Cracked fairings :-(
Claud 14.7 to 1
PostPosted: 22:59 - 18 Jun 2004    Post subject: Cracked fairings :-( Reply with quote
Ive noticed a crack in my fairings, its out of the way, but i dont want it splitting any more.
Whats the best way to mend it? What to use?
Which side can/do i repair it from. inner (engine side) or exterior side? Mending it from the outside would certainly be alot easier, as its in a trickey position.
Its out of the way, and wont need painting afterwards, as it really cant be noticed.
Any other tips. Thanks people!
tatters
Exxon Valdez
PostPosted: 23:35 - 18 Jun 2004    Post subject: Reply with quote
slap a big sticker or decal on it Laughing
yohomiesmelly...
PostPosted: 00:23 - 19 Jun 2004    Post subject: Reply with quote
if you want to go all the way you can plastic weld it on the inside and use p38 on the outside and then sand it down and touch up the area
dont know if that helps
Claud 14.7 to 1
PostPosted: 00:29 - 19 Jun 2004    Post subject: Reply with quote
Tell me about plastic weld...
Would superglue be ok? or araldite?
deputy
PostPosted: 10:57 - 19 Jun 2004    Post subject: Cracked fairing Reply with quote
Read a report in a bike mag recently ( can't remember which one ), they reckoned that superglue was good but the best results they got were by using a soldering iron on the back of the fairing to "spot weld" the crack to hold it together then run the soldering iron down the crack to weld it together. If there is no damage to the outside you probably won't notice the crack, otherwise plastic padding and a touch-up/respray.
deputy
PostPosted: 14:28 - 21 Jun 2004    Post subject: Cracked fairing Reply with quote
Found the article, was Bike magazine July edition page 153. Have copied as an attachment.
Claud 14.7 to 1
PostPosted: 15:01 - 21 Jun 2004    Post subject: Reply with quote
Thanks Dep!
I bough some Araldite, so i think ill use that on the back of the fairing piece becasue it really strong.
Then ill use superglue on the front on the piece becasue its more precision, and ill get a better finish...
Thanks!
badlydamaged
PostPosted: 15:03 - 21 Jun 2004    Post subject: Reply with quote
Nice one deputy! Im sure a few people will find that usefull (I know I will, Ive got a crack running down one of my side panels).
Cheers, Jonathan
My bike: 1988 Kawasaki KH100 Status: Polluting Devon with two stroke smog and noise pollution!
"Its not your engine size that matters!, It's what you do with it that counts" Very Happy
Add me to MSN if you want! [email protected].
mr.z
PostPosted: 18:02 - 21 Jun 2004    Post subject: Reply with quote
Also if your useing the soldering iron method (they are only like £5 anyways) cable ties can be melted on allong the join Thumbs Up
coolfox1
PostPosted: 18:20 - 21 Jun 2004    Post subject: fixing Reply with quote
found builders sylicone is quite good very strong but also stays a little flexible may stop it cracking again with vibrations etc.
Screwfix direct do it for 2or 3 pounds
yz450
PostPosted: 13:37 - 22 Jun 2004    Post subject: Reply with quote
I have found that a gas powered iron with a heat blower tip,an old knife and a normal soldering iron is great for fixing panels.
Do as the others have said, i.e spot weld in place, run the iron along the crack, then get the gas powered iron with a heat blower tip and start to melt bits of plastic and push them into the grove you made with the normal iron with the old knife
feel the power!!!!
fuzz
PostPosted: 19:37 - 22 Jun 2004    Post subject: Reply with quote
Any tips on filling in missing parts of the fairing? How can I get a section that's had a scrape looking new?
coolfox1
PostPosted: 19:44 - 22 Jun 2004    Post subject: Reply with quote
Think thats going a bit far to fix ! ebay job Laughing
yz450
PostPosted: 16:23 - 23 Jun 2004    Post subject: Reply with quote
perhaps cutting a piece of plastic as close as possible to the hole and try to weld it in with an iron. if you get it tight enough you should make a decent job of it!! try it if you mess it up you can do what coolfox said and get another off ebay!
feel the power!!!!
fuzz
PostPosted: 18:13 - 24 Jun 2004    Post subject: Reply with quote
Isn't there something like polyfiller that would work for fairings? I don't mean actual polyfiller but something that does the same job for plastics/fibreglass.
mr jamez
PostPosted: 18:24 - 24 Jun 2004    Post subject: Reply with quote
You can get fibre glass filler and webbing for cracks and scratches, but this is more about cheap fixes without messing about Razz
deputy
PostPosted: 00:35 - 12 Jul 2004    Post subject: Reply with quote
I am posting this to get it to the front for shroom7
There is a gap of 2 years, 111 days between these two posts...
bunglehaze
PostPosted: 15:27 - 31 Oct 2006    Post subject: Reply with quote
OOPS, posted in wrong thread - dumbass....
this is not actually a crack or chip that can be fixed with silicone or bunging up, its actually on the top edge next to the screen (in fact a bit of the screen came off with it too) so its a bit of a wierd bit to patch..
I think on other scratches on the bike I will use the sticker idea though Very Happy Now I will have a look for a set of random pairs of stickers Very Happy
cheers
leigh Very Happy
https://bikechatter.net
Motorcycle Products Reviews and News
06 - ZZR600 > 07 - ZX6R J1 > 08 - ZX6R J2 > 09 - ZX636 A1P > 11 - ZX10R C1H
bunglehaze
PostPosted: 15:29 - 31 Oct 2006    Post subject: Reply with quote
Also to add, I keep seeing them on ebay but so far have not found the correct colour paint (teal) I think eventually I will replace it anyhow though
cheers
leigh Very Happy
Marci
PostPosted: 16:21 - 01 Nov 2006    Post subject: Reply with quote
Plastex... https://www.plastexexpress.co.uk/
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
DynaMight
PostPosted: 18:56 - 01 Nov 2006    Post subject: Reply with quote
I generally use araldite if it's a quick bodge, I use a dremal to make little v shape grooves down the crack line, then use the dremal again to remove paint and generally rough up the surrounding area then fill with araldite.
I've used the soldering iron method before but make sure you remove paint from the area first else it'll get stick in the repair and cause air bubbles etc
The last post was made 19 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 108.59 Kb
