tools
Itchy
PostPosted: 21:53 - 31 Oct 2006    Post subject: tools Reply with quote
whats the difference between normal sockets and impact drivers/wrenches? ,
I hear that impact wrenches are better for buggered bolts and my NTV is covered with them. but don't know why and or how they work.
any thoughts?
Ta
trafficdodger
PostPosted: 21:57 - 31 Oct 2006    Post subject: Reply with quote
I was under the impression that impact sockets were just made of stronger metal than a normal socket because they are normally used on the air gun they use in the garage to remove wheel nuts.
Nige
Present bike Yamaha R6
feef
Energiser Bunny
PostPosted: 22:03 - 31 Oct 2006    Post subject: Reply with quote
an Impact driver is a special tool that uses the sudden shock of a hammer blow to twist the socket, and hopefully the seized nut.
Because of the nature of some air-tools, it's not uncommon to find impact sockets used there too.
Impact sockets tend to be made of a harder material than regular sockets, but harder doesn't always mean stronger. They can transmit shock loads more effectively than a chrome-vanadium tool, but if you were to stick a breaker bar, and swing on it to tighten something, you could crack it..
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
Walloper
PostPosted: 22:22 - 31 Oct 2006    Post subject: Reply with quote
Impact tools:
'Stronger' = Less Brittle and Heavier/Thicker most commonly only six side insted of twelve so the loads are spread over more of the tool.
Hard Means Brittle Like Glass in material talk FYI Karma
feef
Energiser Bunny
PostPosted: 22:28 - 31 Oct 2006    Post subject: Reply with quote
Walloper wrote:
Impact tools:
hardness and strength are usually inversely proportional.
Impact tools require a greater proportion of hardness than their stronger, but more maleable 'regular' counterparts, so that they can transmit shock loads without deformation.
impact bits are by no means 'brittle' but they will be 'more brittle' than a socket designed for prolonged loading, requiring strength, rather than shock loading, but be able to transmit the load as efficiently as possible.
a
The last post was made 20 years, 1 day ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 46.95 Kb
