| robbie21mcn |
 robbie21mcn Nova Slayer
| Finglonga |
 Finglonga World Chat Champion
| alains |
 alains World Chat Champion
| robbie21mcn |
| Blau Zedong |
 Blau Zedong Banned
| six |
 six Trackday Trickster
 Posted: 22:41 - 21 Nov 2006 Post subject: |
i had this problem recently with my RS50
It sounds like your engine is flooded to be honest.
Every time you try to start it, it is pushing petrol through the engine, if its not igniting, you will just have pure petrol going straight through.
I got a spark and everything, but the damn thing wouldn't start. Try jump starting it from a car. What you wanna do is connect it all up properly and just keep pressing the ignition. The starter motor should go round and whatever, and keep going round... but the bike may not start at first (mine took about 30 mins!!!). Eventually, hopefully, the petrol will be pumped through the system, and the bike should start. If you can turn off your petrol, now would be a good time to do it, before you jump it, lol. I had petrol just spraying outta my exhaust for about 10 mins when I got my bike started, but after that it worked fine, and today I tested it, and it starts electronically fine now (touch wood).
Sometimes leaving the petrol on for a while will let it run though. Also, everytime you try to start the bike, especially if you are twisting the throttle and using the choke, its just pumping more and more petrol through the system.
I hope it works out for you.
Tom ____________________ I ride: 2003 Aprilia RS50
Yamaha R1 Fund: ?-0600.00 (grr ) |
| robbie21mcn |
 Posted: 21:35 - 22 Nov 2006 Post subject: |
not really as last night i got it started purely by bump starting it and when i got it goin it ran fine and idled perfectly. problem is when i kill the ignition and try to electronically start it wont do it!!! the minute i bump it. it springs into life again!!!  ____________________ fzr 600 its yellow but its no banana!!!!!! |
| six |
 Posted: 21:54 - 22 Nov 2006 Post subject: |
| Handsome |
 Handsome World Chat Champion
| Dilusi |
 Dilusi Borekit Bruiser
| robbie21mcn |
| alains |
| robbie21mcn |
| alains |
| Blackwolf |
 Blackwolf Burgerfist
| crazymotorbik... |
 crazymotorbik... Nearly there...
| robbie21mcn |
| Marci |
 Marci Brolly Dolly
 Posted: 12:49 - 06 Dec 2006 Post subject: |
What EXACTLY happens when you press the electric-start button?
A click?
A click and the whirr of the starter but the bike doesn't fire?
Nothing at all?
If it works when bumped, the bike itself is mechanically sound. Likely just starter switch, starter motor itself, or the starter solenoid... ____________________ FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk |
| feef |
 feef Energiser Bunny
 Posted: 12:56 - 06 Dec 2006 Post subject: |
the battery might be flat.. even a new battery left for 3 months can end up flat.
if you take out the plugs, and the engine turns over, but it doesn't turn over with the pluigs in, it could just be the battery doesn't have enough juice to overcome the compression.
Bumpstarting it proves it's not compression, plugs or anything else.
Check when it IS running that it's charging the battery.. running a bike with a knacked reg/rec means your running off the battery, and not recharging it..
a ____________________ Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating |
| robbie21mcn |
| feef |
| st3v3 |
 st3v3 Super Spammer
 Posted: 18:00 - 06 Dec 2006 Post subject: |
I would try and use another battery to see if that works, if not, check the wiring around and behind your electric start button-type-thing, has something got a dodgy/broken connection? or come loose?
otherwise, you may well be looking at salvaging a new starter motor or something in that region, good luck  ____________________ Roger wrote: Women don't get damp for clingy puppies. Get some better happy pills, hit the gym & buy a medallion the size of a dinner plate. Job done |
| verastwin |
 verastwin Derestricted Danger
| Louise |
 Louise World Chat Champion
 Posted: 17:38 - 07 Dec 2006 Post subject: |
same with mine at the moment. Bumpstars fine. batt is fine, the eletric start just 'clicks', but its not turning anything over  |
| alains |
 Posted: 14:39 - 08 Dec 2006 Post subject: |
how do you know your battery is fine ?
download my file https://www.geneva-racing.com/~alains/NSRtips.doc and look chapter about batteries
when the stater clicks and does not turn the flywheel , it's 2 possibilities :
- starter relay is worn , due to too many electric arks when pushing button (contacts destroyed)
- starter motor needs to be cleaned with brushes & springs changed (it's quit simple , see my doc) ____________________ the worst day fishing is better than the best day working |
The last post was made 19 years, 18 days ago. Instead of replying here, would creating a new thread be more useful? |
