Help! Idiotic Mistake!
phantomtek
Lil Joe Tek
PostPosted: 20:39 - 15 Oct 2006    Post subject: [HELP!] Help! Idiotic Mistake! Reply with quote
Hi guys,
Well today I was going to change the oil on the SV, as it needed doing.
I went to untighten the sump plug, and in a stupid lapse of concentration I was turning the socket the wrong way, and I heard a snapping sound and the bolt started to turn freely. Then I tried the other way and the bolt came out, so I changed the oil. Then I put it back in and tightened up the bolt up (It just kept spinning, wouldn't tighten) but it looked ok so I left it.
Quick blat up the M1, and parked up. Checked under the bike, the oil is slowly dripping, checked the back tyre, yes the left side is covered in oil.
My Dad had a look and he says that I have basically fooked the thread on the sump, because the bolt is fine. My question is, what the hell should I do in this situation, and how much is it going to cost?
I'm so gutted, because it was totally stupid but there's nothing I can do about it now so I will have to forget it and try fix it.
Any ideas?
Thanks. Thumbs Up
jay_666
PostPosted: 20:41 - 15 Oct 2006    Post subject: Reply with quote
sounds like a new sump for you matey...
umless you can do something like get that liquid stuff and try and re-thread it Confused i duno...
phantomtek
Lil Joe Tek
PostPosted: 20:42 - 15 Oct 2006    Post subject: Reply with quote
Does anyone know if the sump pan on the SV is removeable?
DucatiEVO
PostPosted: 20:47 - 15 Oct 2006    Post subject: Reply with quote
Don't know if it's removeable, but if you have a good look you should be able to tell.
If it's not removeable you could always try fixing it in-situ. I know a mate did the same as you on his crosser, used some of that chemical metal stuff to fill the gap, then just tapped a large M10 thread in it and stuck a bolt in. Thumbs Up
aKa: Ducky
jay_666
PostPosted: 20:48 - 15 Oct 2006    Post subject: Reply with quote
yeah, thats what i ment to say
phantomtek
Lil Joe Tek
PostPosted: 20:50 - 15 Oct 2006    Post subject: Reply with quote
Hi,
What exactly does that mean, what chemical stuff etc? What's an M10 thread? Where do I get all these things from?
Cheers.
extreme3d
Goes to check mine...
https://www.media.suzuki.com/svlaunch/images/engine.jpeg
Afraid it's all one piece. Looks like you will have to get it re-threaded by a garage and use a bigger bolt.
phantomtek
Lil Joe Tek
PostPosted: 21:00 - 15 Oct 2006    Post subject: Reply with quote
I can't ride it as is because there is no oil in it at the moment.
I simply can't afford £80, do you reckon the mechanic will charge me this much?
Crying or Very sad
PostPosted: 21:01 - 15 Oct 2006    Post subject: Reply with quote
Hmm, that's bad if it's all one piece.
Any rethreading, you'd really want to do it with the sump off, so that you don't get swarf in the engine.
Did similar on my ZX6 and got a helicoil kit to do it myself - this results in the same size thread, so you can use the original bolt.
Just looking at the SV engine that I happen to have in bits in my bedroom (the boxes of bits are my bed side table, at the mo Confused ) - doesn't look too good I'm afraid.
Best bet is probably going to be to recut the thread (ideally using a recoil kit - or timesert is better, but a lot more £££ for the kit), then maybe flush the engine a couple of times to be sure.
Alternatively, a could do you a deal on a SV engine Wink.
phantomtek
Lil Joe Tek
PostPosted: 21:09 - 15 Oct 2006    Post subject: Reply with quote
G, do you have any idea what size the thread is on the sump? Could you have a quick gander if it isn't too much trouble?
Just need to work out what size helicoil I'll need.
I bought the kit and used just one coil . Have to go around stripping sump plugs to get my money back lol
Does this mean you have another coil left?
PostPosted: 21:13 - 15 Oct 2006    Post subject: Reply with quote
If you search on Ebay for davethetools , he has a load of helicoil type repair kits. About £38~£58. M14 x 1.25 kit here.
However you do need to use one of these straight, and it is not a bolt that is in a good position to learn with. Also a touch critical to the bike. And the must be very sure there is no swarf left inside after doing so (and the crankcases being alloy, any swarf will be alloy and will not stick to a magnetic sump bolt).
If the drain hole is in the main crankcases then I would say take it to a local bike mechanic. They should be able to do it quickly and for not massive amounts of money.
PostPosted: 21:16 - 15 Oct 2006    Post subject: Reply with quote
The helicoil kit I got was about £23, if I remember.
