Winter maintenance
sagiliam
PostPosted: 16:39 - 06 Oct 2006    Post subject: Winter maintenance Reply with quote
The cold weathers coming and its pissing down outside with a near gale force wind. Just looking for some general winter maintenance tips to make sure the bike doesnt give up. Whats best to stop corrosion?
Thanks
Liam
TOM M
PostPosted: 17:06 - 06 Oct 2006    Post subject: Re: Winter maintenance Reply with quote
A warm garage
Now owner of a 1200 Bandit
ram_doom
PostPosted: 17:18 - 06 Oct 2006    Post subject: Re: Winter maintenance Reply with quote
Wash everything every couple of days, particularly fork stanchions, header pipes on exhaust, frame, brake area, rear set assemblies etc... then dry with a chamois whilst running the engine for 5 - 10 minutes or so to dry out bits you've missed.
Give any moving parts a good lubricating, then everything metal a coat of something like FS365, and polish the bodywork with a decent wax.
Once a month or so, its a good idea to remove your bodywork and clean the crap and salty yuck off the hidden areas of frame and engine, and coat them with something protective...
TL1000s, KDX200
SoulRider
PostPosted: 17:52 - 06 Oct 2006    Post subject: Reply with quote
If you clean the forks do you need to lube them again?
Might sounds stupid question but not sure, so thought best to ask.
My Bike Pics
ram_doom
PostPosted: 18:01 - 06 Oct 2006    Post subject: Reply with quote
No, just keep the shiny part of the fork clean, and the seals too. Dont let any grime get up between the seal and the tube Wink
TL1000s, KDX200
SoulRider
PostPosted: 18:16 - 06 Oct 2006    Post subject: Reply with quote
Cheers, all is good now, will give the bike a good clean this weekend as its so dirty that coronaboner wrote clean me on my exhaust.
My Bike Pics
mr.z
PostPosted: 18:45 - 06 Oct 2006    Post subject: Reply with quote
Fork gaitiors, any moto-x shop will have them and there cheap as a cheap thing..
Personally i use a mix of grease one some parts and WD40 on others, wd40 stuff gets reallyed with each time it gets washed.. a light hoseing after every ride will be the best soloution really though.. and take very good care of your chain because they dont get on with the salt well..
iCraig
PostPosted: 12:34 - 07 Oct 2006    Post subject: Reply with quote
Or do what I do, never clean your bike so the layers of shite build up inturn creating a protective layer from the road salt.
I don't think I've cleaned my bike in about a year and I don't have a problem with corrosion!
phatstorage
PostPosted: 13:24 - 07 Oct 2006    Post subject: Reply with quote
https://www.scottoiler.com/pc/Lubes,_Cleaners_;am;amp;_Protectors/FS_365_Protector_Spray_-_1_Litre.html
just ordered some and hope it does the trick. Thumbs Up
that and the chain oiler i think all should be well for the winter.
do you have a fender extender? expensive bit of plastic that works wonders for the area behind the front spinney thing Smile
"Product whore", i know Rolling Eyes
Misc
PostPosted: 18:34 - 07 Oct 2006    Post subject: Reply with quote
Mine came through a few days ago, won MCE best product so should be good. How do you use it tho? Do you need to wipe it after with a cloth..
ram_doom
PostPosted: 18:38 - 07 Oct 2006    Post subject: Reply with quote
I saturate mine and catch/wipe the excess Thumbs Up
TL1000s, KDX200
Chuff
PostPosted: 18:51 - 07 Oct 2006    Post subject: Re: Winter maintenance Reply with quote
Buy a honda Thumbs Up Mr. Green Karma
GS500e- 3 weeks, vfr750 - 12 months, cbr900 13 months, CBR1100XX 2 years, CBR600F4i 3 months cbr900rrx 5 months and counting
kawakid
PostPosted: 23:54 - 08 Oct 2006    Post subject: Re: Winter maintenance Reply with quote
TOM M wrote:
A warm garage
Very true.
Unfortunately my garage is detached from the house and not heated.
My mates got an integral garage and the boiler is kept in there for the house. The jammy git.
Serendipity
PostPosted: 00:10 - 09 Oct 2006    Post subject: Reply with quote
I used to have one of those on my Diversion and it was great. I later fitted one to my CBR and it also worked well until I hit a big bump while two up and it popped into the front of the lower fairing locking the steering in a straight line. Not a nice experience.
When it did it a second time on the Hanger Lane gyratory I ripped it off and tossed it.
Good product, just make sure if you have a full fairing that there's enough clearance.
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
veeeffarr
PostPosted: 00:41 - 09 Oct 2006    Post subject: Reply with quote
ACF50
Itchy
PostPosted: 09:19 - 09 Oct 2006    Post subject: Reply with quote
[quote="Misc]
Mine came through a few days ago, won MCE best product so should be good. How do you use it tho? Do you need to wipe it after with a cloth..[/quote]
spray on about an hour after riding the heat will cook it on , or just spray all over (cept for brakes) then fire her up and watch all the cook off!.
reapply after rain as it washes off.
extreme3d
PostPosted: 09:47 - 09 Oct 2006    Post subject: Reply with quote
One of the benefits of FS365 is that it will not burn on. Sprays like WD40 will, especially on the exhaust. You can spray FS365 all you want onto hot surfaces, the oil has a very high boiling point and just goes super thin which if anything is what you want as it will then flow easily into all the hard to reach areas. What you see steaming and fizzing away is the water content. The medium that allows the oil to flow - FS365's 'flux' if you will. Once this evaporates the oil is left as a thin coating.
Whats more it actually neutralises salt. Additives in the solution chemically react with and turn salt into an inert compound. This is why spraying something like WD40 will not work as although it will protect a clean surface, it will not help a surface already dirty Wink
The real beauty of it though is that it allows you to ride in winter and still only have to wash once a week. If you were to wash/wipe down your bike after every ride you will soon get bored and what's more the bike is no longer a more practical solution than a car Shocked .
Simply spray FS365 onto the main areas that get covered with salt (engine, frame, radiators/coolers/, subframe, exhaust) and they will then be protected from salt corrosion taking place overnight. Only a fine mist is needed and it takes only 30 seconds if that.
With a little bit of practice you can spray onto the fork lowers without getting any onto the brakes. I also spray onto the caliper exteriors and brakes lines to keep them looking like new - BUT you must be entirely confident with your spraying technique to do this as oil and brakes don't mix Exclamation
Itchy
PostPosted: 14:11 - 09 Oct 2006    Post subject: Reply with quote
wash ? , wash??!! blasphemy!
just use a piece of card board to put over your brake disc and spray away as normal ,
extreme3d
PostPosted: 16:34 - 09 Oct 2006    Post subject: Reply with quote
shhh Shhh! your're giving away all my secrets about how to avoid spray on the disks! I was trying to give the impression I manage it by just being good at spraying the stuff Laughing
The last post was made 19 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 108.43 Kb
