fuel tap position?
PostPosted: 13:39 - 20 Nov 2006    Post subject: fuel tap position? Reply with quote
stupid question.
I thought my reserve wasnt working as i run outta petrol a little while ago.Decided yesterday to pull tank off and remove reserve pipe,thinking it may have fell off in the tank. When i took it off everything was looking ok.
my question is this.
https://i6.photobucket.com/albums/y238/dodgydav32000/Image2225x225.jpg
where it says pointer in above pic,this is where i thought you had to point it.
I mean if that bit was down then it would be petrol on.Pointing that bit up would be reserve.When ur looking at the bike that end looks like the pointer.but now im not sure.is it the longer end of the tap i should be using to point?
if im using the wrong end then i probably ran out of petrol cos i have been running it on reserve all the time.it sorta gives it away that the off position meant the longer pointer was pointing towards the off.but being a chinese bike i wasnt sure if the pointers on back to front/wrong way round.so i just used the end which looked like it come to a point.
could someone confirm this for me please...
dave
DRZ-400sm
Stiffler
PostPosted: 15:51 - 20 Nov 2006    Post subject: Reply with quote
It should only rotate around 180 degrees of the circle, and the side that passes off is the pointer. This is how mine works anyway.
Tim
Current Bikes - Kawasaki ZX-6R (636) | BMW G650GS
vector74
PostPosted: 16:24 - 20 Nov 2006    Post subject: Reply with quote
If the bike is gy125..
12 is reserve
3-9 is off
6 is on
In your picture the fuel is turned off. It needs to point to 12 for reserve and of course normal would be pointed down at 6. If you turn it clockwise which ever end stops at the bottom is the end that needs to point (12) to reserve.
PostPosted: 18:52 - 20 Nov 2006    Post subject: Reply with quote
ok thanks.so that would mean that when i thought i was running "on"i was actually running "res".thatll explain why i was keep running out..ill try that soon as i get my bike back on the road..
it has no rear wheel cos its still in the shop getting re-spoked...
Sad
DRZ-400sm
Momeg
PostPosted: 00:49 - 24 Nov 2006    Post subject: Reply with quote
Very Happy I'm glad someone had the courage to ask this question!
I've turned it off and on that many times i was getting quite confused but i eventually took a good look at the thing and decided that i was doing it correctly and this post confirms it
Cheers xx Laughing Very Happy
I have wandered all my life, and I have traveled; the difference between the two is this -- we wander for distraction, but we travel for fulfillment.
--Hilaire Belloc
PostPosted: 03:33 - 24 Nov 2006    Post subject: Reply with quote
ha ha whats the worst that can happen?someone might take the pi$$ out of me?
i dont give a shite what anyone thinks of me...
i got the answer i was looking for,and me posting this thread has helped you.so either way im happy.
no probs m8
dave
DRZ-400sm
Momeg
PostPosted: 17:35 - 24 Nov 2006    Post subject: Reply with quote
no probs m8
dave
I already feel a dunce when it comes to bike maintenance etc etc so am trying not to sound too thick lmao Mr. Green
--Hilaire Belloc
The last post was made 19 years, 310 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 53.64 Kb
