Camera help
Syx
PostPosted: 01:39 - 20 Oct 2006    Post subject: Camera help Reply with quote
I've been lurking for a while but decided it was time to make an account once I needed some help! Razz
Anyways straight to the point:
I basically want to get a bullet camera (link) and fit it to a digital video recorder (link). I also want to power both devices from my bike battery.
Now as the voltage isn't going to be all that steady and I don't want to wreck the camera/recorder, I'll be fitting a voltage regulator in between. I also need a potential divider to step down the voltage before it gets to the recorder as it only takes a 5v input.
Here's a diagram:
https://img286.imageshack.us/img286/3003/camerasetuptz8.png
Now, where I need the help:
Firstly is there anything obviously wrong with this? I've never done anything similar so any advice will be more than welcome.
Second, I'll be building the divider myself, and I'm a little confused as to where I connect the 0v rail to - the negative terminal of the battery would be the obvious choice - is this correct?
Any input is much appreciated, so thanks Smile
hmmmnz
PostPosted: 02:59 - 20 Oct 2006    Post subject: Reply with quote
hey there you don't need a regulator,
the bikes battery is smooth enough,
the bullet camera is 12v and the video recorder you are looking at has a 12v to 5v transformer(for running in a car which can easily be made to fit onto the bike). all you have to do is hook up both to the battery(via an inline fuse)
heres a wee pic
https://img120.imageshack.us/img120/3029/camgd8.jpg
the humans are dead
I kick arse for the lord
Syx
PostPosted: 03:25 - 20 Oct 2006    Post subject: Reply with quote
Thanks for your help! The in-line fuse was a bit of a no-brainer, as I'd rather replace that than a few hundred quid's worth of kit!
Regarding the 12v to 5v transformer... whereabouts did you see that it 'has' one? And how would I go about fitting it to the bike? Obviously I haven't seen one so I don't even know what you mean - the only thing that springs to mind is the kind of thing you stick in a cigarette lighter.
PostPosted: 07:13 - 20 Oct 2006    Post subject: Reply with quote
What about this?
https://www.trackdays.co.uk/Track-Cam.htm
PostPosted: 09:01 - 20 Oct 2006    Post subject: Reply with quote
The bullet camera I have is meant to be fairly free with the voltage it takes. From memory they claim it will easily take 8V to 15V. Worth checking with the supplier of your bullet camera.
Syx
PostPosted: 12:27 - 20 Oct 2006    Post subject: Reply with quote
Geri wrote:
Looks interesting... I'll look into it!
@Kickstart - Thanks for the input, I'll check with my supplier and see what they say.
Anyone have anything to say regarding my second post?
DynaMight
PostPosted: 12:36 - 20 Oct 2006    Post subject: Reply with quote
Geri wrote:
I was tempted at those but I saw them on ebay, £115 inc P+P with 1GB card, cant find the UK link now but found a US one who will del to the UK: https://cgi.ebay.co.uk/WIRELESS-BULLET-HELMET-CAM-CAMERA-1GB-SANDISK-ULTRA-II_W0QQitemZ230040980155QQihZ013QQcategoryZ48514QQssPageNameZWD2VQQrdZ1QQcmdZViewItem
Or heres a UK one if it goes cheap enough: https://cgi.ebay.co.uk/Bullet-Cam-Oregon-Scientific-ATC-1000_W0QQitemZ160041422678QQihZ006QQcategoryZ96999QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
1GB SD cards will be about £10-15 max.
Syx
PostPosted: 13:04 - 20 Oct 2006    Post subject: Reply with quote
Only 15fps though, not ideal but good for the price.
hmmmnz
PostPosted: 13:11 - 20 Oct 2006    Post subject: Reply with quote
when i was searching through reveiws looking for the voltage of it one said it came with one but it doesn't look like it when i just did a quick search
https://www.nextag.com/Archos-Cigarette-Lighter-Adaptor-61038522/prices-html
is what i thought it came with
this one is probly better
https://www.thetoolboxshop.com/sess/utn;jsessionid=154538afd16a454/shopdata/?main_url=go.shopscript%3Fa%3D0-578-90
just cut the wires both sides and your away laughing
or 1 from maplan for a tenner
https://www.maplin.co.uk/Module.aspx?TabID=1&ModuleNo=48574&doy=20m10
im sure if you do a bit of searching you can get one cheaper
the humans are dead
Syx
PostPosted: 13:25 - 20 Oct 2006    Post subject: Reply with quote
Yep, those are the things I thought you meant. According to a retailer the included AC/DC adapter has a 5v/2A output. Now whilst I can easily use the 4.5V as that will be fine, how well would it cope with a 1.5A input?
