| binge |
 binge Emo Kiddy
| binge |
 binge Emo Kiddy
| The Tot |
 The Tot World Chat Champion
| binge |
 binge Emo Kiddy
| baldy |
 baldy World Chat Champion
| binge |
 binge Emo Kiddy
| bikedudextrm |
 bikedudextrm Traffic Copper
| bikedudextrm |
| binge |
 binge Emo Kiddy
There is a gap of 2 years, 61 days between these two posts... |
| darren1990 |
 darren1990 L Plate Warrior
 Posted: 01:36 - 20 Oct 2006 Post subject: |
i have a gilera ice same engine and the black pipe is going to the air box and i dont know what it does to speed when taken out but is really load when taken out i have bout a zx pipe of ebay for £20 the bike does 42mph i will let use know what it does when i get my pipe tommorow  ____________________ gilera ice 2001 standard 43mph lol |
| befdelta7 |
 befdelta7 Brolly Dolly
 Posted: 02:16 - 20 Oct 2006 Post subject: |
when fitting a sports pipe to the bike remove the old cat exhaust and block up the existing small black pipe you mentioned that goes to the black box, that will be fine. you could screw a bolt into the pipe to block it or put something else in there to block it (make sure it wont come out obviously ), remove the variator "washer", take out the brass plate with holes in it (should be at the mouth of the carburetor) and up-jet your carb, put some performance rollers in the variator between 5g to 8g (malossi one are good) its up to you to decide what weight rollers to use that suit you and the bike best... heavier rollers equal poor acceleration, but good top-speed -- lighter rollers equal fast acceleration poor top-speed be carefull not to go too light as your engine will over rev causing your clutch to overheat and fail and your engines reliability to decrease very fast. a malossi kevlar drive belt is worth getting as this is stronger that the standard and as your be "tuning" your bike you'll need a strong reliable drive belt to get the power to the rear wheel.
some other things you could do are fit:
. 70cc cylinder kit
. carbon reed petals -- bigger reed block
. malossi delta clutch and malossi springs
. variator kit
. lighter fly wheel
. race clutch bell
. malossi torque driver spring
. bigger carburetor (19mm-21mm 50cc -- 25mm-28mm 70cc)
. race inlet manifold
. malossi full circle race crank shaft
. malossi high compression head
.........ETC
IF YOU GOING TO TUNE AND INCREASE YOUR SCOOTERS SPEED, ITS A GOOD IDEA TOO UP RATE YOUR BRAKING SYSTEM.
REMEMBER.... THE FASTER YOU RIDE THE HARDER YOU BRAKE!! ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine. |
| irving |
 irving Traffic Copper
 Posted: 09:14 - 20 Oct 2006 Post subject: |
| lee8040 |
 lee8040 Nearly there...
| irving |
 Posted: 13:03 - 20 Oct 2006 Post subject: |
| irving |
 Posted: 13:07 - 20 Oct 2006 Post subject: |
| Finglonga |
 Finglonga World Chat Champion
The last post was made 19 years, 345 days ago. Instead of replying here, would creating a new thread be more useful? |
