fJR Broken gearbox... [update 18-12-06]
feef
Energiser Bunny
PostPosted: 20:09 - 12 Nov 2006    Post subject: fJR Broken gearbox... [update 18-12-06] Reply with quote
Riding home today, I noticed a couple of occasions where it felt like the gearbox was jumping out of gear, but it didnt change the gear it was in.
In accelerating out of a roundabout, and changing up the box, I hear a scrunching noise, like a false neutral, and lost all drive. At the same time, the gear selector went all flappy.
Got the bike home after running back and forth from home to Milton Keynes (only about 30 miles), to get my car and trailer.
Anyone know what the situation is with the warranty on a bike that's 3 years and 2 weeks old? or have I now got an expensive paper weight?
I suspect the selector mechanism has sheared somewhere inside.
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
PostPosted: 20:30 - 12 Nov 2006    Post subject: Reply with quote
How long was the warrenty on it? Has it been dealer serviced from new? If it is a 3 year warrenty and has been serviced by a Yamaha dealer then Yamaha might come to an arrangement.
feef
Energiser Bunny
PostPosted: 20:35 - 12 Nov 2006    Post subject: Reply with quote
got a full service history from new, but I'm not sure what the warranty is. I need to check that.
Even if the warranty is less than 3 years, I'd make a call on 'fit for purpose' if their gearboxes are suffering "serious mechanical failures" within such a short space of time.
a
Paddy Blake
PostPosted: 20:37 - 12 Nov 2006    Post subject: Reply with quote
It sounds like it might be just a spring.
PostPosted: 20:38 - 12 Nov 2006    Post subject: Reply with quote
Doubt you would get anywhere at all on that. Outside warrenty pretty much leaves you at the mercy of their feelings.
Guy at work had major hassle with a Peugeot his sister had where the gearbox went pop at 15 months old. Peugeot would have nothing to do with it. He compared that to his Lexus where the ignition switch wore out (well outside warrenty, well over 100k), and Lexus replaced it for free as it should not have worn out.
sickpup
Old Timer
PostPosted: 23:48 - 12 Nov 2006    Post subject: Reply with quote
As the man says if it went all flappy it sounds like a spring. Would be worth having a look at the selector mechanism by the clutch drum.
<edit>and drop the sump and have a looksie<edit>
feef
Energiser Bunny
PostPosted: 11:16 - 13 Nov 2006    Post subject: Reply with quote
had a look at the FJR service manual, and I suspect it could be the
shift-shaft pawl or stopper leaver that has failed.. or even the entire
end of the shift-shaft mechanism that has come adrift.
Luckily, I can check that by draining the oil, taking a couple of engine
covers off, and removing the clutch..
the service manual does mention checking the pawl, return spring and
other bits in there, for wear, and to replace if required.. it's as good
a place as any to start I spose.
if it's the shift-drum mechanism, or anything deeper, it involves dropping the engine out, and dropping the crankcase off the bottom of the engine, which includes taking the heads and barrels off Neutral
I hope it's the shift shaft and pawl :S
a
feef
Energiser Bunny
PostPosted: 22:29 - 13 Nov 2006    Post subject: Reply with quote
taking the clutch out of the FJR presented me with this:
https://www.kickingtyres.com/pics/fjr/DSCF0460.sized.jpg
I thought "yay" only a spring has come adrift..
unfortunately not.
The end has sheared/fractured off the selector drum
this...
https://www.kickingtyres.com/pics/fjr/DSCF0465.sized.jpg
https://www.kickingtyres.com/pics/fjr/DSCF0466.sized.jpg
is supposed to go on the end of there...
https://www.kickingtyres.com/pics/fjr/DSCF0463.sized.jpg
The end of the selector drum is welded onto the shaft, and the weld has failed. Looks like a shear/fracture. Despite the shaft sitting a good 10mm inside the selector star it's only the very end of the shaft that has weld on it.
I'm going to consult the service manual, but I suspect this is rather major Sad
a
Paddy Blake
PostPosted: 23:07 - 13 Nov 2006    Post subject: Reply with quote
Is the middle of the drum treaded because i dont think the part should be
welded on
Paddy.
feef
Energiser Bunny
PostPosted: 23:12 - 13 Nov 2006    Post subject: Reply with quote
welded on
no.. it needs to be in a specific location, as this is what decides what gear you're in, or neutral.
If it was bolted onto the shaft, there would need to be a key or other method of locating it to ensure it was in the right rotational position.
