| mrbluesbox |
 mrbluesbox Scooby Slapper
 Posted: 12:27 - 01 Nov 2006 Post subject: Really Tight Axle Bolt |
Hi all
gonna be chaging my rear sprocket this weekend for the first time, but i got a bit of a problem. The rear axle bolt is really tight.
I already tried to get the axle bolt off but couldnt manage to get it off with an adjustable spanner literally putting all my body weight behind it.
Will it be ok to cover it in WD40 / penetrating oil type stuff to help get if off (worried about getting it back on and jeeping it tight enough).
Also any other tips about how to get it off would be welcome.
Lastly when its done back up (i aint got a torque wrench yet ) does it need to be this tight as i figure its gonna be a bit of a problem with the tools i got.
Cheers.
Gaz. ____________________ I seem to have misplaced my pants................... |
| T1z3R |
 T1z3R World Chat Champion
| irving |
 irving Traffic Copper
 Posted: 12:40 - 01 Nov 2006 Post subject: |
| Walloper |
 Walloper Super Spammer
 Posted: 12:45 - 01 Nov 2006 Post subject: |
AS ABOVE..
Some sprockets require NEW HARDWARE in refitting.
I never had any problems using a skoot of threadlock on good originals.
Make sure you clean off ALL mating surfaces and the nut/bolt threads.
Shit between the bolted together parts will eventually squash out and the bits will then be slack. EVEN IF YOU USED A PROPER TORQUE WRENCH and shit.
Buy a big box of Waterproof 'Bandaid' too while you're at it.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| loply |
 loply World Chat Champion
 Posted: 19:19 - 01 Nov 2006 Post subject: |
I agree with above that an adjustable spanner is asking for trouble. They're nigh on useless for high torque applications.
With a ring spanner or a socket wrench (preferably a long one) you'll crack it off on no time at all.
Go to halfords and buy a "breaker bar" which is basically a metal bar about 2 ft long with a socket holder on the end, and then put a socket on it. If you can't undo a rear axle with a two foot breaker bar, go to the gym! ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| Walloper |
 Posted: 00:22 - 02 Nov 2006 Post subject: |
I have a mate who did up a GSXR750 spindle with a long 36mm ring spanner and a club-hammer. I had to cut the nut in half with a hacksaw and fit a new spindle. He had ripped all the threads out because he was worried he might not have done it up tight enough. ____________________ a.k.a 'Geri'
| mrbluesbox |
 Posted: 10:39 - 02 Nov 2006 Post subject: |
Cheers - gonna go to halford and get one of those big bar things and a propper size socket for it - that should to the trick. But had a more major problem that i gotta sort first thats made the bike undrivable - but thats in another thread.
Not having the best of luck at the moment  ____________________ I seem to have misplaced my pants................... |
The last post was made 19 years, 360 days ago. Instead of replying here, would creating a new thread be more useful? |
