HOnda Steed Engine specs/ Bros SPecs
mrsquirrel
PostPosted: 16:09 - 13 Nov 2006    Post subject: HOnda Steed Engine specs/ Bros SPecs Reply with quote
Do the Honda Steed 400cc and 600cc have the same stroke?
I want to carry out a simple cyclinder swap if possible to fit into my VRX,
I believe the Honda Bros/Hawl 650 has the same engine as the Steed 600 which in theory means that I could put it into my VRX as long as the strokes are the same.
Anybody got any ideas if this can be done>
Keep your nuts safe and clean!!
hmmmnz
PostPosted: 19:18 - 13 Nov 2006    Post subject: Reply with quote
the bore and stroke from the 400 is
64.0 x 62.0 mm (2.5 x 2.4 inches)
and the 600 is
75.0 x 66.0
so no not the same, you might be able to shave a mm or 2 from both sides of the head, ect ect to try and increase your compression slightly
the sv650 has a closer stroke lenth of
81.0 x 62.6 mm (3.2 x 2.5 inches)
dunno how much luck you would have trying to bolt the head of the sv on your you block.
you would probly find a engine transplant would be easier and probly a whole heap cheaper
the humans are dead
I kick arse for the lord
Paddy Blake
PostPosted: 20:13 - 13 Nov 2006    Post subject: Reply with quote
It is not a bros engine thats for sure.But a transalp 600 engine might be
close.
Paddy.
hmmmnz
PostPosted: 20:59 - 13 Nov 2006    Post subject: Reply with quote
hmmm the mighty trans alp Very Happy
just had a look and it looks like the bore and stroke is the same as the 600 steed at 75.0 x 66.0
go figure what other honda v twins are there ???
mabee an old cx500??
thats 78.0 x 52.0 mm
the humans are dead
mrsquirrel
PostPosted: 11:46 - 14 Nov 2006    Post subject: Reply with quote
This is what I have so far
The Honda Bros and Steed 400cc share the same engine but the Bros has a close ratio gear box.
The Steed 600cc and 400cc share the same frame,
It appears that the Bros 650 and the Steed 600 share the same engine but the Bros has a bigger bore.
So if all this is true then I should be able to dump a Bros 650 engine into my bike (Honda VRX)which uses a steed 400 engine since that engine can be swapped out with a 600cc steeds. which should mean that a 650 will fit.
Is that making sense?
I didn't know about the translap which has given me another option.
Any idea if the clutch basket from the 400 Steeds were common in any other bikes?
Paddy Blake
PostPosted: 12:35 - 14 Nov 2006    Post subject: Reply with quote
The front exhaust on a bros would hit the frame but i think the transalp
600 exhaust is the same angle as yours.
If your changing cylinders you will need to be sure whether the oil goes
to the heads by an external pipe or internally.
The other thing to check before you try to change the engine is how far
the shaft the sprocket goes on sticks out as there can be a difference of
5 to 10mm.
Paddy.
hmmmnz
PostPosted: 19:03 - 14 Nov 2006    Post subject: Reply with quote
have you read this??
https://www.nibiker.co.uk/reviews/bikes/bros/
the trans alp is 53hp and the nt650 engine is 57
but still a step up from the 400 Very Happy
the humans are dead
sickpup
Old Timer
PostPosted: 01:29 - 15 Nov 2006    Post subject: Reply with quote
Right do you mean the VLX/VT600 Shadow steed thing?
If so. The BROS engine is NOT the same. In many many ways it is different including making about double the power of the steed/shadow and having a 5 speed box over the steed/shadow 4 speed.
If you are trying to put a BROS engine into the custom frame you are going to run into a few problem I believe but I'm about to go to bed so will continue this later.
Heres a place you can buy a brand new complete engine that should fit quite nicely clicky.
Sadly I know these bikes to well. Wink
mrsquirrel
PostPosted: 10:23 - 15 Nov 2006    Post subject: Reply with quote
https://www.wemoto.com/wem/pic/vrx94.jpg
I'm talking about one of these VRX 400cc, this runs a Steed engine.
It really wants a 650 though. Very Happy
https://www.ridetowork.org/files/master/everydayrides/189.jpg
However if it can't be done without breaking the bank and my heart then it can't be done.
sickpup
Old Timer
PostPosted: 10:44 - 15 Nov 2006    Post subject: Reply with quote
The 650 top end from the BROS will not fit that engine but the 650 top end from an NTV might. The BROS has external oil lines for the front cylinder whereas the VT/VLX/VRX doesn't.
