Undertray modification for zzr?
bunglehaze
PostPosted: 02:32 - 17 Oct 2006    Post subject: Undertray modification for zzr? Reply with quote
Hi folks, just wondering really as I have not found much out on the net..
Is it possible to buy an underseat kit for a zzr E model that neatens the whole back end up a little? I would like to get a smaller number plate and jack up the back end a little I think but dont want the standard undertray showing.
Obviously this is a different bike but it would be nice to get something like this:
https://www.redracingparts.com/images/sottosellazx6r.jpg
Also have any of you jacked up the back end on a zzr600? I read it can make the front end feel a little more responsive and improve the general handling although I dont know just how accurate this is, I do like the idea of a slightly cocked tail though!
cheers
leigh Thumbs Up
gixxersixx
PostPosted: 08:53 - 17 Oct 2006    Post subject: Reply with quote
had a quick look around this site https://www.zzr-international.co.uk/forum/index.php they may know more
We're all just born to die. So lets have some fun
gsxr6k1,pc,k&n,skimmed block,flowed head,yoshi gasket,cams,blue print,arrow system titanium can,quick shifter,gilles rear sets,ktech forks,ohlins shock,galfer waveys, -3front+4rear + other goodies
bunglehaze
PostPosted: 15:38 - 17 Oct 2006    Post subject: Reply with quote
Thanks for the link, I will have a good look around!
Thumbs Up Thumbs Up Mr. Green
cheers
leigh Very Happy
krebsy
PostPosted: 17:54 - 18 Oct 2006    Post subject: Reply with quote
A mate at work jacked up the rear on his and he claims it made the bike far more responsive. Might give it a go at the weekend. need to stiffen up the rear anyway.
K.
1280 x 1024.
Jebus
PostPosted: 20:00 - 18 Oct 2006    Post subject: Reply with quote
by jacking up the rear you will, shorten the wheelbase and make the angles of the steering steeper, so it will turn in faster etc, but this will make it more sensitive and flighty, make it more prone 2 tank slappers etc.
2nd time around Smile CBT: 8/9/11
125 Varadero
Whosthedaddy
PostPosted: 20:16 - 18 Oct 2006    Post subject: Reply with quote
Jacking up the rear is something that I want to do in the not to distant future, dog bone extensions costing less than £20 aint to bad for a mod that can drastically change the way the bike handles.
https://www.bikefarmmv.de/EN/extreme-tail-riser/index.php
bunglehaze
PostPosted: 23:57 - 18 Oct 2006    Post subject: Reply with quote
I dont think I will mind it being a bit more flighty too much if it stiffens up the rear suspension a tad, I took my first pillion out today and it felt very soft. I too found the dogbone mod so I think I will give it a whirl shortly - by the way is it a big or involved job? I am only just getting into what everything on the bike does..
cheers
leigh Very Happy
https://bikechatter.net
Motorcycle Products Reviews and News
06 - ZZR600 > 07 - ZX6R J1 > 08 - ZX6R J2 > 09 - ZX636 A1P > 11 - ZX10R C1H
Jebus
PostPosted: 00:40 - 19 Oct 2006    Post subject: Reply with quote
it will be a bit more flighty, but it depends on how soft it 2 start with etc
125 Varadero
Whosthedaddy
PostPosted: 02:10 - 19 Oct 2006    Post subject: Reply with quote
Piece of piss Wink
The dog bones are connected to the swing arm and bottom of the shock mount by 2 bolts, simply remove these and pop in the new dog bones.
Its a 15 minute job with a spanner and socket once the rear of the bike is supported ie on a paddock stand
bunglehaze
PostPosted: 17:49 - 20 Oct 2006    Post subject: Reply with quote
Bargain!!!
I will have a whirl at that then I think...
In answer to your question too about how soft it is, IMO it is very soft - very comfortable mind but I think I need to stiffen up the front end and definately could do with a bit more bite on the back.
cheers
leigh Very Happy
Whosthedaddy
PostPosted: 17:52 - 20 Oct 2006    Post subject: Reply with quote
That website was annoying me last night so I shopped else where and bought some off of ebay for £20.
They are 157mm dog bones so should be a nice little lift Wink
bunglehaze
PostPosted: 17:57 - 20 Oct 2006    Post subject: Reply with quote
BTW does it need to be done on a paddock stand or will it work on just the centre stand? I dont have any stands yet (apparently chrimbo pressies Very Happy)
cheers
leigh Very Happy
Whosthedaddy
PostPosted: 17:59 - 20 Oct 2006    Post subject: Reply with quote
As long as the rear wheel is off of the ground, my FZR has no centre stand so it will be on axle stands, a centre stand should be just fine.
