| alien.46.uk |
 alien.46.uk Could Be A Chat Bot
 Posted: 15:44 - 01 Oct 2006 Post subject: Is this right? |
 Posted: 15:49 - 01 Oct 2006 Post subject: |
| alien.46.uk |
| 0ddball |
 0ddball World Chat Champion
 Posted: 15:54 - 01 Oct 2006 Post subject: |
I'd be wanting at least 2 full threads showing once the nut is fitted.
I don't think it means that type of squish It's probably refering to the gap between the rim of the piston and the cylinder head deck at tdc. |
| Paddy Blake |
| cestrian |
 cestrian World Chat Champion
| gavin |
 gavin World Chat Champion
| cagiva gezzer |
 Posted: 16:31 - 01 Oct 2006 Post subject: |
Download a manual.  ____________________ "because one stroke isnt enough and four strokes waste two" |
| alien.46.uk |
| six |
 six Trackday Trickster
 Posted: 16:48 - 01 Oct 2006 Post subject: |
slightly off topic, but could anyone tell me what a gasket is? lol... I was just reading through and I don't have a clue what any of it is about! hehe
sorry for being thick!
Tom ____________________ I ride: 2003 Aprilia RS50
Yamaha R1 Fund: ?-0600.00 (grr ) |
 Posted: 17:04 - 01 Oct 2006 Post subject: |
You can't have measured the squish until the whole lot is torqued down and the head is on. You certainly can't do it with a feeler guage.
As has been said, those base gaskets are WAY too thick. A thicker gasket increases the squish, a thinner one reduces it. Standard gasket paper is 0.4mm (roughly 1/64"). You can cut your own out using gasket paper or thin card.
With a brand new barrel and head, you'd only normally need one gasket. May need more if the head had been skimmed/lapped a fair bit.
So, you would need to fit it with ONE paper gasket. If you still don't have enough stud showing, contact the place that sold you the barrel and ask them about it because something has gone wrong somewhere, maybe their design needs slightly longer studs fitting? Once you have the barrel bolted down, fit the head.
The way I was taght to measure squish was to make a 'ring' of solder slightly smaller than the diameter of the bore and lay this on top of the piston. Then fit the head, torque it down, turn the engine over once by hand and remove the head again. Now measure the bit of solder. The thickness of the solder = the squish. Gavins technique sounds easier though.
If the squish is too small, fit another base gasket. If it is too big, skim a bit off the top of the barrel/head. |
| six |
| alien.46.uk |
 Posted: 17:21 - 01 Oct 2006 Post subject: |
Well i've taken them all off and put the smallest one on and there isn't even enough thread showing to fill up the bolt ...
Im going to get slightly stroppy with the company as i've asked them three times to clarify this is the right kit as i need this bike on it first run-in on Tuesday as from this week i cant get a lift to college anymore ...
Hmphh ... I even thought to myself last night [Whilst slightly pissed] that this was going too well because i was enjoying it too much ... Something always stops me ...
That haynes looks interesting Kickstart, i know its the same engine, but its a totally different bike, lol ... Think ill pass on that one and keep browsing for the Rotax 123 Manual then base the body on the old 650, lol as its the ame frame ... Also noticed the '98 ETX is vertually identical parts wise, so that isn't too bad ...
Anyway, ill give it another check and see whats going on, i think they've just made the base to thick as i dont think it being too wide will effect, might look odd and add weight, but internally it matches up ...
Luke.
 ____________________ 2007 Kawasaki ZX10R :: 1998 Kawasaki ZX-9R - SOLD
1998 Yamaha FZS600 Fazer - SOLD :: 1994 Aprilia Pegaso 125 - SOLD |
| cagiva gezzer |
 Posted: 17:32 - 01 Oct 2006 Post subject: |
https://www.laverdaman.co.uk/
God knows what the bike is a mix of.
If you're not sure about how the two stroke engine is meant to work, take a look around sites like
https://www.eric-gorr.com/
www.macdizzy.com
Or buy one of the two stroke books - jennings / bells - .
Or, shock horror, ask on a Aprilia site? ____________________ "because one stroke isnt enough and four strokes waste two" |
| gavin |
 Posted: 17:33 - 01 Oct 2006 Post subject: |
just spotted something odd about that barell.......usually the bolt lands (mating faces) are machined down a bit. this is done to locate the flange of the nut properly.
the ones on that barrell arent, and they dont even appear to be flat in relation to the studs. if that is the case, even if you get it to do up, the nuts wont sit right, they will touch one side first and bind on the threads. maybe you have a barell that didnt get fully machined  |
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 17:34 - 01 Oct 2006 Post subject: |
How does it compare to the old one?
If the gasket is much thicker then theres the problem as it does nt look a very good fit in my opinion, it does nt seem to follow the contours of the casings. Surley, like mentioned before, it should be paper thin, not several mm thick?
If the new part is the top end then is this different, as the studs in the existing block have not shrunk overnight and maybe the new part is not suitable for the bike.
Comparing new with old takes 2 minutes and will tell you insantly whether there will be problems  ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| Paddy Blake |
| Whosthedaddy |
| cagiva gezzer |
| Paddy Blake |
 Posted: 17:45 - 01 Oct 2006 Post subject: |
The studs may be unscrewed slightly giving you more threads to tighten a nut onto to [/quote] |
| gavin wrote: | just spotted something odd about that barell.......usually the bolt lands (mating faces) are machined down a bit. this is done to locate the flange of the nut properly.
Yeah, it doesn't mate-up with the crankcases very well, far too much overlap in some places and exposed mating surface in others. The gasket doesn't look like it was meant for either the barrel or the engine, doesn't extend to the edge of either. I'd normally expect the gasket to extend round all the studs, which it clearly doesn't.
This picture in particular looks distinctly ropy, huge gap under the barrel, no gasket round the stud. Make sure they sent you the right bits.
https://i14.photobucket.com/albums/a317/taazzukcb/Pegaso%20Re-Build/DSCN0072Medium.jpg |
| gavin |
The last post was made 20 years, 21 days ago. Instead of replying here, would creating a new thread be more useful? |
