| phantomtek |
 phantomtek Lil Joe Tek
 Posted: 20:39 - 15 Oct 2006 Post subject: [HELP!] Help! Idiotic Mistake! |
Hi guys,
Well today I was going to change the oil on the SV, as it needed doing.
I went to untighten the sump plug, and in a stupid lapse of concentration I was turning the socket the wrong way, and I heard a snapping sound and the bolt started to turn freely. Then I tried the other way and the bolt came out, so I changed the oil. Then I put it back in and tightened up the bolt up (It just kept spinning, wouldn't tighten) but it looked ok so I left it.
Quick blat up the M1, and parked up. Checked under the bike, the oil is slowly dripping, checked the back tyre, yes the left side is covered in oil.
My Dad had a look and he says that I have basically fooked the thread on the sump, because the bolt is fine. My question is, what the hell should I do in this situation, and how much is it going to cost?
I'm so gutted, because it was totally stupid but there's nothing I can do about it now so I will have to forget it and try fix it.
Any ideas?
Thanks.  |
| jay_666 |
 jay_666 World Chat Champion
 Posted: 20:41 - 15 Oct 2006 Post subject: |
sounds like a new sump for you matey...
umless you can do something like get that liquid stuff and try and re-thread it i duno... ____________________ CBT - Done | Theory - Passed | Test - 4th Oct [PASSED!]
https://www.bikepics.com/members/jay666/ |
| phantomtek |
| DucatiEVO |
 DucatiEVO Could Be A Chat Bot
 Posted: 20:47 - 15 Oct 2006 Post subject: |
Don't know if it's removeable, but if you have a good look you should be able to tell.
If it's not removeable you could always try fixing it in-situ. I know a mate did the same as you on his crosser, used some of that chemical metal stuff to fill the gap, then just tapped a large M10 thread in it and stuck a bolt in.  ____________________ aKa: Ducky |
| jay_666 |
| phantomtek |
| extreme3d |
 extreme3d World Chat Champion
| Blau Zedong |
 Blau Zedong Banned
 Posted: 20:57 - 15 Oct 2006 Post subject: |
Did the same thing on my Gixxer 750 . You CAN helicoil it in situ, I think it's M12 or M14 (Get the shop where you buy the kit from to measure the plug with a thread gauge), but the helicoil kit is about £80 (cheaper than a sump though). As far as I remember there isn't any drilling, you wind a tap in then fit the helicoil, just the fact you are working upwards makes it a bit fiddly. Do not ride it "as is"..if the sump bolt falls out you will either a) fall off b) wreck your engine or c) both. PTFE tape / Threadlock are NOT suitable bodges for something this critical. When I did mine I flushed the engine with a few litres of Halfords shittest oil just to make sure there was no debris from the tapping process floating about in the engine, then did an oil and filter change as usual. Plus it also makes a stronger thread the same size as standard  ____________________ 18:54:48 Rob Fzs: jews don't give away stuff for free
18:54:59 Rob Fzs: unless its their clothes/ hair/ golden teeth
| phantomtek |
 Posted: 21:00 - 15 Oct 2006 Post subject: |
I can't ride it as is because there is no oil in it at the moment.
I simply can't afford £80, do you reckon the mechanic will charge me this much?
| G |
 G The Voice of Reason
 Posted: 21:01 - 15 Oct 2006 Post subject: |
Hmm, that's bad if it's all one piece.
Any rethreading, you'd really want to do it with the sump off, so that you don't get swarf in the engine.
Did similar on my ZX6 and got a helicoil kit to do it myself - this results in the same size thread, so you can use the original bolt.
Just looking at the SV engine that I happen to have in bits in my bedroom (the boxes of bits are my bed side table, at the mo ) - doesn't look too good I'm afraid.
Best bet is probably going to be to recut the thread (ideally using a recoil kit - or timesert is better, but a lot more £££ for the kit), then maybe flush the engine a couple of times to be sure.
