Bike bogs when i rev?
dransy
PostPosted: 00:52 - 15 Oct 2006    Post subject: Bike bogs when i rev? Reply with quote
Hi all ive had this problem before but its been so long since ive tinkered with my rs.
Anyway got it all runing now but when i go to rev it the bike bogs down. if i put the choke on it doesnt do it?
I took my carb apart and cleaned my jets checked my fuel pipes for blockages etc all seems ok.
Still doing it , not as bad but it still is. Will a new plug help?
Im gonna tinker with my mixture tomorrow to see if that helps as its smelling abit rich.
Could it be the mixture?
hmmmnz
PostPosted: 04:29 - 15 Oct 2006    Post subject: Reply with quote
if it bogs down with out the choke on and then revs better when its on my guess is that its running lean.
you may have a leak in the rubber boot between the carb and the air box.
have you modified the air box or changed the filter, those 2 things will make it run lean
(bike generly don't bog down when rich they just blow black smoke. its normally when they are lean that they do.
try the wd40 trick and see if you have a air leak some where,
(spray wd40 at the rubber boot, while the bike is running, if the revs change you more than likely have a leak)
also check that your exhaust doesn't have a leak, or that its not all full of coke(carbon build up)
the humans are dead
I kick arse for the lord
dransy
PostPosted: 15:20 - 15 Oct 2006    Post subject: Reply with quote
Hi all i need to make the rs richer, do i turn the mixture screw cock wise or anti clockwise?
irving
PostPosted: 15:57 - 15 Oct 2006    Post subject: Reply with quote
Question
dransy
PostPosted: 16:01 - 15 Oct 2006    Post subject: Reply with quote
my bike is totally standard. Its blowing tons of white smoke and keeps bogging out , any ideas?
irving
PostPosted: 16:12 - 15 Oct 2006    Post subject: Reply with quote
Question
dransy
PostPosted: 16:19 - 15 Oct 2006    Post subject: Reply with quote
Ive always run it on castrol super tt its always been spot on. it has new fuel in.
My coolant level doesnt drop no so it cant be leaking anywhere
irving
PostPosted: 16:27 - 15 Oct 2006    Post subject: Reply with quote
Question
dransy
PostPosted: 16:28 - 15 Oct 2006    Post subject: Reply with quote
when i take it out down the street thats when it kicks out tons of white smoke if i turn it off for 5 mins then let it tick over in neutral hardly any smoke at all comes out?
dransy
PostPosted: 16:30 - 15 Oct 2006    Post subject: Reply with quote
Its been stood all threw last winter and this summer over the past 4 days ive done it up again and got it running and it wasnt ticking over so i altered the mixture n it ticked over.
And as soon as i give it some revs it bogs out straight away at like 2000rpm
irving
PostPosted: 16:42 - 15 Oct 2006    Post subject: Reply with quote
Question
dransy
PostPosted: 16:43 - 15 Oct 2006    Post subject: Reply with quote
I took my carb apart yesterday, cleaned my jets and they are fine*sigh* ill just keep tinkering with it
irving
PostPosted: 16:54 - 15 Oct 2006    Post subject: Reply with quote
Question
dransy
PostPosted: 17:56 - 15 Oct 2006    Post subject: Reply with quote
One more thing my bike runs perfect with choke on i rev it and it revs and when i let got of the throttle the revs drop but id i take the choke off, it bogs down and if i rev it and it revs it takes ages for the revs to drop
irving
PostPosted: 18:04 - 15 Oct 2006    Post subject: Reply with quote
Question
PostPosted: 18:12 - 15 Oct 2006    Post subject: Reply with quote
Err, one thing to check is that the 2 stroke oil pipe is connected (and connected to the correct spigot on the carb). Leave it disconnected and it will be running lean and also running without oil which can cause some interesting colour smoke.
White smoke is normally a sign of water.
extreme3d
PostPosted: 20:18 - 15 Oct 2006    Post subject: Reply with quote
Silly point i'm sure, but are you quite sure that choke off is not in fact choke on and visa versa? If you've not been out on the bike for a while even those things that you did without thinking before can be forgotten!
jay_666
PostPosted: 20:24 - 15 Oct 2006    Post subject: Reply with quote
Its a 2 stroke and its been standing fore ages.
Just take it out for a blast and get all the clag out of it Thumbs Up
The last post was made 19 years, 184 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 96.99 Kb
