Vibration when braking
UrbanRacer
PostPosted: 16:04 - 13 Oct 2006    Post subject: Vibration when braking Reply with quote
got a little problem with the front brakes on my GSXR 600 K4. when i use the front brake at low speeds i get a bit of vibration, sometimes it can be quite severe. i replaced the discsw and pads a while back so i know it isn't them. i was hoping someone else could think of something. i'm going to change the brake fluid over the weekend.
i was thinking it might be the hoses that are getting a little soft and expanding when i use them, but it only happens at low speeds like under 20mph.
any ideas?
***edit*** currently i have Sintered HH pads and Braking wavey discs
element
PostPosted: 16:25 - 13 Oct 2006    Post subject: Reply with quote
its vibration through the bars or though the lever?
headset bearings normally causes that else check for play in the front wheel bearings and in the forks/triplecrown. Also check the caliper bolts are tight (would be obvious if they were but only takes a second to check)
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
PostPosted: 16:40 - 13 Oct 2006    Post subject: Reply with quote
Though I'd have thougt it would get worse with speed; check your wheel bearings.
UrbanRacer
PostPosted: 16:53 - 13 Oct 2006    Post subject: Reply with quote
it comes through the bars, in fact the whole front end of the bike vibrates
will do cheers
element
PostPosted: 17:03 - 13 Oct 2006    Post subject: Reply with quote
Normally you can tell worn wheel bearing as you can feel the bike drifting side to side. You dont need to be braking to feel it either. Id say its headset bearings. You tend to notice they are going when your braking with just the front brake as the front judders. You feel it over bumps/potholes too cos the whole front end shakes. Smile
mrtEE
PostPosted: 17:15 - 13 Oct 2006    Post subject: Reply with quote
have u been doing wheelies?
UrbanRacer
PostPosted: 19:47 - 13 Oct 2006    Post subject: Reply with quote
no wheelies. i had a quick look over the front end of the bike tonight and everything feels ok. no movement at all in the front wheel and the forks feel fine Confused
shammon
PostPosted: 14:09 - 14 Oct 2006    Post subject: Reply with quote
check your fork leg securing bolts! coul dbe there not tight enough. had a simelar prob on my bike and one was ready to come off Shocked . Caused vibration in the front end.
YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı
PostPosted: 14:11 - 14 Oct 2006    Post subject: Reply with quote
If through the bars then that suggests an issue with the front suspension / steering.
Front wheel bearings, steering head bearings, fork bushes, deformed tyre, etc.
Could even be from having the front suspension badly set up (believe way too stiff can cause this problem).
UrbanRacer
PostPosted: 17:35 - 15 Oct 2006    Post subject: Reply with quote
Changing the brake fluid seems to have stopped the vibration, cheers for the help guys
Gradog
PostPosted: 17:50 - 15 Oct 2006    Post subject: Reply with quote
You may not feel the movement until you lift the front of the bike, when it then becomes obvious. It still sounds like head bearings.
either use a paddock stand and put a jack under the engine or get a mate to pull her over on the side stand if you dont have the paddock stand. I am sure you wil then feel play by pulling at ythe bottem of the fork legs.
Grey haired bikers don't get that way from pure luck. Only a biker knows why a dog sticks his head out of the car window.
UrbanRacer
PostPosted: 18:27 - 15 Oct 2006    Post subject: Reply with quote
ok, i'll check it again later.
The last post was made 19 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 72.41 Kb
