| Brick_Top |
 Brick_Top Spanner Monkey
| Pete. |
 Pete. Super Spammer
| Itchy |
 Itchy Super Spammer
 Posted: 14:39 - 24 Oct 2006 Post subject: |
if you are even more lazy you can get a lorry come up to your door with premix and just dig the hole and wheel barrow it infor you about £200 last time but then I was laying a gigantic house foundation. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| extreme3d |
 extreme3d World Chat Champion
| mr jamez |
 mr jamez World Chat Champion
| puremagic72 |
 puremagic72 Brolly Dolly
 Posted: 20:43 - 24 Oct 2006 Post subject: |
Or you could put cellotape round the anchor?
Baz.  ____________________ Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids. |
| Cillit-BANG |
 Cillit-BANG World Chat Champion
 Posted: 22:19 - 24 Oct 2006 Post subject: |
As mentioned before, don't go mental with the spade action. There are often utility supplies (water, gas, electricity, phone line sewerage etc) that run underground at the front of your property.
9 times out of 10 your fine, but if you take your time you'll spot anything untoward before it gets serious.
B&Q or Wickes sell the post-fix bags. I would buy 2 of these (£3-4 each) and use as instructed. You usually pour half a bag in, water, wait, add rest of bag, wait. All done in a couple of mins and will be hard overnight, but full strength usually takes a few days.
It will also help if you have a length of 2"x2" to tamper (whack!) the mixture to ensure it has settled all around the anchor properly. |
| Cillit-BANG |
| muddycoffee |
 muddycoffee Nitrous Nuisance
 Posted: 21:42 - 25 Oct 2006 Post subject: |
I have concreted a couple of ground anchors in in the last couple of years.
1) don't dig an enormous hole, as you will need about 7 bags of stuff to fill it, and that is a lot of work.
2) have an old pole and some bricks to hand, then you can hold the anchor through the chain eye, and keep it in the exact perfect position while the concrete goes off.
3) If you find some old metal shelf brackets, scaffolding pole, or dexion shelving to bash deep into the ground radially deep down so your concrete binds them in, then your anchor will be impossible to lever out without a 10 ton crane.
4) have some half house bricks to hand and if you are running out of concrete mix, you can push some in to raise the level of your wet mix. Builders call this using plums!
I used bags of ballast and cement which I mixed with a shovel, about 4 to 1 ballast to cement. But fence post suff should be just as good. Although I would use more than one bag, probably 2 or 3. ____________________ Suzuki SV650 naked Blue curvy with Givi Screen and G force can. |
| thx1138 |
 thx1138 World Chat Champion
| muddycoffee |
| muddycoffee |
| muddycoffee |
| Itchy |
 Itchy Super Spammer
| muddycoffee |
| virus |
 virus World Chat Champion
| muddycoffee |
| virus |
 Posted: 18:07 - 26 Oct 2006 Post subject: |
ok, cheers, ill get one as soon as i can afford it  ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| Walloper |
 Walloper Super Spammer
 Posted: 23:55 - 29 Oct 2006 Post subject: |
Remember to wrap a rag soaked in grease around the anchor.
That way whenever you move house it's just a deft flick of the wrist and hey presto you have your anchor for the new house.
And since you've already fitted one. It will be a piss case to put that in.
Warning:
Be carefull if you're moving to a flat though.
You will need planning permission.
 ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| virus |
 Posted: 11:34 - 30 Oct 2006 Post subject: |
why make it easier to get out?
that defies the whole point of a gound anchor.. you may aswell tie your bike up with string instead of chains  ____________________ own: 81 xs1100g...
| Walloper |
| krebsy |
 krebsy World Chat Champion
 Posted: 18:25 - 30 Oct 2006 Post subject: Heavy duty Drilling... |
After 4 hours of solid drilling with an 850W 110V industrial drill I managed to drill ONE 90mm deep, 16mm wide hole into the poured concrete and stone floor of my Garage.
Here's the hole (and the bolt on the left), the pair of drills (my own 500 W and the big hire drill and the anchor (ready to go in).
It took far too long to drill as the floor seems to be made out of Basalt rather than concrete . Actually it was a poured concrete/crushed brick/sand mix and I ended up having to use one of the 16mm masonry bits as an impromptu chisel. Basicly I shoved it into the hole and smacked it as hard as possible with a steel mallet (thanks be to the kind neighbours ) until sparks flew to break up the REALLY tough stuff I seemed to hit at about 70mm down.
I got the thing in and set it into the hole using the extracted dust and a bit of water as a mortar mix. Ok, it's only in by one of the 4 bolts but it'll be impossible to drill another hole without a motorised chisel and a whopping big drill to tidy the hole up.
To summise, Don't drill into a solid floor when you have the option of pouring concrete instead and setting the anchor in whilst wet.
K. ____________________ What's my New Year's resolution?
1280 x 1024. |
| Walloper |
 Posted: 18:34 - 30 Oct 2006 Post subject: |
Did you have that 850 m/c set on Hammer?
It should have went through that like hot pish through packed snow.
Was it a borrowed m/c?
Maybe the percussion mechanism is gubbed.
But what a nice hole you got boy.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| virus |
| loply |
 loply World Chat Champion
The last post was made 19 years, 156 days ago. Instead of replying here, would creating a new thread be more useful? |