Alternatively, a could do you a deal on a SV engine . |
| Blau Zedong |
 Blau Zedong Banned
 Posted: 21:04 - 15 Oct 2006 Post subject: |
I've not a clue what a mechanic would charge, plus how will you get it to him with no oil? It's possible he won't have the helicoil kit in that size on stock, so he might have to buy one anyway. Usually people carry 4 - 10mm as these are common sizes, they are only likely to have others if the've done one before for someone else. I bought the kit and used just one coil . Have to go around stripping sump plugs to get my money back lol ____________________ 18:54:48 Rob Fzs: jews don't give away stuff for free
18:54:59 Rob Fzs: unless its their clothes/ hair/ golden teeth |
| Blau Zedong |
 Blau Zedong Banned
| phantomtek |
 Posted: 21:09 - 15 Oct 2006 Post subject: |
| G wrote: | Hmm, that's bad if it's all one piece.
G, do you have any idea what size the thread is on the sump? Could you have a quick gander if it isn't too much trouble?
Just need to work out what size helicoil I'll need.
| Quote: | I bought the kit and used just one coil . Have to go around stripping sump plugs to get my money back lol |
Does this mean you have another coil left? |
| Blau Zedong |
 Blau Zedong Banned
| Kickstart |
 Kickstart The Oracle
 Posted: 21:13 - 15 Oct 2006 Post subject: |
If you search on Ebay for davethetools , he has a load of helicoil type repair kits. About £38~£58. M14 x 1.25 kit here.
However you do need to use one of these straight, and it is not a bolt that is in a good position to learn with. Also a touch critical to the bike. And the must be very sure there is no swarf left inside after doing so (and the crankcases being alloy, any swarf will be alloy and will not stick to a magnetic sump bolt).
If the drain hole is in the main crankcases then I would say take it to a local bike mechanic. They should be able to do it quickly and for not massive amounts of money.
| G |
| phantomtek |
 Posted: 21:30 - 15 Oct 2006 Post subject: |
Well the problem with taking it to a mechanic is that there is no oil in it, I have about two 500g jars of oil left and the rest is all over the floor outside. I have a few litres at my Dads though.
How much do you reckon that those people who come to your house will cost, and is there anywhere I can contact them? I'll try Google.
The drain hole is part of the main crankcase, how much do you reckon a mechanic would charge?
| mchaggis |
 mchaggis World Chat Champion
| loply |
 loply World Chat Champion
 Posted: 22:26 - 15 Oct 2006 Post subject: |
You could apply a gasketing compound of some description to the sump plug to make it temporarily useable. I managed this using a combination of loctite and liquid gasket once, onto the oil pressure test bolt.
As I think some others have suggested too, one of those "liquid metal" type substances could possibly be used to bond an internally and externally threaded tube into the sump plug hole, and then screw a new sump plug into the aforementioned tube. This would in theory mean you could fix it without needing professional assistance.
It's a bit of a hack though, and I'm not sure how easy it would be to source an internally and externally threaded steel tube. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| irving |
 irving Traffic Copper
 Posted: 22:34 - 15 Oct 2006 Post subject: |
| Pete. |
 Pete. Super Spammer
| phantomtek |
 Posted: 22:45 - 15 Oct 2006 Post subject: |
Ah christ this is a mess.
I just want to say, thank you to everyone who has/will replied so far, it makes me feel alot better knowing there are many people who want to help out.
I will probably ring some garages up tomorrow, see how much they want to charge, then probably go down there with the bike and see if they can fix it. I have someone who has kindly offered to transport it for me. The SV must hate me Though I must say, it ran alot better with the new oil, for what little time it had it in.
Anyway, if this doesn't go to plan I may be back to ask for more help on how to fit a helicoil.
It's been a crap day.
Cheers  |
| extreme3d |
| G |
| phantomtek |
The last post was made 19 years, 362 days ago. Instead of replying here, would creating a new thread be more useful? |
