| shot2bits |
 shot2bits Two Stroke Sniffer
 Posted: 16:22 - 18 Oct 2006 Post subject: Track day tyre pressures...? |
Apologies as no doubt this has been covered off a few times...
I'm still really confused as to what pressures I should run this Saturday at Snetterton. The stock pressures are 42 rear and 36 front...
Reading Ride mag, they suggested dropping by no more than 4PSI front and rear but some sites have suggested running 30PSI front and rear! Should't the pressure drops stay in relation - maintain higher pressure in the rear than the front rather than setting them both to the same PSI?
Any thoughts on what I should set them to...? Its a little cooler this time of year so track temp will be lower...
The tyres are Pilot 2CT's on a K6 GSXR 1000.
Yours confused, ____________________ GSX-R 1000 | SCENIC 1.6  |
| Davo |
 Davo Davo To The Rescue!
 Posted: 16:28 - 18 Oct 2006 Post subject: |
I usually try and drop the pressures down to around 30 psi on both front & rear.
There will normally be a guy at the track who can give you good advice on what pressure to run the tyres.
Have fun!  |
| Bendy |
 Bendy Mrs Sensible
| shot2bits |
| Bendy |
 Bendy Mrs Sensible
| shot2bits |
| Zimbo |
 Zimbo World Chat Champion
| sub4sec |
 sub4sec Two Stroke Sniffer
The last post was made 20 years, 5 days ago. Instead of replying here, would creating a new thread be more useful? |
