> URGENT < Rounded off a screw! Help!
veeeffarr
PostPosted: 22:02 - 10 Oct 2006    Post subject: > URGENT < Rounded off a screw! Help! Reply with quote
Hi,
Got a cross head screw here connecting my airbox to the bike frame.
When I went to take it off, it just rounded straight away, good old Suzuki Cheese.
I only have sockets, spanners, a screwdriver.
Any way I can get the fucker off?
neeeel
PostPosted: 22:11 - 10 Oct 2006    Post subject: Reply with quote
1 - find a socket slightly smaller than the screw head, hammer it on, try and remove it that way
2- drill out the screw till the head falls off, remove the airbox, then use pliers to remove the rest of the screww
3 - use a hacksaw to cut new grooves in the screw head, and try the screwdriver again
4 - put the screwdriver at an angle to the edge of the screw, and use a hammer to hit the screwdriver to push the screw round( not sure if ive explained this one very well)
sure theres other ways
veeeffarr
PostPosted: 22:15 - 10 Oct 2006    Post subject: Reply with quote
At the moment option 4 seems the only viable option.
Would you believe it, I dont even have a hammer.
Can't hacksaw, theres not enough space and I only have a pen knife saw Sad
Cheers,
T
veeeffarr
PostPosted: 22:32 - 10 Oct 2006    Post subject: Reply with quote
Well number 4 doesn't work Sad Sad Sad
I'm stuck for ideas now, I've just spent an hour taking everything else I need to off.
Yoshi
PostPosted: 22:33 - 10 Oct 2006    Post subject: Reply with quote
Mole grips Thumbs Up
Present: GS650 Katana - Getting ready for summer touring!
Past: TS50, RS50, ZXR400, LT80, TS250
veeeffarr
PostPosted: 22:47 - 10 Oct 2006    Post subject: Reply with quote
Got none mate Sad
carvell
Scuttler
PostPosted: 22:52 - 10 Oct 2006    Post subject: Reply with quote
The socket idea is usually the best option, if it has a domed head and isn't countersunk obviously.
Yamaha TDM 850
veeeffarr
PostPosted: 22:55 - 10 Oct 2006    Post subject: Reply with quote
Tried, can't get the socket on it, using a 22mm spanner as a hammer, lol
carvell
Scuttler
PostPosted: 23:00 - 10 Oct 2006    Post subject: Reply with quote
You need to use a proper hammer.
There's no way you'll be able to get a socket of the right size to undo the bolt on with anything less than a big hammer!
Yamaha TDM 850
yambabe
PostPosted: 23:16 - 10 Oct 2006    Post subject: Reply with quote
Are you at home or in Warrington? Might be able to drop by with some tools tomorrow if you've not sorted it by then......
veeeffarr
PostPosted: 00:14 - 11 Oct 2006    Post subject: Reply with quote
I'm at home, don't worry about it Jo, thanks for the offer tho, I've just put the bike back together.
TheDonUK
PostPosted: 10:20 - 11 Oct 2006    Post subject: Reply with quote
If i remember correctly arent the airbox screws the rounded head ones? in which case if you dont have a hammer, use something heavy and bash a screwdriver in making a grove... or drill it out ....
meenie
PostPosted: 14:44 - 11 Oct 2006    Post subject: Reply with quote
EVERY mechanic should have a hammer!!! The better you are the more hammers you have and heavier they are!! Smile
Owner : ZXR750L3 ('96) My bike @ BikePics.com
Wearer: Alpinestars & Shoei
SafeSpeed
veeeffarr
PostPosted: 14:47 - 11 Oct 2006    Post subject: Reply with quote
Found the Suzuki toolkit under the seat.
Doh.
Unfortunately it's all rusted, and shit.
I did find a leaf in my airbox tho Very Happy
Also found out STARDROPS is a boss bike cleaner.
meenie
PostPosted: 15:01 - 11 Oct 2006    Post subject: Reply with quote
Doh.
That is because they are made of an alloy of chocolate and cheese Wink
SafeSpeed
veeeffarr
PostPosted: 16:36 - 11 Oct 2006    Post subject: Reply with quote
Well the flat bladed screwdriver surrendered to my repeated hammering and drove itself into the handle.
Cheap shit.
ram_doom
PostPosted: 16:46 - 11 Oct 2006    Post subject: Reply with quote
Tobe, mole grips are available in all cheapy stores for under a fiver Mr. Green *FACT* you wont get far without molegrips Wink
Small chisel might be a good idea too...
TL1000s, KDX200
Finglonga
PostPosted: 16:50 - 11 Oct 2006    Post subject: Reply with quote
Cheap shit.
You get what you pay for with tools, if a crosshead driver is used in a posidrive screw chances are it will round it off and vice a versa. Most good quality screwdrivers have the metal shaft that goes to the top of the handle, not designed to be hammered but it works sometimes.
It would be worth investing in a good quality tool set before destroying...i mean working on the bike. Mr. Green
Andy Sez....
F.Y.Y.F.F.
PostPosted: 19:37 - 11 Oct 2006    Post subject: Reply with quote
You need more tools, cannae do the job with what you have. Even a pair of pliers.
If you had pliers you could just rive the airbox off over the head of the screw, undo the screw with your pliers then refit it using a washer to cover the now slightly larger hole in the airbox. Bodgery at its worst but hey..
Why do you need to take the airbox off anyway?
Walloper
PostPosted: 21:10 - 11 Oct 2006    Post subject: Reply with quote
You are ignoring the 1st Law of Scottish Engineering:
If at first ye canny git it
Pick up yer hammer and Fuckin' Hit It.
PostPosted: 21:21 - 11 Oct 2006    Post subject: Reply with quote
4oz ball pein.
Standard draper claw
1/2lb nylon deadblow
1/2lb copper shotted deadblow
1lb 'pioneering' with rear half hammered into hatchet blade.
2 1/2lb lump
5lb sledge
Really want a slide hammer, going to ask for one for christmas.
Mr. Green
veeeffarr
PostPosted: 00:54 - 12 Oct 2006    Post subject: Reply with quote
To derestrict the bike (Access to the carbs)
PostPosted: 02:17 - 12 Oct 2006    Post subject: Reply with quote
Can you not just pop the rubbers off or fold them back? Might need to heat them up a little first.
The last post was made 20 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 117.29 Kb
