What the hell just happened?! Help ASAP!
5v3d3b0
PostPosted: 22:16 - 19 Oct 2006    Post subject: What the hell just happened?! Help ASAP! Reply with quote
So I was going around on the Yamaha TZR 50 that I've been talking about, cause I took it to some mechanics who fixed it, and it's great.
Suddenly the bike stopped, as if I'd ran out of petrol. I know I have the entire reserve left, so I was like WTF... I push started it, and it worked. Went about 100m, and it stopped again. After a couple of repetitions I put it on the sidewalk, and push started again. When I have it in gear, with the clutch fully in, its perfect for about 5 seconds. Then the revs suddenly increase to about 6000/min, and go back down slowly, and the bike just stops... Ever heard of anything like it?
finpos
PostPosted: 22:20 - 19 Oct 2006    Post subject: Reply with quote
Yes, that sounds EXACTLY like it's running out of petrol. I think by moving the bike you're sloshing enough petrol into the carb to make it run for a few seconds more.
It's possible that with the tap on reserve, it's not actually allowing any fuel though, or the bit of petrol you have left is below the reserve outlet.
finpos.
irving
PostPosted: 22:21 - 19 Oct 2006    Post subject: Reply with quote
Arrow
5v3d3b0
PostPosted: 22:27 - 19 Oct 2006    Post subject: Reply with quote
I'll get someone to bring me a litre or so of petrol tomorrow, and if it doesnt work, ill give a shout. Thanks
5v3d3b0
PostPosted: 23:10 - 19 Oct 2006    Post subject: Reply with quote
Why would it accelerate though?
PostPosted: 23:26 - 19 Oct 2006    Post subject: Reply with quote
Rising-revs is a sign of mixture leaning-off. I reckon the reserve outlet in your petrol tap is blocked.
5v3d3b0
PostPosted: 23:36 - 19 Oct 2006    Post subject: Reply with quote
If that is the case, how would I unblock it? Do I have to take the petrol tank off?
PostPosted: 00:16 - 20 Oct 2006    Post subject: Reply with quote
Depends what is blocked. The suggestion of a blocked breather is a good one, although that would affect it whether it was on reserve or not.
Reserve just works by taking fuel from a lower point in the fuel tank. Also any rubbish in the tank will sink to the bottom, as will any water that gets into the tank. When you switch onto reserve any of this can get sucked into the carb. Also if rubbish is in the bottom of the tank then it will block the pickup for reserve.
PostPosted: 00:19 - 20 Oct 2006    Post subject: Reply with quote
A blocked breather might become more apparent as the weight of the fuel in the tank is reduced. Could be a blocked breather as it's only usually older tanks that get clogged-up reserve outlets.
finpos
PostPosted: 10:49 - 20 Oct 2006    Post subject: Reply with quote
All great suggestions on the thread, but first, just put some more petrol in Smile. Sometimes you'll find you can hear petrol sloshing around when it's on reserve, but there's just not enough to reach the reserve outlet. Common case is where the tank is 'bent' over the top frame tube and there's petrol in the right hand side and non in the left, where the outlet is. Lean your bike over, hey presto it works again.
finpos.
Finglonga
PostPosted: 13:05 - 20 Oct 2006    Post subject: Reply with quote
If putting fuel in you still get the same proplem....Next time is cuts out open the tank up straight away, if it hisses you have a blocked breather. Wink
Andy Sez....
F.Y.Y.F.F.
5v3d3b0
PostPosted: 19:06 - 21 Oct 2006    Post subject: Reply with quote
It was just the petrol missing. Thanks anyway guys. Got a lil worried
Odie
PostPosted: 03:09 - 22 Oct 2006    Post subject: Reply with quote
It helps if you have petrol!
I suggest that you put both fingers in your ears, turn around and say "RED" back-wards.
The last post was made 19 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.48 Sec - Server Load: 2.47 - MySQL Queries: 13 - Page Size: 76.66 Kb
