Great, now I don't know what speed i'm doing...
Mozzer
PostPosted: 14:22 - 23 Oct 2006    Post subject: Great, now I don't know what speed i'm doing... Reply with quote
Nice little suprise for me...
The speedo on my RS125 is cable driven, there is a small metal clip which slides into the front wheel and spins with it.
The clip itself has snapped (I'll either need to get hold of one or fabricate one, but i'm not really any good at things like that... but whats worse is that the part of the wheel it fits into has worn... the sides of the "hole" it fits into have been shaven away, effectively allowing the speedo clip thingymabob to just pass through it, instead of sitting inside.
I'll get some pictures if it's a bad explanation.
So, how could I fix this? Weld some walls back in there?
1st: June 6th 2006 - Nov 6th 2006: 2001 Aprilia RS125 |2nd: Nov 12th 2006 - Present: 1991 Honda CBR400RR
Jamie Stokes wrote: it now has a memory of 512mb and is super fast
Mozzer
PostPosted: 14:47 - 23 Oct 2006    Post subject: Reply with quote
Not cheap!
Feck.
I'd rather try a couple of bodges first...
T1z3R
PostPosted: 14:51 - 23 Oct 2006    Post subject: Reply with quote
get bodging.
put some pics up as well cos i dont quite get what you mean.
duck my sick!
Rookie
PostPosted: 15:29 - 23 Oct 2006    Post subject: Reply with quote
Could always just leave it be, depends if you plan to sell it on at a decent price. If not, use a bicycle speedo temporarily until a wheel comes up on the cheap.
alien.46.uk
PostPosted: 15:51 - 23 Oct 2006    Post subject: Reply with quote
Hay, mines driven the same, but my wheel has those small notches all the way round for the blade to fit into off the speedo drive.
Ive attached the front wheel assay, its number 28 and fits into the notches in the part to the right of 24 ...
There should be more thn=an one notch ...
If not, just bodge it, there's plenty of possibilities ...
Luke.
2007 Kawasaki ZX10R :: 1998 Kawasaki ZX-9R - SOLD
1998 Yamaha FZS600 Fazer - SOLD :: 1994 Aprilia Pegaso 125 - SOLD
Graham88
PostPosted: 16:24 - 23 Oct 2006    Post subject: Reply with quote
I haven't been able to tell me speed since I've owned the bike. Speedo has never worked.
Doesn't bother me TBH.
PostPosted: 19:34 - 23 Oct 2006    Post subject: Reply with quote
Are you sure the "part of the wheel it fits into" is actually part of the wheel and not a seperate bit that could be drifted out and replaced?
Mozzer
PostPosted: 21:15 - 23 Oct 2006    Post subject: Reply with quote
Well, just went out and got some pictures, and also checked to see wether Stinkwheel's thought might be a possibility but on closer inspection it's not happening.
So, with these, what do you reckon my first port of call should be?
PostPosted: 21:37 - 23 Oct 2006    Post subject: Reply with quote
In all honesty. That looks like a case of near terminal neglect. Speedo drives are supposed to be oiled/greased once in a while you know.
I can't see the exact damage but it looks like you are missing some bits of the actual wheel hub casting (broken/.corroded off).
Now, the bits of the wheel that have worn/corroded away aren't structural (the wheel sits on the bearings). I reckon BLUEX5s suggestion is favourite, build up the missing bit with chemical metal. The speedo drive doesn't see a lot of force (you can easily spin it with your finger) so it should hold.
I would recommend using a product called "JB Weld". It's probably the best one on the market.
If you are a bit more technically minded, you could build it up with a product called 'lumiweld' which is a low melting point, aluminium solder then shape it to suit using a burr. This would be tricky
hmmmnz
PostPosted: 22:23 - 23 Oct 2006    Post subject: Reply with quote
why don't you just buy a new speedo drive and cable
https://www.apriliayorkshire.co.uk/catalogue/partlist.jsp?Catalogo=%3D340X&Tavola=%3D27&_NomeImmagine=82070224.gif&_bikename=RS%20125%201999-2005&_pagename=Front%20wheel
its a seperate unit and not part of the wheel???
the humans are dead
I kick arse for the lord
alien.46.uk
PostPosted: 22:33 - 23 Oct 2006    Post subject: Reply with quote
Its the hole in the Wheel that's also broken hmmmnz ...
A new drive unit is needed me thinks, but the hole for the stud to sit on the wheel had also corroded.
But a bit of Chem. Metal stuff ... should be a good enough bodge ...
Luke.
hmmmnz
PostPosted: 23:14 - 23 Oct 2006    Post subject: Reply with quote
oooh damn. chemicle stuff it is then Very Happy must be a sign that you should be selling it on Very Happy
good luck
the humans are dead
Gazdaman
I did a trackday!!!
PostPosted: 14:26 - 26 Oct 2006    Post subject: Reply with quote
Meh, I have a chemical metal'd on engine mount.
Gaz
Mozzer
PostPosted: 10:56 - 31 Oct 2006    Post subject: Reply with quote
Okay, i've chemical metald the whole thing together....
Because the actual pin that sits inside snapped I was simply left with a vertical stub that just sits parallel with the wheel... I chemed the whole thing to the hole and covered it so it's one big piece.
It worked this morning, speedo working again fine... I just can't help but think it's only going to last a day or so.
Gazdaman
I did a trackday!!!
PostPosted: 01:06 - 01 Nov 2006    Post subject: Reply with quote
You underestimate the hard-core-ness of chemical metal.
Gaz
The last post was made 19 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 96.64 Kb
