| Jack_Cheese |
 Jack_Cheese World Chat Champion
 Posted: 19:30 - 18 Oct 2006 Post subject: Sliding the rear... |
Correct me if i'm wrong, but isn't this the proper/fastest way to corner? The number of bikes i see with blue, shredded rear tyres and absolutely huge front chicken strips seems to confirm this.
Whenever i feel it happen, it makes me really really nervous. I can't keep it sliding, and immediately pull the rear back into line. Any advice on how to keep the rear sliding through the corner properly? I seem to be a little bit nervous after binning it a few months back.
Jack ____________________ www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!" |
| mr.z |
 mr.z World Chat Champion
 Posted: 19:35 - 18 Oct 2006 Post subject: |
"backing it in"? probably for the track, imo most track tecniques aren't practical for real world rideing (unless you have a supermoto) and much more likely instead to come a cropper on gravvel, cowshit/oil/diesel/vomit on the roads.
Being smooth and observeing stuff waaay ahead is the better way to "make good progress" propperly trained bike copper will usually be faster than somebody doing a rossi impression, and they'll probably end the journey on their bike not in an ambulance. ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| Jack_Cheese |
 Posted: 19:47 - 18 Oct 2006 Post subject: |
It's not so much backing it in, as the rear wheel is totally in line approaching, and entering the corner, and i was under the impression that backing it in was effectively powersliding into the corner.
What i was referring to is just when the rear starts to slide, mid - corner. Not a big twitch, but a slight, progressive slide. It feels half natural, half totally shit-my-pants scary.
| Blau Zedong |
 Blau Zedong Banned
| G |
 G The Voice of Reason
 Posted: 19:55 - 18 Oct 2006 Post subject: Re: Sliding the rear... |
| Jack_Cheese wrote: | Correct me if i'm wrong, but isn't this the proper/fastest way to corner? The number of bikes i see with blue, shredded rear tyres and absolutely huge front chicken strips seems to confirm this.
Jack |
No, it is most definitely not.
Even in top class road racing (moto gp etc) only a handfull manage to do it usefully.
You can get used to doing it on the road, but I most definitely wouldn't reccomend doing it while 'pushing it'.
Are you sure you haven't seen people that have done trackdays, or more likely, bought race rubber off others for the more disposable rear tyre?
From my racing, even when I've been pretty much on the limit of traction and keeping up mid corner with the top people, I've still often got chicken strips left on the front, on the left at least. Why? Because I hang off.
Anyway, sliding the bike - going into a corner, on a bike with reasonable engine braking:
Knock it down a gear just as you are turning in. This should get it sliding a bit, now use the rear brake to keep it sliding, otherwise the wheel speed will catch up with the road speed.
When doing this, always, always keep covering the clutch incase it all starts to go wrong.
(pic of me playing with the above technique a month ago)
Coming out of a corner...
Definitely do not attempt this - likely to end in pain in a lot of cases!
Get on the power more, in a very, very controlled fashion!
You need to be /just/ past the limit of traction.
This sort of thing is much easier to play with off road on an off road bike.
On the really muddy field I was at last friday it was just a case of leaning the bike over in first and opening it up for a nice controlled tight 180 degree powerslide..
| TL666 |
 TL666 Trackday Trickster
| G |
| Wooly R6 |
 Wooly R6 World Chat Champion
| Jack_Cheese |
 Posted: 21:35 - 18 Oct 2006 Post subject: |
Humm, i'll check the rear tyre pressure then. I suppose it may be due to low pressure, but it doesn't feel as soggy as when the pressure is low, it still feels full of feedback, like i know exactly where the rear is planted.
I've noticed that it mainly happens on a roundabout just round the corner from work meaning the tyres are still cold. That probably doesn't help...
As for technique, i don't lean off as much as i should. I aggrovated my knee injury on sunday when i went up to rivvy, not a nice feeling at all and the first time i've aggrovated it, so i've been avoiding leaning off quite a bit.
And as for suspension, i've heard the sachs rear shock on my bike is hardly the creme de la creme of suspension technology.
Ah well, i should hopefully be getting fully adjustable forks in the next few months, at least that should allow me a little fiddle. My forks have a heavier fork oil in than standard, as the dive under braking was pretty bad. Riding my bike was like consuming a large quantity of alcohol and marijuana, then playing rodeo on a rocking horse.
| Ferret |
 Ferret Derestricted Danger
| Jack_Cheese |
 Posted: 21:42 - 18 Oct 2006 Post subject: |
Michelin pilot powers (single compound version), and no i don't think i'm getting enough heat in 'em. (see previous post) ____________________ www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
| G |
| Jack_Cheese |
 Posted: 21:46 - 18 Oct 2006 Post subject: |
| GearboxGeezer |
 GearboxGeezer World Chat Champion
| G |
| Jack_Cheese |
 Posted: 21:50 - 18 Oct 2006 Post subject: |
Yeah. I couldn't actually increase the rear preload either, because the preload adjuster is surrounded by airbox. The ride was... erm... interesting... ____________________ www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
| Method |
 Method World Chat Champion
 Posted: 22:05 - 18 Oct 2006 Post subject: |
You wanna back it in properly?
Check my avatar. ____________________ CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado
My Bikepics.com - No Brakes, No Gears... No Fear. |
| Jack_Cheese |
| steveh |
 steveh World Chat Champion
 Posted: 22:12 - 18 Oct 2006 Post subject: |
i did it on friday the 13th, was great, came right out HUGEE skid mark all the way round the corner, near full lock on the bars, great rush.........
until....
https://img92.imageshack.us/img92/6541/photo0008cn9.th.jpg
 ____________________ Current : 06 Zx10r, 07 Wr450f SM, 74 850 norton commando, 63 bsa b40, 1962 Triton 650, 67 Triumph Tr6r, 1955 Triton 750, 1978 TY250E. |
| quik_d |
 quik_d Could Be A Chat Bot
 Posted: 23:31 - 18 Oct 2006 Post subject: |
....and the only undamaged bit...... The R & G crash Bungs
____________________ LOOK AT DAT M8 WELL LUSH A PARROT INT IT |
The last post was made 19 years, 151 days ago. Instead of replying here, would creating a new thread be more useful? |