bunglehaze
PostPosted: 18:53 - 21 Oct 2006    Post subject: Reply with quote
Excellent! just the news I was hoping for - look out dogbones here I come (well providing I can get my bike started again)
cheers
leigh Very Happy
Whosthedaddy
PostPosted: 17:43 - 25 Oct 2006    Post subject: Reply with quote
The 157mm dog bone extensions (from a FZR1000) arrived and I've been itching for the last few days to fit them and see what difference it makes to the stature and feel of the bike. The latter will have to wait for a few more days yet.
https://www.bikechatforums.com/files/fzr600_079.jpg
Tools required:
Arrow 14m spanner
Arrow 5/8 spanner
Arrow Hammer
Arrow A little Duckhams grease
Arrow Locktight
Time:
Arrow 30 minutes
Level of difficulty:
Arrow Piece of piss
When ordering the new parts I was unsure on the size of the orginal FZR600 dog bones, they are 10-12mm longer, so how this will translate to the final ride height of the rear will be Thinking
BEFORE
https://www.bikechatforums.com/files/fzr600_078.jpg
The 2 retaining bolts were easily removed except for the rear hanger getting in the way a little, so this came off to make life a little less frustrating.
When both bolts are removed the rear will pivot and shift a little from the frame. You will need to press down (one handed is enough pressure) on the seat pan / rear subframe to extend this pivot allowing the new, longer bones to be lined up with the swing arm mount.
Once the bolts are both pushed through, the washers and nut are refitted with a little red Locktight to stop vibrations from loosening them too much.
AFTER
https://www.bikechatforums.com/files/fzr600_080.jpg
Jobs a good 'un Wink Thumbs Up
It really is a piss easy job to do, good luck and lets see the before and after pics to see the overall effect.
bunglehaze
PostPosted: 21:34 - 25 Oct 2006    Post subject: Reply with quote
whats the difference to the look from the side then???? Twisted Evil Twisted Evil Twisted Evil Twisted Evil Razz Razz
cheers
leigh Very Happy
Whosthedaddy
PostPosted: 21:37 - 25 Oct 2006    Post subject: Reply with quote
cheers
leigh Very Happy
Bit hard to tell at the moment Shifty
https://www.bikechatforums.com/files/fzr600_081.jpg
It should look a little more complete this weekend Wink
hmmmnz
PostPosted: 00:55 - 26 Oct 2006    Post subject: Reply with quote
is that a suzuki rear wheel?? or is the pattern the same as the older suzukis??
the humans are dead
I kick arse for the lord
Whosthedaddy
PostPosted: 10:47 - 26 Oct 2006    Post subject: Reply with quote
Would nt suprise me if there were different wheels to the bike, a few things have been this way so far Rolling Eyes Most of the older bikes have a generic looking 3 spoke wheel dont they so not really sure.
sickpup
Old Timer
PostPosted: 13:01 - 26 Oct 2006    Post subject: Reply with quote
That would be a paddock stand on the swing arm that is supported by the bones that you're taking off right? riiiiight Shocked
Whosthedaddy
PostPosted: 22:39 - 26 Oct 2006    Post subject: Reply with quote
Yep, somthing like that Very Happy
timjim
PostPosted: 23:14 - 26 Oct 2006    Post subject: removing tie rods Reply with quote
just put bike on the side stand,put a bottle jack or trolley jack under opposite side under a block of wood and jack up till wheel is off deck...mack sure to slacken all the mount bolts on the tie rods before raising the bike ..it makes it a bit safer and YES it is a 10 min job!!!!!! Laughing
bunglehaze
PostPosted: 01:13 - 27 Oct 2006    Post subject: Reply with quote
im still coming up with nothing regarding the tail section/undertray...
I have seen others where people have replaced the subframe with a different model but this is a little too extreme for my skill level at this time, any simple bolt/screw on sports tails I could look at or tails of other similar bikes? if so which ones?
cheers
leigh Very Happy
Whosthedaddy
PostPosted: 10:03 - 27 Oct 2006    Post subject: Reply with quote
cheers
leigh Very Happy
You can fit alternative bike rear plastics onto the existing frame or change the rear section completely and start from scratch.
The common one for the FZR is an R1 or R6 tail, the only thing is that you have to mod the tank and fairings too, so a little involved, but looks the nuts.
Have a look for a ZX7R or ZX9R, they may have units that you may be able to use, or look at track day rear units. With these you will have to drill and cut for the brake lights.
It looks like www.1tail.com may do a ZX6R unit to fit a ZZR Thinking
Something that I failed to realise, so was a little shocked when the front and rear pivoted against each other as I was nt expecting it to move as much as it did Shocked
bunglehaze
PostPosted: 18:30 - 27 Oct 2006    Post subject: Reply with quote
so far so good, I have chopped off the rear mudguard which looked pants and am in the process of finding a smaller number plate that I can fabricate a mount for - out of interest what sizes are all your plates? I am assuming very few of you run the full size standard plates..
I need to know what I could possibly get away with.
cheers
leigh Very Happy
The last post was made 19 years, 364 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 140.47 Kb