The easiest way to do it and the only way to retain the look is to get a complete lump from a VT/VLX.
mrsquirrel
PostPosted: 10:52 - 15 Nov 2006    Post subject: Reply with quote
That was my plan to do a whole transplant
Sorry I probably hadn't made that clear (I did change my mind part way through after realising that the stroke was different, I forgot to tell anybody)
I went from the idea of cylinders to a whole engine
So do you think that the 650 engine will fit in without too many problems then.
It appears to be exactly the same engine having researched the history but I'm not 100% sure.
sickpup
Old Timer
PostPosted: 11:00 - 15 Nov 2006    Post subject: Reply with quote
Yes the engines are from the same family but they are different.
Will it fit easily, don't know but I doubt it. Is £400 a bargain for a new engine that has a greater chance of fitting, yes.
mrsquirrel
PostPosted: 11:09 - 15 Nov 2006    Post subject: Reply with quote
I live in Thailand so that is out the question
sickpup
Old Timer
PostPosted: 11:29 - 15 Nov 2006    Post subject: Reply with quote
Oh well. Guess you're gonna have to look for a 600 locally then.
mrsquirrel
PostPosted: 11:35 - 15 Nov 2006    Post subject: Reply with quote
Current plan is to buy a whole 650 and cannabalise it.
I can pick one up for around 400-600 pounds depending on it's condition and if it's registered.
The good side being that I can sell the bike again if nothing fits.
The downside being I will end up with a Honda Hawk/Bros with a 400cc steed engine fitted to it as well.
sickpup
Old Timer
PostPosted: 12:34 - 15 Nov 2006    Post subject: Reply with quote
Notice the way I keep saying 600 and not 650, theres a reason.
mrsquirrel
PostPosted: 12:54 - 15 Nov 2006    Post subject: Reply with quote
Very good
What would that reason be then?
sickpup
Old Timer
PostPosted: 13:02 - 15 Nov 2006    Post subject: Reply with quote
Except for the transalp it would fit with the minimum of hassle.
mrsquirrel
PostPosted: 13:15 - 15 Nov 2006    Post subject: Reply with quote
Aah gotcha.
I thought you were being obtuse. Very Happy
Hassle wise shouldn't be too much of a problem (well not for me). I will be taking my mechanic to take a look at the 650 with the VRX side by side, manuals printed out and his head working hopefully he will either say yes or no rather than a maybe.
He has made steed 400 years ago with an early Bros 400 engine which he claims was no hassle.
The main concern that he has from looking at the photos is that the exhaust outlet on the front cylinder may be in line with my frame. If I am lucky it is going to come out in the middle of the radiator and I will just have to move the radiator instead or split it in to two separate coolers.
A 600 engine out here is extortionate a 600 steed is too much as well.
If it all goes to shite I have a backup plan.
A '76 GL 1000 Razz just waiting to be bought.
Clanger
Stirrer
I was always told the Africa Twin engine would easily fit into the Honda Bros frame... not that I ever did it mind, I just went out and bought a faster V-twin bike!
mrsquirrel
PostPosted: 13:16 - 15 Nov 2006    Post subject: Reply with quote
Oh
And why would the Translap cause hassle if the others don't?
sickpup
Old Timer
PostPosted: 13:49 - 15 Nov 2006    Post subject: Reply with quote
mrsquirrel wrote:
Oh
My mistake sorry its the Africa twin thats a bitch, very different ignition.
On all the engines you need to check what coils they use as each different ignition uses a different type.
mrsquirrel
PostPosted: 14:36 - 15 Nov 2006    Post subject: Reply with quote
So does that mean my original plan is still on then (within reason)?
sickpup
Old Timer
PostPosted: 16:50 - 15 Nov 2006    Post subject: Reply with quote
No the BROS 650 is a 650 not a 600. The ideal engine is a VT/VLX.
sickpup
Old Timer
PostPosted: 02:43 - 16 Nov 2006    Post subject: Reply with quote
Yes it fits in the frame easily. Its the oil cooler you have to mount and the second wiring loom for the ignition sytem that are a pain.
The last post was made 19 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 125.16 Kb
