You'd think it would be straightforward.
krebsy
PostPosted: 10:29 - 05 Oct 2006    Post subject: You'd think it would be straightforward. Reply with quote
Recipie:
1 Concrete floor
1 ground Anchor
1 mains powered drill
1 16mm concrete drill bit
Result?
2 half inch deep holes (need 4 x 90mm deep)
1 face full of dust
1 pair of stinging arms (from the feedback from the drill)
Anyone got tips for drilling into concrete? I need to get the anchor fitted but I'm having no joy drilling into the floor. Even tried pilot holes with a smaller 10mm drill (wall bit) but I just can't get deep enough. the floor seems to be poured concrete on top of god knows what....
K.
1280 x 1024.
finpos
PostPosted: 10:42 - 05 Oct 2006    Post subject: Reply with quote
Need bigger drill!
finpos.
krebsy
PostPosted: 10:49 - 05 Oct 2006    Post subject: Reply with quote
Smile
It's a 500W mains powered affair, the thing spins, it's just not eating the concrete. Sad. Will ask a mate or two if they have something larger... Smile
K
1280 x 1024.
finpos
PostPosted: 10:55 - 05 Oct 2006    Post subject: Reply with quote
Domestic drill won't touch foundation concrete - as you've discovered Smile
I had to hire one of the big sod off things out of a shop to do something similiar, even a SDS type drill I borrowed wasn't tickling it.
finpos.
Finglonga
PostPosted: 11:25 - 05 Oct 2006    Post subject: Reply with quote
Is it a hammer drill? as if its not you wont touch the concrese.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 11:44 - 05 Oct 2006    Post subject: Reply with quote
Your drill is spinning too fast. You need something like a Hilti TE72 to do the job.
Where are you I could drill them if you are local?
krebsy
PostPosted: 12:05 - 05 Oct 2006    Post subject: Reply with quote
Using the hammer action and not going on full revs, only using about half speed. I'm in Milton Keynes and there's a HSS tool hire place just up the road so I'll pop up and see if they've got anthing that'll do the job I could hire.
K.
1280 x 1024.
MattHirst
PostPosted: 12:22 - 05 Oct 2006    Post subject: Reply with quote
I went to a rapid hire place when i fitted my ground anchor (i made them at work...36mm rawl bolt biatch Cool )
I'll get a pic of one of them later, big chunky ass things (made 2)
i hired a SDS maxi drill and a 36mm bit for the week.
£13 for the drill and about £2.50 for the bit and they made mince meat of the concrete Very Happy
The bolts took some braying in so i think they are pretty much stuck there...but saying that, about 2 2weeks after i fitted it my dad said he was organising a new garage to be put in Evil or Very Mad
divuk83
PostPosted: 12:34 - 05 Oct 2006    Post subject: Reply with quote
I have fitted 3 ground anchors and a door defender into solid concete using a hammer drill and a 16mm masonry bit. Took a long time to get the holes drilled and after doing all that the chuck on the drill is knackered. It can be done, but it takes ages.
Dave
krebsy
PostPosted: 12:42 - 05 Oct 2006    Post subject: Reply with quote
both wrists are knackered from a 40mph Mountain bike smash 10+ years ago so I need to be able to get through the floor as quickly as possible. Otherwise I get a ton of pain as all the little bones in my wrists jostle for position.. Smile..
Mind you, my current drill punched a hole for an electrical cable through the solid brick wall of my house with no problems, chewing through bbricks and steel with just the wall bit. Smile
K.
1280 x 1024.
The last post was made 19 years, 364 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 63.29 Kb
