Has my NS125 barrel been lined?
Dilusi
PostPosted: 11:45 - 23 Oct 2006    Post subject: Has my NS125 barrel been lined? Reply with quote
Hi,
I've just bought a NS125 (1987) and started to strip it down. The engine needs a rebuild as the previous owner melted the piston.
When I took the barrel of to inspect the damage I noticed it seems to have a steel liner in it. Someone on another forum said that the barrel is standard and needs plating and cannot be rebored but I'm not convinced.
I thought the plated barrels were solid alloy without a liner?
Can someone who knows have a look at the pics of the barrel and tell me for definite?
https://www.byphotos.com/album/4133986
disco_stu
PostPosted: 12:34 - 23 Oct 2006    Post subject: Reply with quote
Looking at your photo's I say that yes your barrell is a cast iron lined one. You can see the different materials by the different colour and also the join line.
A nonliner or plated barrell would have the same aluminium colur right to the bore edge or the start of the plating.
Having a liner means your barrell can be rebored to the next bigger piston size if need be and if oversize pistons are available for it.
Have a reputable machine shop measure it up for you. If there is not any damage from the piston meltdown or too much wear, you may get away with having it honed and a new piston and rings of the same size.
cheers
Dilusi
PostPosted: 14:03 - 23 Oct 2006    Post subject: Reply with quote
^^Thanks.
also, you can't really see it in the pics but the ports on the barrel do not line up perfectly with some of the ports on the liner meaning there is a bit of a lip in places. Would this affect the running/performance at all?
I'm going to take it to a specialist and let them have a look but any other advise in the mean time would be appreciated.
joe black
PostPosted: 15:20 - 23 Oct 2006    Post subject: Reply with quote
send you r barrel to langcourts weston-s-mare ,they are the experts used them numerous time excellent firm to deal with
Dilusi
PostPosted: 16:20 - 23 Oct 2006    Post subject: Reply with quote
^^I really want to find somewhere local if poss (Stourbridge, West mids) so I can just drop it of and collect it.
Anyone able to recommend someone in that area?
PostPosted: 21:35 - 23 Oct 2006    Post subject: Reply with quote
Stock NS125 barrel is plated but that one looks like a liner has been bodged in.
Closest place to you is probably PJ Engineering in Wolverhampton.
plugger147
PostPosted: 23:16 - 23 Oct 2006    Post subject: Reply with quote
Just took a peak at the one I have in the shed and the one on my bike (yes it is in bits. Crying or Very sad )the one on my bike is original the others had a liner bodged in and looks just like yours. Kickstarts right ( theres a surprise Laughing )the standard one is plated and can't be rebored
Tristan the wrote: just whipped off my trousers to find a big bruise on my arse, caused by matt rear ending me...
alains
PostPosted: 23:35 - 23 Oct 2006    Post subject: Reply with quote
you should buy a barrel-piston kit , but i do not know if they are still avaiable . phone at DSS 01728833020
Dilusi
PostPosted: 09:50 - 24 Oct 2006    Post subject: Reply with quote
You wouldn't recommend getting mine honed/rebored then?
alains
PostPosted: 10:26 - 24 Oct 2006    Post subject: Reply with quote
exactly , it seems in very bad condition for a re-plating , better to buy a kit or change bike
Dilusi
PostPosted: 11:27 - 24 Oct 2006    Post subject: Reply with quote
I wasn't going to get it replated because of the steel liner, I was hoping just to get it rebored for now as the bike needs more things replacing than I anticipated.
I've seen athena replacement barrels (standard) for just under £100 then another £20 for a piston kit but I thought I could save a few quid if I could get away with a rebore.
alains
PostPosted: 11:38 - 24 Oct 2006    Post subject: Reply with quote
i do not recommand big bore on this bike , like the NSR125R the max size admissible for the bottom-end is 150cc , otherwise you will change your engine very shortly
Dilusi
PostPosted: 11:52 - 24 Oct 2006    Post subject: Reply with quote
The Athena barrel I've been looking at is standard 124cc
https://www.ve-uk.com/demo/index.php?search_group=41&search_lists=7&search_make=28&search_model=278
alains
PostPosted: 12:22 - 24 Oct 2006    Post subject: Reply with quote
so better fitting the genuine !
Dilusi
PostPosted: 21:42 - 24 Oct 2006    Post subject: Reply with quote
Do you think it would be ok to get mine rebored rather than buy a new barrel?
Its going to cost enough to rebuild the bottom end and the rest of the bike at the moment. As long as a rebore will last for a few 1000 miles I don't mind replacing the top end again at a later date.
PostPosted: 22:28 - 24 Oct 2006    Post subject: Reply with quote
I am not keen on the idea of putting cast iron liners into engines designed to be plated, you can probably get away with boring it out and fitting a new piston. A rebore will not be expensive, but not sure how easy it will be to source an oversize piston (certainly not from Honda).
Dilusi
PostPosted: 18:59 - 25 Oct 2006    Post subject: Reply with quote
Thanks, I've seen a few places that sell oversized pistons so I'm gonna take it somewhere and get it rebored for now.
Grubby
PostPosted: 19:51 - 25 Oct 2006    Post subject: Reply with quote
You can get a 150cc kit for them no worries. This is a standard size for the bike in Thailand & they run them with no bottom end problems at all.
I am me & you are he & we are all together. See how they run like pigs from a gun!
Dilusi
PostPosted: 19:54 - 25 Oct 2006    Post subject: Reply with quote
I've only seen 190cc kits, any ideas where I'd get a 150?
The last post was made 19 years, 338 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 101.23 Kb
