| Cillit-BANG |
 Cillit-BANG World Chat Champion
 Posted: 20:55 - 06 Oct 2006 Post subject: Total loss track electrics |
Does anyone know whats involved with the above? Is it simply a case of ripping out anything that isn't needed from under the alternator cover and the relevent wiring?
Would it mean you can do away with the regulator/rectifier or does this need to stay in the circuit for some reason?
And yes, I do know it may well be a pain in the arse with no charging system, but unless you try for yourself
Cheers for any help. |
| Paddy Blake |
 Paddy Blake World Chat Champion
| finpos |
 finpos World Chat Champion
 Posted: 01:10 - 07 Oct 2006 Post subject: |
Educated guess:
rip out all the stator coils. rip out the big heavy flywheel* that turns the magnets for the stator. rip out the regulator. run your ignitor gubbins off a battery that you charge off the bike and keep a couple of batteries spare. A good battery will run your ignition long enough for what you need. In theory, that's all. If you look at battery specs, one of the figures is how low long it will run an average ignition without any charging, and it's usually plenty long enough.
Loosing the flywheel means you need to keep the thing on top beans all the time, but that's not a problem for what you want it for
As long as you don't want to start the bike off the battery, you'll probably get away with a much smaller and lighter battery than standard as well.
finpos.
* you'll need a lightened flywheel otherwise it'll probably be too mad.
| Paddy Blake |
 Posted: 01:22 - 07 Oct 2006 Post subject: |
What are you trying to do because i once ran a bike on an everyready
battery when i worked in a garage and no one would take my word and
they had to see the battery that was in the bike.
Paddy. |
| finpos |
 Posted: 01:25 - 07 Oct 2006 Post subject: |
He wants to race the bugger on a track for 30 mins at a time
Excellent.
finpos. |
| Paddy Blake |
| Paddy Blake |
| Cillit-BANG |
 Posted: 08:41 - 07 Oct 2006 Post subject: |
Great cheers.
So just to confirm, I can rip out the regulator as this just controls the ac current coming from the alternator, charging the battery with dv and stops it frying once full?
They are a known fualt on the nc30's so getting it out would be handy
Can modifying the old flywheel be done or is it a precise science with regards even weight distribution? I'm thinking it could be expensive to buy:lol: |
| G |
 G The Voice of Reason
| finpos |
 Posted: 13:30 - 07 Oct 2006 Post subject: |
Yes, you can simply remove the regulator and associated wiring, the battery will then go flat as you run the bike. Now sober, I can remember that the battery rating you are looking for is the "reserve capacity" (RC) which will give you an idea how long it will run the bike for you without any charging input. Don't forget to factor in starting the bike - unless you rip the starter motor out as well
finpos. |
| Kickstart |
 Kickstart The Oracle
 Posted: 13:41 - 07 Oct 2006 Post subject: |
Not 100% sure on the NC30, but the ignition probably works off it as well. Cutting it down would be possible, just make sure you cut the right bit down. The bike will rev more quickly and stall far more easily.
The regulator / rectifier unit take the high voltage AC and converts it to DC (the rectifier bit) of nominally 12V (the regulator bit). You should be able to remove it but might have run with the wiring afterwards.
You might find that you save rather more keeping the charging system and using a far smaller battery.
| Cillit-BANG |
| Cillit-BANG |
| Kickstart |
 Posted: 16:24 - 07 Oct 2006 Post subject: |
| Cillit-BANG |
 Posted: 16:47 - 07 Oct 2006 Post subject: |
Great, many thanks. Should get a few bob for my old rectifier too
Maybe I'll start practicing my jump starts ready for next year to save battery power  |
The last post was made 20 years, 3 days ago. Instead of replying here, would creating a new thread be more useful? |
