Nervous in the wet...
Interspatial_Meltdown
PostPosted: 22:37 - 25 Nov 2006    Post subject: Nervous in the wet... Reply with quote
A few weeks ago, my friend binned his bike going round a roundabout, slid several metres before coming to a stop. I was right behind him doing the same speed and managed to grind to a halt just behind him.
He was riding a CLR125 with knobbly tires. Not the best, I know and he was probably going too fast for the conditions (neither he nor I realise how slippery it actually was).
He broke up his speedo, damaged his light, bent his bars and a few other odds and ends.
Ever since, whenever I'm riding in conditions that aren't perfectly dry I'll start to tense up and become over-cautious about every little thing. Kinda makes me not want to ride unless it's dry.
I know I'm riding a ZXR400 with road tires so I should be fine, it's jst I'm finding it hard to regain my confidence and seeing something like that right infront of me and knowing it could've/could easily be me.
I've never been overly confident on my bike since I've had it (since july) but this has seriously exacerbated the situation and I dread having to do anything that isn't in a straight line when in the wet.
It isn't really something which you can give me pointers with but any advice would be appreciated.
ZXR 400 Rider.
KTM Gordo
PostPosted: 22:42 - 25 Nov 2006    Post subject: Reply with quote
The first tip is also the hardest: relax.
If you're tense, and the 'bike slips slightly (e.g. on a white line) then you're not all that well placed to do something - and might make it worse.
Riding in the wet requires a smoother, more pre-planned riding style. Get out there, ride in the rain, and you will get more comfortable about doing it.
I've got Bridgestone BT-020 tyres on my Fazer and they're excellent in the wet (and the dry for that matter). If you're running semi-slick road-legal "racing" tyres then they're designed for warm, day tarmac.
If you can afford it, go on an off-road course as then you'll get to know when a 'bike is telling you there's no / little grip before it spits you off, and you'll stop worrying about the odd small slip or slide because you're used to it.
HTH Smile
Change is inevitable - except from a vending machine.
KTM 990 Adventure | KTM EXC 250 Racing | Land Rover Freelander SE Td4
extreme3d
PostPosted: 23:29 - 25 Nov 2006    Post subject: Reply with quote
Tyres are important, not just to grip but also to your confidence. You mention road tyres are fitted to your zxr400, but do you mean road race or road sports touring? Using Bridgestone's range tyres as an example, a road going 'race' tyre would be an 014. The road sports touring would be an 020.
Only one is good in the wet and that's the 020. It's designed for road use only, not trackday use, so it's optimum temperature is lower and works fine even when wet. The 014 must be kept very hot to provide optimum grip. This is rarely achieved on dry roads let alone when they are covered in cooling water Wink
So at this time of year fit a tyre that will cope with water. Personally I find the conti Road Attacks are the grippiest of all the current sports touring tyres on the market at present.
KTM Gordo
PostPosted: 10:05 - 26 Nov 2006    Post subject: Reply with quote
Having said that, I've done three trackdays on BT-020s without any trouble - although they did suffer a bit:
https://images.fotopic.net/yah9eh.jpg
The BT-014 is also pretty good in the wet from what I've heard, but I've never used them.
HTH Smile
quik_d
PostPosted: 12:11 - 26 Nov 2006    Post subject: Reply with quote
reiterating whats aready been said a bit but in the wet try to stay upright as much as possible, where in the dry you'll be leaning it right in through corners try to keep as much rubber in contact with the road as you can whilst still going round the corner smoothly.
Leave more distance between you and the vehicle in front and if its pouring down squeeze your brakes slowly when going along to keep some heat in them otherwise when you need to slow down they'll be crap at first.
HTH Smile
i have to say i've been fairly unimpressed with the bt020's, i mean maybe its all in my head but i find the slipping quite a bit and i dont feel i can lean them over in the wet at all really. i'm on a 1999 bandit 600, maybe its the roads i'm on as they are busy roads with lots of tankers etc on them so maybe its not the tyres but the conditions. Fantastic in the dry tho Thumbs Up
LOOK AT DAT M8 WELL LUSH A PARROT INT IT
KTM Gordo
PostPosted: 13:00 - 26 Nov 2006    Post subject: Reply with quote
It could be roads, but I would also check your tyre pressures. Just a small change can make a big difference. I know what you mean about it being in your head - I've had some unusually "nervous" rides in the wet for no good reason... More practice needed perhaps? Smile
On the subject of tyre pressures, Bridgestone recommend 36/40psi front/rear on the Fazer 600, so it might be similar to the Bandit. Note that this is not the same as Yamaha state in the manual, but I trust the tyre maker more than Yamaha!