I'm going to drop the sump out, and check it out.
a
sickpup
Old Timer
PostPosted: 23:26 - 13 Nov 2006    Post subject: Reply with quote
So the fault is in the first area I say check and I get no karma! Not that I'm bitter mind.
Engine out, flip over, sump off, crankcase off.
feef
Energiser Bunny
PostPosted: 23:28 - 13 Nov 2006    Post subject: Reply with quote
no no.. read the post again..
I THOUGHT it was the spring.. it wasn't.. it was that the end has sheared off the selector drum :p
a
Paddy Blake
PostPosted: 23:45 - 13 Nov 2006    Post subject: Reply with quote
I dont have a manual but you might be able to take of a plate at the bottom
of the engine for access to the gearbox,If so then you need to take out the
shaft that the selectors go on then take out the selectors and pull out the
drum.
Paddy.
sickpup
Old Timer
PostPosted: 23:47 - 13 Nov 2006    Post subject: Reply with quote
a
Read my post again. The first place to look is by the clutch, I was in the right area.
feef
Energiser Bunny
the sump's coming off anyway, as I've not idea what bits have fallen down there as part of the fracture.. once it's off I'll see if I can get the selectors out....
a
feef
Energiser Bunny
PostPosted: 23:48 - 13 Nov 2006    Post subject: Reply with quote
a
since almost all of the gearbox is accessed via the clutch, it'd be hard to be wrong :p
a
sickpup
Old Timer
PostPosted: 23:50 - 13 Nov 2006    Post subject: Reply with quote
That would be all the gearbox except the gears, shafts and selector. Just the pawl on the end. Laughing
feef
Energiser Bunny
PostPosted: 23:52 - 13 Nov 2006    Post subject: Reply with quote
the selector is accessed from behind the clutch too..
anyway.. I'm less than a happy bunny tonight.. working at 3:30am for some system updates.. and the bike's fscked..
I'm going to hit the sack and try it again tomorrow,.
a
Paddy Blake
PostPosted: 01:40 - 14 Nov 2006    Post subject: Reply with quote
a
Still we put on the right place to look.Or is that not true.You need to read
what people write as this may help.Not giving out just trying to help.
How many springs are to do with the gear box and where are they.
Paddy.
sickpup
Old Timer
PostPosted: 02:16 - 14 Nov 2006    Post subject: Reply with quote
Feef doesn't like us anymore Paddy. Time for some more Guinness.
feef
Energiser Bunny
PostPosted: 04:56 - 14 Nov 2006    Post subject: Reply with quote
Paddy.
ether are 3 springs in that location.. none of them have anything to do with the failure.. one spring was disconnected because of the weld failure. It was an effect, not a cause.
I appreciate the comments, but didn't actually tell me anything that wasn't plainly visible on section 5-57 of the service manual Very Happy
a
woodyfjr
PostPosted: 12:49 - 14 Nov 2006    Post subject: Reply with quote
Bloody hell that a pain how many mile on the motor?
Anyway the shift drum assembly looks like it's fitted in from the side, know I dont know if its possible to jiggle it out as the selectors sit in the grooves. When reassembling fit the bearing last to give a bit more movement.
Look at page 5-110.
If is doesnt work it looks like a motor out to me.
Good luck
If you don't pay your exorcist you can get repossessed.
If you have to rev it! Don't Buy it!
feef
Energiser Bunny
PostPosted: 12:51 - 14 Nov 2006    Post subject: Reply with quote
Good luck
55k on the clock.. just over 3 yrs old. yamaha list service intervals on the FJR up to 500,000km and I don't see any mention of checking the end of the selector drum, so can only assume it's not supposed to do that Wink
I'm going to drop the sump off, and see if I can get into the selector mechanism from below.. otherwise, yes.. engine out
a
woodyfjr
PostPosted: 12:57 - 14 Nov 2006    Post subject: Reply with quote
The selectors are at the back and at the top of the motor so it would be hard.
If you want to get your hand in, the main shaft (clutch & gears) comes out from the side just may have enough room to get the drum refitted.
Page 5-110
feef
Energiser Bunny
PostPosted: 13:01 - 14 Nov 2006    Post subject: Reply with quote
Page 5-110
Yup.. That's what I intend doing.
handy thing that manual Very Happy
I've got wee hands.. that should help.
need to get the rest of the bodywork, rad and exhaust off to get in there tho Neutral
a
The last post was made 19 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 144.82 Kb
