Bike not starting/no lights/possibly ignition - help reqd!!
bunglehaze
PostPosted: 16:34 - 21 Oct 2006    Post subject: Bike not starting/no lights/possibly ignition - help reqd!! Reply with quote
Hi folks,
I have taken off my tank and airbox for the first time today to have a little look underneath and assess what I will need to service on the bike. I started it up with the airbox off and cleand the airfilter - so far so good everything works just fine!
Anyhoo, I have then put the bike back together and it wont start, in fact where everything was working just fine previously, firing up first time etc and the dash lights coming on I am getting nothing. Even when I arm my alarm usually I turn the key in the ignition and it sets off - not any more...
I tried to bump it off down the street and got nothing, usually it bumps off in 2rd pretty quickly but no such luck today. The battery is new (been on 2 weeks) and had a decent charge in it from yesterdays ride so I doubt it is that causing my problem.
Any of you able to offer and good advice here to fault fixing this?
Failing that, if any of you are in hillsborough, Sheffield and dont mind helping a new biker all help is appreciated
regards
leigh Very Happy
https://bikechatter.net
Motorcycle Products Reviews and News
06 - ZZR600 > 07 - ZX6R J1 > 08 - ZX6R J2 > 09 - ZX636 A1P > 11 - ZX10R C1H
Paddy Blake
PostPosted: 16:44 - 21 Oct 2006    Post subject: Reply with quote
It must be a blown fuse.What bike is it.
bunglehaze
PostPosted: 16:57 - 21 Oct 2006    Post subject: Reply with quote
zzr 600 e1 I have checked the junction box and all the fuses are ok there (then again there were only lights fuses)
if there are others to check it would be great to know where
cheers
leigh Very Happy
Paddy Blake
PostPosted: 17:50 - 21 Oct 2006    Post subject: Reply with quote
I,m not sure on your bike but will try to get the manual.
Paddy.
bunglehaze
PostPosted: 17:54 - 21 Oct 2006    Post subject: Reply with quote
Thanks Paddy, I have just been out to try it again, usually if it was a battery problem there would at least be a few seconds of lighting on the dash and headlights but it appears to have no effect turning the ignition. As I said previously the alarm is not even triggered (as if the ignition is not actually being turned to the start position)
I currently have the bike in bits out the back and would love to get it working again for tonight.
cheers
leigh Very Happy
Paddy Blake
PostPosted: 18:01 - 21 Oct 2006    Post subject: Reply with quote
I,m trying to download this at the momant but it may Take a while.
https://www.blackbears.ru/manual/files/Kawasaki_ZZR600_Service_Repair_Manual.zip
Paddy.
bunglehaze
PostPosted: 18:19 - 21 Oct 2006    Post subject: Reply with quote
Paddy, it wont work m8. I tried it a few times with no luck.
I have the workshop manual here, it was uploaded for me on BCF here:
https://www.megaupload.com/?d=6CEUIF67
cheers
leigh Very Happy
Resurrection
Ballast Boy
PostPosted: 19:34 - 21 Oct 2006    Post subject: Reply with quote
Could you have a bad earth or a knackered solanoid?
Res
ZX9r
PostPosted: 19:42 - 21 Oct 2006    Post subject: Reply with quote
There is a main fuse in the starter relay. 30A I think. Follow the +'ve lead from the battery and it is the first thing that the lead goes to.
bunglehaze
PostPosted: 19:52 - 21 Oct 2006    Post subject: Reply with quote
Folks, I have checked the main fuse which is intact and fine, I am just wondering where the solenoid may cause an issue with the electrics such as lights rather than actually starting the bike?? For now I am trying to diagnose why turning the ignition does nothing electrically (not even triggers my alarm which it normally would).
If after this stage it does not start I will diagnose that but with a brand new battery with full charge and having had the bike running not 1 hour before I am thinking the problem is happening BEFORE I am even getting to the starting system. I may be wrong though but logic tells me the problem is occuring within the ignition barrel or between that and the connection to the lights.
cheers
leigh Very Happy
irving
PostPosted: 20:00 - 21 Oct 2006    Post subject: Reply with quote
Arrow
irving
PostPosted: 20:07 - 21 Oct 2006    Post subject: Reply with quote
Arrow
PostPosted: 20:13 - 21 Oct 2006    Post subject: Reply with quote
On Hondas the starter relay definatly can cause problems, and looking at the ZZR manual all the ciruits use power that has gone through the relay.
Batteries rarely go pop suddenly.
bunglehaze
PostPosted: 20:14 - 21 Oct 2006    Post subject: Reply with quote
There is literally nothing else I have undone while taking off the airfilter, i have not undone any electrical connections (although since taking it apart again I have checked all of the connectors nearby to make sure I have not dislodged anything.
So far all I have done today is retrace what I have done and consult my workshop manual to no avail which is why I am looking to you guys for advice.
Added** The only think electrical I have fiddled with is I tightened up the negative connector on the battery as it was a little loose and I have spreayed WD40 into the ht leadswhen I popped them off to check the depth the spark plugs are at ( i only did this on 2 and 3 though s I didnt want to undo anything else)
cheers
leigh Very Happy
PostPosted: 20:18 - 21 Oct 2006    Post subject: Reply with quote
Have you got a multimeter?
If so check the voltage over the battery. Check for a voltage going to the starter relay. Check for a voltage coming out of the relay (not the chunky wire to the starter motor, just the small wire, white I think).
bunglehaze
PostPosted: 20:24 - 21 Oct 2006    Post subject: Reply with quote
Thanks keith I will give it a whirl tomorrow (weather just turned bad here) when its dry or at least light! Thumbs Up
cheers
leigh Very Happy
bunglehaze
PostPosted: 19:32 - 22 Oct 2006    Post subject: Reply with quote
Hi folks, thanks for all the help but it is now fixed. It turned out to be a corroded wire in the connector block. It has now been stripped off and attached and works fine again - simple fix eh after all that trauma!
cheers
leigh Very Happy
The last post was made 19 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 97.22 Kb
