front brake master cylinder
hmmmnz
PostPosted: 20:03 - 09 Nov 2006    Post subject: front brake master cylinder Reply with quote
well, ive always had this with this master cylinder on the bike,
i have to pull the lever in about a cm before at starts moving the fluids and starts slowing me down. there is nothing at all in the way of resistance in that first bit.
it doesnt leak, it doesnt have air in the lines, its got braided lines.
is some sort of seal gone in the master cylinder??
the humans are dead
I kick arse for the lord
finpos
PostPosted: 20:18 - 09 Nov 2006    Post subject: Reply with quote
It's possible the problem is at the other end - the caliper pistons are getting knocked back slightly (warped disks, loose calipers, busted wheel bearing...) in between your attempts to brake. Then, every time you pull the lever, the first bit of movement is undoing the knock-back.
That's easy to diagnose - try repeatedly pulling the brake without actually riding the bike anywhere,
Another possibility is if you have slightly over-eager caliper piston seals which are pulling the piston back too far when you let off the brake. Again, when you pull the brake lever, the first bit of movement is overcoming this.
finpos.
hmmmnz
PostPosted: 22:16 - 09 Nov 2006    Post subject: Reply with quote
just had a test, it does the same thing wether the bike is moving or not, and did it even when i was bleeding the brake system.
i watched the calipers when i was pulling the lever in. it doent move the caliper until there is the fluid resistance, its like there is a complete dead spot before the brake reaches the piston and presses it in.
im miffed.
the humans are dead
PostPosted: 23:12 - 09 Nov 2006    Post subject: Reply with quote
Try wrapping some cloth around the top banjo bolt, pull the brake lever hard and keep it that way while you crack the banjo bolt off and tighten it again. Gets rid of any air bubbles stuck at the top of the system.
Big Pete
PostPosted: 11:43 - 10 Nov 2006    Post subject: Reply with quote
with that little slack it could just be the MC dust cap being compressed before you get to the piston itself. It could also be that the pivot pin or the hole in the lever is worn.
Trust me, I`m an engineer
GarageOfPower.co.uk
hmmmnz
PostPosted: 12:42 - 10 Nov 2006    Post subject: Reply with quote
right cheers ill try that Very Happy Thumbs Up cheers guys
the humans are dead
The last post was made 19 years, 238 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 49.53 Kb
