do you know how a datatool alarm works
ronnieringdin...
PostPosted: 19:11 - 05 Nov 2006    Post subject: do you know how a datatool alarm works Reply with quote
is there anybody out there that knows what sequence of button presses that will unarm the bike so it can be moved and worked on
the alarm is a datatool the fob has number 433 if this means anythin
thanx very much ronnie
sickpup
Old Timer
PostPosted: 19:17 - 05 Nov 2006    Post subject: Reply with quote
Go to www.datatool.co.uk and read the manual.
Zimbo
PostPosted: 21:01 - 05 Nov 2006    Post subject: Reply with quote
Usually you turn the ignition on, then press the arm / disarm (circle) button for about five seconds until the system chirps. The unit is now in service mode, and will chirp once every 30 seconds or so, but the alarm and immobiliser functions are disabled.
smpayne321
PostPosted: 00:34 - 07 Nov 2006    Post subject: Reply with quote
Just to add to what Zimbo said above, if you're only needing to move the bike about you can just press the triangle button. That disables the movement sensor but leaves it immobilised. Don't switch the ignition on though, the alarm will go off.
Its not ideal for all jobs, but it means you can do things like was your bike or check the chain without the bike chirping all the time and pissing you off.
ronnieringdin...
PostPosted: 08:37 - 07 Nov 2006    Post subject: cheers Reply with quote
thanx chaps the mist has cleared
The last post was made 19 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 43.12 Kb
