Ignition cutting out
steve133
PostPosted: 08:12 - 18 Oct 2006    Post subject: Ignition cutting out Reply with quote
Hi,
I have a 1991 zzr 250 that initially blew a headlamp, when i changed it turned ignition on to check it was ok, and as soon as i flicked the headlight switch on all power on the bike (ignition, lights, etc.) cut out. After finding a short in rear taillights, power was back on, jumped on to start it, ran for about 5 seconds and all power cut out again. Any ideas would be appreciated.
finpos
PostPosted: 11:08 - 18 Oct 2006    Post subject: Reply with quote
Check the fuse would be the obvious answer. The fuse is deliberately located as near to the battery as possible so that any shorts on the bike (e.g. in the taillight) will be of the fused supply. So it's possible that if your short didn't actually blow the fuse, it made it very tired indeed.
finpos.
gixxersixx
PostPosted: 11:46 - 18 Oct 2006    Post subject: Reply with quote
as above, check your battery connections, but if theres nothing obvious get your reg rectifier and charging system checked out, had similar problems on an old gs suzuki when the reg rectifier went. The bike would run if the battery was fully charged but when it started to drain it would cut out.
We're all just born to die. So lets have some fun
gsxr6k1,pc,k&n,skimmed block,flowed head,yoshi gasket,cams,blue print,arrow system titanium can,quick shifter,gilles rear sets,ktech forks,ohlins shock,galfer waveys, -3front+4rear + other goodies
steve133
PostPosted: 02:46 - 19 Oct 2006    Post subject: Reply with quote
thanks to both of you for your quick replies, i got it working!!
I changed the fuses for the sake of it, just in case, then a mate suggested i clean the ignition switch with contact cleaner. Did it this morning, started straight away after that. I am still a bit suspect of it though so i will check the regulator anyway. Thanks again, at least it is working for now.
finpos
PostPosted: 10:21 - 19 Oct 2006    Post subject: Reply with quote
I reckon that's a good call by your mate - an intermittent connection in there would go a long way towards explaining all the problems you've had.
finpos.
The last post was made 19 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 42.41 Kb
