Clutch slip?
Graham88
PostPosted: 03:34 - 15 Oct 2006    Post subject: Clutch slip? Reply with quote
Was out tonight, and everything was normal, having a blast, high revs then change into gear, all normal....
Then suddenly when I was doing a quick start it'd go around the rev range like normal (whilst accelerating) then get to say 8-10k it'd just just rev to about 13k and then it would bite and go.
It only does it when accelerating fairly hard, what's the reason?
Rookie
PostPosted: 03:40 - 15 Oct 2006    Post subject: Reply with quote
As per the title, it's clutch slip. Basically your clutch plates and/or springs are worn. It's not particularly expensive in parts, and with a Haynes I hear the job itself is OK for an amateur mechanic. But it's not masses of labour anyway.
irving
PostPosted: 16:05 - 15 Oct 2006    Post subject: Reply with quote
Question
Graham88
PostPosted: 16:58 - 15 Oct 2006    Post subject: Reply with quote
irving wrote:
Has it been changed recently?
It was about 4000 miles ago.
I was going to do it soon anyway, should I do the change before I change clutch plates?
irving
PostPosted: 17:00 - 15 Oct 2006    Post subject: Reply with quote
Question
Graham88
PostPosted: 17:11 - 15 Oct 2006    Post subject: Reply with quote
OK cheers, new clutch plates it is Thumbs Up
PostPosted: 17:13 - 15 Oct 2006    Post subject: Reply with quote
Sounds like clutch slip. Normally worse in higher gears (ie, full throttle @ 10000rpm in top is far more likely to trigger it than the same throttle and revs in 1st gear).
Think the NC30 is slightly tricky to change the clutch plates on (special tool required, someone might have one you can borrow).
shammon
PostPosted: 20:13 - 15 Oct 2006    Post subject: Reply with quote
Or have you left enough slack on the clutch lever? a tight lever can result in cluth slip from my experience.
YAMAHA YZF 1000cc THUNDERACE- 'ƃuıןןǝds ʇnoqɐ ʇıɥs ɐ ǝʌıƃ ʇuop ı
Graham88
PostPosted: 04:53 - 16 Oct 2006    Post subject: Reply with quote
Clutch has slack yeah.
Kickstart, I'll check my Haynes tomorrow to see what tool I need.
R1stu
Shrek!
PostPosted: 23:18 - 17 Oct 2006    Post subject: Reply with quote
Keith whats your views on these?
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=019&item=290019569674&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
was thinking of that for the R1 just in case?
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
PostPosted: 23:29 - 17 Oct 2006    Post subject: Reply with quote
Probably be fine. Nothing wrong with the stock plates either normally.
Graham88
PostPosted: 04:12 - 20 Oct 2006    Post subject: Reply with quote
Have got a price of 43 quid for the stock clutch plates.
Or 52 for Race plates....
Race plates it is Very Happy
The last post was made 19 years, 349 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 70.93 Kb
