| Skunkcap Freddie |
 Skunkcap Freddie Brolly Dolly
 Posted: 19:23 - 19 Oct 2006 Post subject: Wheel bearing problems |
had to replace the wheel bearings just over 3 weeks ago as the others which had about 4k on them, one had seized up, anyway i got new bearings 14quid for 2 ,i got them directly from a bearings place. so i get them fitted bike feels great from then until now. then this morning i was on my way to work going around a bend and noticed that the front was a bit shakey so i took it easy to work on the way home i noticed it again. so i got my bro to have a listen and help me check the bearings in the headstock were fine which they are . thing is i havn't been wheeling or going fast over speed bumps/humps (take your pick) since i got them replaced and havn't done very many miles.
has this happened to anyone else ? i'm a bit fucked off they've gone this quick. any ideas if it could be somthing else causing it ? ____________________ Northern Irish Biker? www.nibikers.com |
| Jebus |
 Jebus Brolly Dolly
 Posted: 19:44 - 19 Oct 2006 Post subject: |
as long as they are well greased and preloaded then they should be fine, anyway this should be in the workshop section really. they wont of gone off that fast and 4k seems low miliage for them as well. ____________________ 2nd time around CBT: 8/9/11
125 Varadero |
| Cillit-BANG |
 Cillit-BANG World Chat Champion
| irving |
 irving Traffic Copper
 Posted: 20:10 - 19 Oct 2006 Post subject: |
| Skunkcap Freddie |
 Posted: 20:15 - 19 Oct 2006 Post subject: |
thanks folks, the last time the bearings were done . a aprilia dealer did them. and charged me a fortune. i took the bearings out and replaced them the same way i took it apart.
will look into it . and check my work shop manual. many thanks ____________________ Northern Irish Biker? www.nibikers.com |
| Skunkcap Freddie |
 Posted: 20:20 - 19 Oct 2006 Post subject: |
i packed the wheel full of grease aswell ____________________ Northern Irish Biker? www.nibikers.com |
| irving |
 Posted: 20:27 - 19 Oct 2006 Post subject: |
| irving |
 Posted: 20:31 - 19 Oct 2006 Post subject: |
| sickpup |
 sickpup Old Timer
| irving |
 Posted: 20:39 - 19 Oct 2006 Post subject: |
| Jebus |
 Jebus Brolly Dolly
 Posted: 20:47 - 19 Oct 2006 Post subject: |
i guess that preload is the wrong word, i mean they were adjusted correctly, i just go by setting them 2 a certain torque setting is preloading them, at least to some sort of degree. ____________________ 2nd time around CBT: 8/9/11
125 Varadero |
| Kickstart |
 Kickstart The Oracle
| Skunkcap Freddie |
 Posted: 20:56 - 19 Oct 2006 Post subject: |
i put a fair bit of grease in , but loads came out when the spacer went back in and other bearing on.
will check it when i get the new bearings ____________________ Northern Irish Biker? www.nibikers.com |
| irving |
 Posted: 21:04 - 19 Oct 2006 Post subject: |
| Kickstart |
| irving |
 Posted: 21:26 - 19 Oct 2006 Post subject: |
| Skunkcap Freddie |
 Posted: 21:30 - 19 Oct 2006 Post subject: |
nah. the spacer is there alright. i'll be having a good look at it when i'm changin the bearings.
again folks, many thanks for the help ____________________ Northern Irish Biker? www.nibikers.com |
| sickpup |
 sickpup Old Timer
The last post was made 19 years, 160 days ago. Instead of replying here, would creating a new thread be more useful? |