Just checked and mine's a M12 x 1.75. Unfortunately, this is a slightly different pitch to the SV; which is M12 x 1.5, I reckon.
There are people that will come to your house and fit a helicoil for you.
phantomtek
Lil Joe Tek
PostPosted: 21:30 - 15 Oct 2006    Post subject: Reply with quote
Well the problem with taking it to a mechanic is that there is no oil in it, I have about two 500g jars of oil left and the rest is all over the floor outside. I have a few litres at my Dads though.
How much do you reckon that those people who come to your house will cost, and is there anywhere I can contact them? I'll try Google.
The drain hole is part of the main crankcase, how much do you reckon a mechanic would charge?
Sad
mchaggis
PostPosted: 22:18 - 15 Oct 2006    Post subject: Reply with quote
Sad
Hire or acquire a van/ trailer and move it yourself to a mechanic. Alternatively, find a mechanic who will pick it up for you.
I must not be a troll...
Mmmm, Guinness
loply
PostPosted: 22:26 - 15 Oct 2006    Post subject: Reply with quote
You could apply a gasketing compound of some description to the sump plug to make it temporarily useable. I managed this using a combination of loctite and liquid gasket once, onto the oil pressure test bolt.
As I think some others have suggested too, one of those "liquid metal" type substances could possibly be used to bond an internally and externally threaded tube into the sump plug hole, and then screw a new sump plug into the aforementioned tube. This would in theory mean you could fix it without needing professional assistance.
It's a bit of a hack though, and I'm not sure how easy it would be to source an internally and externally threaded steel tube.
Yamaha SZR660 Caution to the wind, the throttle pinned!
irving
PostPosted: 22:34 - 15 Oct 2006    Post subject: Reply with quote
Question
PostPosted: 22:35 - 15 Oct 2006    Post subject: Reply with quote
You can helicoil the sump in situ, and though you should be careful to get as much swarf out of the sump as humanly possible any left behind will easily be stopped by the strainer and the oil filter, and oil passes through both of these before doing any work. The sumps on most engines carry an amount of engine debris anyway.
phantomtek
Lil Joe Tek
PostPosted: 22:45 - 15 Oct 2006    Post subject: Reply with quote
Ah christ this is a mess.
I just want to say, thank you to everyone who has/will replied so far, it makes me feel alot better knowing there are many people who want to help out.
I will probably ring some garages up tomorrow, see how much they want to charge, then probably go down there with the bike and see if they can fix it. I have someone who has kindly offered to transport it for me. The SV must hate me Sad Though I must say, it ran alot better with the new oil, for what little time it had it in.
Anyway, if this doesn't go to plan I may be back to ask for more help on how to fit a helicoil.
It's been a crap day.
Cheers Thumbs Up
extreme3d
PostPosted: 22:53 - 15 Oct 2006    Post subject: Reply with quote
Geri wrote:
You can helicoil the sump in situ, and though you should be careful to get as much swarf out of the sump as humanly possible.
A helicoil MUST be inserted bang on 90 degrees - not an easy thing to do at all in situ when you would have to work with less than 8 inches ground clearance and upsidedown, especially if you've never ever done a coil before.
Get it wrong and you won't be able to have another go - it's a do once or not at all thing.
Our advice Joe is to take it to a garage. Get them to pick it up (£50 is what most will charge for pick-up). It's false econonmy to try it yourself on something so critical. SV engines are not cheap on ebay either due to the racing series demand so get it wrong and it could prove even more costly. Get a mechanic to do it for you. You are not a mechanic and no offence, but your 'mechanical skills' got you into this situation in the first place so personally I wouldn't trust them Wink
*Edit* Whilst I was typing all that you've only gone and made a post saying you will go to a garage after all haven't you Joe Laughing
PostPosted: 23:05 - 15 Oct 2006    Post subject: Reply with quote
Were I doing it, I'd lean the bike right over so it was pretty much on it's side (old mattress maybe?)
However, I would agree - I'd get a garage to do it as you can't easily get a replacement sorted as I could do when I did my zx6 sump.
If you get a garage to do it, see if they do 'timesert' - which is a superiour version of the helicoil.
phantomtek
Lil Joe Tek
PostPosted: 23:09 - 15 Oct 2006    Post subject: Reply with quote
Nice one I'll see what I can do, Toby has told me that a nice mechanic would probably come out to my house and do it, but these days they are mainly driven by money than seeing another biker back on the road. Which is fair enough I guess, they need to make a living but hopefully I will be eating those words tomorrow.
Oh well my own stupid fault, I'll see if they can unseize my brake caliper pins whilst they are at it too Very Happy
Cheers guys.
The last post was made 19 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 138.84 Kb
