Carbs off question
Sephiroth
PostPosted: 23:12 - 08 Oct 2006    Post subject: Carbs off question Reply with quote
Hey just wondering what I need before hand before I take carbs off Bandit 400?
Things like gaskets etc?
cheekythomas
PostPosted: 23:16 - 08 Oct 2006    Post subject: Reply with quote
Nothing but time! Wink
You could be super efficient and get float bowl rubber seals but 99% of the time they are fine time after time! Might be worth getting a few 5mm short bolts incase you distroy any getting them undone.
Bezzer
PostPosted: 23:17 - 08 Oct 2006    Post subject: Reply with quote
Depends why you are taking them off, if it's just to get them out of the way while you do work on the engine etc then you don't need anything. If you're fully stripping and checking the carbs then an overhaul kit is your best option, checking float bowls, float height etc then just a float bowl gasket.
Either get them from a dealer or somewhere like NRP.
https://www.nrp-carbs.co.uk/
Sephiroth
PostPosted: 23:22 - 08 Oct 2006    Post subject: Reply with quote
Cheers guys.
Was going to take it off to see if the bike is restricted Smile
PostPosted: 23:31 - 08 Oct 2006    Post subject: Reply with quote
Pull the airbox and open the throttles, lift a slide and look in - if you see metal discs in the inlet tracts you're restricted. If you're lucky you might be able to just pull the lid and the air filter, I can't remember if it was possible from working on my sister's bandit.
Sephiroth
PostPosted: 23:33 - 08 Oct 2006    Post subject: Reply with quote
The restrictors are between the airbox and carbs then? Thought it was carbs and engine?
jay_666
PostPosted: 23:39 - 08 Oct 2006    Post subject: Reply with quote
take tank off, remove air box, remove carbs, should see the restrictors
https://w1.bikepics.com/pics/2006/09/29/bikepics-690377-full.jpg
PostPosted: 23:43 - 08 Oct 2006    Post subject: Reply with quote
No, as Jay's pic shows you would have had to open the throttles and lift a slide to see. Smile
Sephiroth
PostPosted: 23:45 - 08 Oct 2006    Post subject: Reply with quote
Right so between carbs and engine then? Wink
PostPosted: 23:47 - 08 Oct 2006    Post subject: Reply with quote
Aye, if they were before the carbs, the vacuum caused by the engine would cause far too much fuel to be taken in Smile
Sephiroth
PostPosted: 23:48 - 08 Oct 2006    Post subject: Reply with quote
Groovy, thanks for your help.
How long should this take after taking tank off? Just a ballpark figure
PostPosted: 23:49 - 08 Oct 2006    Post subject: Reply with quote
Not very long, depending on how profficient you are with a spanner. I guess about an hour start to finish.
cheekythomas
PostPosted: 00:07 - 09 Oct 2006    Post subject: Reply with quote
Also depends on the make of restrictor kit fitted Wink
Genuine suzuki kit doesnt have inlet restrictors, its carb internals! Cool
The last post was made 20 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 75.68 Kb