Cheers for your help, guys.
PostPosted: 14:31 - 20 Oct 2006    Post subject: Reply with quote
15fps output doesn't look good for bike stuff.
I've had problems using a bullet cam attached to a bike battery in the past.
hmmmnz
PostPosted: 15:49 - 20 Oct 2006    Post subject: Reply with quote
it doesn't matter about the input as long as the output of the unit can handle it .
oh yeah? why what happened, are you better using the supplied battery pack??
the humans are dead
Syx
PostPosted: 16:07 - 20 Oct 2006    Post subject: Reply with quote
I actually meant the recorder, but to be honest 2A going into that sort of device sounds a little high.
As regards the battery, I could quite easily stick a voltage regulator in as they only cost about a quid.
biketeacherda...
PostPosted: 19:41 - 20 Oct 2006    Post subject: DO A SEARCH THIS HAS BEEN DONE TO DEATH Reply with quote
And any way you can buy everything you need from www.maplins.co.uk for not a lot of dosh
www.dgridertraining.co.uk
Syx
PostPosted: 14:06 - 21 Oct 2006    Post subject: Re: DO A SEARCH THIS HAS BEEN DONE TO DEATH Reply with quote
Thanks, I actually went into their Birmingham shop today and bought a few bits and pieces - the most important thing being a multimeter as I wanted to check the battery voltage. I did actually do a search, but none of the other topics really covered what I wanted to know.
I now see why G might have had problems - the battery voltage ranges from 8V to 14V - 8V when you hit the ignition and 14V once the alternator kicks in. There's only actually 12V across the terminals when the bike is idling, and that's not when you want your camera on!
As such I'm going to make a regulator to keep it at 12V, but I just thought I'd share with you guys in case anyone else decided to fit a camera with low voltage tolerances... beware!
biketeacherda...
PostPosted: 22:49 - 21 Oct 2006    Post subject: ok i have this set up already Reply with quote
you do not need to make a regulator maplins sells one already you can select the vlotage output you want from it by simply adjusting the switch to your needs, mine has several out puts on it
1. buy the lead which goes straight to the battery and give you the ciggi lighter socket on the other end
2. plug in the voltage regulator adaptor they sell and select the output you want
3. connect camera and other stuff
look here
https://www.maplin.co.uk/Module.aspx?ModuleNo=42895&&source=14&doy=21m10
and here
https://www.maplin.co.uk/Module.aspx?TabID=1&DOY=21m10&ModuleNo=37423&criteria=
hope this helps
Syx
PostPosted: 00:04 - 22 Oct 2006    Post subject: Reply with quote
Thanks for the help dave - I'm going to give the regulator a shot for two reasons:
1) I can make the entire contraption small, space is a concern for me as I've already got an Autocom system under the seat, and
2) I love tinkering with electronics!
However as it will inevitably result in either mild electrocution or burnt-out components (likely both) I'll pick up a converter on Monday. Thanks! Very Happy
KevTM
PostPosted: 17:44 - 22 Oct 2006    Post subject: Reply with quote
just watch out with the hard drive digital recorders as from experience with my Archos Av420 it can feck up and not record due to data getting corrupted by vibrations/bumps mostly.. i've bought a new harddrive (40gb) for it which has shock protection etc and should be better than the crappy one installed in the machine, haven't tried it on the bike yet though..
one with a memory card may be better, if possible.
Syx
PostPosted: 18:17 - 22 Oct 2006    Post subject: Reply with quote
Unfortunately I don't think I can really cope with just a memory card, especially as the cards themselves aren't cheap!
Thanks for the heads-up on the vibration issue though, it's something I hadn't thought of. I'll see what I can do about housing the device in a foam surround.
Hopefully I'll get under way with some of the electronics next week, and I'll be sure to let you all know how it goes!
KevTM
PostPosted: 18:23 - 22 Oct 2006    Post subject: Reply with quote
aye hope it works mate, i tried various surrounds for mine, foam, towels, everything from under the seat, on a tank bag, on my person etc.. worked best inmy jacket pocket mind you so if you've any bother try that first Thumbs Up
Syx
PostPosted: 18:27 - 22 Oct 2006    Post subject: Reply with quote
Thanks for the tips mate Thumbs Up
The last post was made 19 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 116.03 Kb
