| feef |
 feef Energiser Bunny
 Posted: 19:09 - 12 Nov 2006 Post subject: fJR Broken gearbox... [update 18-12-06] |
Riding home today, I noticed a couple of occasions where it felt like the gearbox was jumping out of gear, but it didnt change the gear it was in.
In accelerating out of a roundabout, and changing up the box, I hear a scrunching noise, like a false neutral, and lost all drive. At the same time, the gear selector went all flappy.
Got the bike home after running back and forth from home to Milton Keynes (only about 30 miles), to get my car and trailer.
Anyone know what the situation is with the warranty on a bike that's 3 years and 2 weeks old? or have I now got an expensive paper weight?
I suspect the selector mechanism has sheared somewhere inside.
a ____________________ Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
| Kickstart |
 Kickstart The Oracle
| feef |
 Posted: 19:35 - 12 Nov 2006 Post subject: |
got a full service history from new, but I'm not sure what the warranty is. I need to check that.
Even if the warranty is less than 3 years, I'd make a call on 'fit for purpose' if their gearboxes are suffering "serious mechanical failures" within such a short space of time.
Blog and stuff - PlentyMoreFish dating |
| Paddy Blake |
 Paddy Blake World Chat Champion
| Kickstart |
 Posted: 19:38 - 12 Nov 2006 Post subject: |
Doubt you would get anywhere at all on that. Outside warrenty pretty much leaves you at the mercy of their feelings.
Guy at work had major hassle with a Peugeot his sister had where the gearbox went pop at 15 months old. Peugeot would have nothing to do with it. He compared that to his Lexus where the ignition switch wore out (well outside warrenty, well over 100k), and Lexus replaced it for free as it should not have worn out.
| sickpup |
 sickpup Old Timer
| feef |
 Posted: 10:16 - 13 Nov 2006 Post subject: |
had a look at the FJR service manual, and I suspect it could be the
shift-shaft pawl or stopper leaver that has failed.. or even the entire
end of the shift-shaft mechanism that has come adrift.
Luckily, I can check that by draining the oil, taking a couple of engine
covers off, and removing the clutch..
the service manual does mention checking the pawl, return spring and
other bits in there, for wear, and to replace if required.. it's as good
a place as any to start I spose.
if it's the shift-drum mechanism, or anything deeper, it involves dropping the engine out, and dropping the crankcase off the bottom of the engine, which includes taking the heads and barrels off
I hope it's the shift shaft and pawl :S
| feef |
| Paddy Blake |
| feef |
| sickpup |
 sickpup Old Timer
| feef |
| Paddy Blake |
| sickpup |
 sickpup Old Timer
| feef |
| feef |
| sickpup |
 sickpup Old Timer
 Posted: 22:50 - 13 Nov 2006 Post subject: |
That would be all the gearbox except the gears, shafts and selector. Just the pawl on the end.  |
| feef |
| Paddy Blake |
| sickpup |
 sickpup Old Timer
| feef |
| woodyfjr |
 woodyfjr Scooby Slapper
| feef |
| woodyfjr |
| feef |
 Posted: 12:01 - 14 Nov 2006 Post subject: |
The last post was made 19 years, 105 days ago. Instead of replying here, would creating a new thread be more useful? |