HTH Smile
andrea
PostPosted: 13:19 - 26 Nov 2006    Post subject: Reply with quote
I felt exactly the same when i first rode in the wet, i was given excellent advice from this forum, link here
https://www.bikechatforums.com/viewtopic.php?t=95065&highlight=
Remember to relax, look as far ahead as possible whilst still scanning back for manhole covers, paint in the road etc (which should be avoided if at all possible) leave twice the normal braking distance etc.
The last ride i went on my R6 was the best i ever had, even though it was wet and still raining heavily. I had total confidence for the first time, it just felt right. With practise you will feel the same.
[/url]
kawashima
PostPosted: 15:57 - 26 Nov 2006    Post subject: Re: Nervous in the wet... Reply with quote
I once slipped just after I changed to new tyre on my CB400SF at the first crossing Laughing . I turned and opened throttle too wide(to check the new sprocket gear ratio... I was flying and fell to the ground). The reason was : Tyre wax remained. Even after I completely removed the wax, I became very nervous against leaning bike for a few months, so I understand the feeling well. The brain feels the rejection against leaning physiologically.
There was nothing but gaining the previous feeling little by little for me.
own:2020 Serow 250
JonB
Afraid of Mileage
PostPosted: 16:04 - 26 Nov 2006    Post subject: Reply with quote
You are not alone. I have put BT020's on my Bandit 600 and it just doesn't have the grip my previous BT45's had. On the trackday I did they kept loosing grip. Did not have this problem with my BT45's.
Only area where my BT020's are better is in the wet. Might try some Michelins next time.
nautilus
PostPosted: 14:41 - 27 Nov 2006    Post subject: Reply with quote
'Sfunny what a cerebral thing biking is. You're brain can really screw up your riding & it is your brain rather than the wet. Just have to desensitise it by getting in lots of practice in the wet. It won't be pleasant but the more miles you get done in bad conditions the moreconfident you'll be. An off road or a track day can also help although difficult to arrange rain for the day!
krebsy
PostPosted: 14:52 - 27 Nov 2006    Post subject: Reply with quote
rode the Divvy on BT-45's and the ZZR has 020's. I don't know whether it's own to the different bike or not but the 020's seem less grippy. I slid the back end a little coming out of the estate this lunchtime with too much power on the slightly damp road. the 45's on the Divvy et up the wet.. and stuck like glue in the heat (I hacked the bike two-up through the tight "25mph limit" corners past the Broadway tower en route to Oxford practically on it's side with no issues.. Smile ).
still, the 020's seem ok once they've got a bit of heat in them...
K.
1280 x 1024.
quik_d
PostPosted: 20:18 - 27 Nov 2006    Post subject: Reply with quote
i took the bike out for a spin at the weekend, it had rained about half an hour before i went out so the roads were damp but not sodden. I decided to see if the slipping was all in my head, by the time i got home i was convinced it was not me. I purposely lent over a little coming out of roundabouts, and whilst the sliding was gradual and i felt like i was under control of it, the bike slid out very easily. I will check the pressures tomorrow morning but i check them regularly so i think thy'll be fine.
i put 30 in the front and 36 in the rear, I with these tyres over other cheaper ones (most notably BT45' and road pilots) due to the masses of goods reviews so i think my experience is fairly uncommon. I couldn't fault the BT45' i had on my last time, rain, sun, snow even unfazed them, and they were some 40 quid cheaper a pair! maybe its a bandit + 020's incompatibility if other people have found similar results?
Cheers and stay safe Thumbs Up
quik_d
PostPosted: 20:22 - 27 Nov 2006    Post subject: Reply with quote
oh and i have experience riding in the wet, so i don't beleive thats the problem. i've ridden my bikes all year round in all conditions for the past 5 years so i've been exposed to just about all weather england throws at us
cheers
Dean
The last post was made 19 years, 263 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 84.37 Kb
