| Interspatial_Meltdown |
 Interspatial_Meltdown Renault 5 Driver
| KTM Gordo |
 KTM Gordo Brolly Dolly
 Posted: 22:42 - 25 Nov 2006 Post subject: |
The first tip is also the hardest: relax.
If you're tense, and the 'bike slips slightly (e.g. on a white line) then you're not all that well placed to do something - and might make it worse.
Riding in the wet requires a smoother, more pre-planned riding style. Get out there, ride in the rain, and you will get more comfortable about doing it.
I've got Bridgestone BT-020 tyres on my Fazer and they're excellent in the wet (and the dry for that matter). If you're running semi-slick road-legal "racing" tyres then they're designed for warm, day tarmac.
If you can afford it, go on an off-road course as then you'll get to know when a 'bike is telling you there's no / little grip before it spits you off, and you'll stop worrying about the odd small slip or slide because you're used to it.
HTH  ____________________ Change is inevitable - except from a vending machine.
KTM 990 Adventure | KTM EXC 250 Racing | Land Rover Freelander SE Td4 |
| extreme3d |
 extreme3d World Chat Champion
 Posted: 23:29 - 25 Nov 2006 Post subject: |
Tyres are important, not just to grip but also to your confidence. You mention road tyres are fitted to your zxr400, but do you mean road race or road sports touring? Using Bridgestone's range tyres as an example, a road going 'race' tyre would be an 014. The road sports touring would be an 020.
Only one is good in the wet and that's the 020. It's designed for road use only, not trackday use, so it's optimum temperature is lower and works fine even when wet. The 014 must be kept very hot to provide optimum grip. This is rarely achieved on dry roads let alone when they are covered in cooling water
So at this time of year fit a tyre that will cope with water. Personally I find the conti Road Attacks are the grippiest of all the current sports touring tyres on the market at present. |
| KTM Gordo |
| quik_d |
 quik_d Could Be A Chat Bot
| KTM Gordo |
 Posted: 13:00 - 26 Nov 2006 Post subject: |
| andrea |
 andrea World Chat Champion
 Posted: 13:19 - 26 Nov 2006 Post subject: |
I felt exactly the same when i first rode in the wet, i was given excellent advice from this forum, link here
https://www.bikechatforums.com/viewtopic.php?t=95065&highlight=
Remember to relax, look as far ahead as possible whilst still scanning back for manhole covers, paint in the road etc (which should be avoided if at all possible) leave twice the normal braking distance etc.
The last ride i went on my R6 was the best i ever had, even though it was wet and still raining heavily. I had total confidence for the first time, it just felt right. With practise you will feel the same.
[/url] |
| kawashima |
 kawashima World Chat Champion
 Posted: 15:57 - 26 Nov 2006 Post subject: Re: Nervous in the wet... |
| Interspatial_Meltdown wrote: | Ever since, whenever I'm riding in conditions that aren't perfectly dry I'll start to tense up and become over-cautious about every little thing. |
I once slipped just after I changed to new tyre on my CB400SF at the first crossing . I turned and opened throttle too wide(to check the new sprocket gear ratio... I was flying and fell to the ground). The reason was : Tyre wax remained. Even after I completely removed the wax, I became very nervous against leaning bike for a few months, so I understand the feeling well. The brain feels the rejection against leaning physiologically.
There was nothing but gaining the previous feeling little by little for me. ____________________ own:2020 Serow 250
owned: 2012 YB125SP, 2008 TDM900, 2005 W650, 2002 LS125R, 2002 CB400SF, NS50F, C50 / Trip to UK(2009), Hokkaido touring(2013) |
| JonB |
 JonB Afraid of Mileage
| nautilus |
 nautilus Borekit Bruiser
| krebsy |
 krebsy World Chat Champion
 Posted: 14:52 - 27 Nov 2006 Post subject: |
rode the Divvy on BT-45's and the ZZR has 020's. I don't know whether it's own to the different bike or not but the 020's seem less grippy. I slid the back end a little coming out of the estate this lunchtime with too much power on the slightly damp road. the 45's on the Divvy et up the wet.. and stuck like glue in the heat (I hacked the bike two-up through the tight "25mph limit" corners past the Broadway tower en route to Oxford practically on it's side with no issues.. ).
still, the 020's seem ok once they've got a bit of heat in them...
K. ____________________ What's my New Year's resolution?
1280 x 1024. |
| quik_d |
 Posted: 20:18 - 27 Nov 2006 Post subject: |
i took the bike out for a spin at the weekend, it had rained about half an hour before i went out so the roads were damp but not sodden. I decided to see if the slipping was all in my head, by the time i got home i was convinced it was not me. I purposely lent over a little coming out of roundabouts, and whilst the sliding was gradual and i felt like i was under control of it, the bike slid out very easily. I will check the pressures tomorrow morning but i check them regularly so i think thy'll be fine.
i put 30 in the front and 36 in the rear, I with these tyres over other cheaper ones (most notably BT45' and road pilots) due to the masses of goods reviews so i think my experience is fairly uncommon. I couldn't fault the BT45' i had on my last time, rain, sun, snow even unfazed them, and they were some 40 quid cheaper a pair! maybe its a bandit + 020's incompatibility if other people have found similar results?
Cheers and stay safe  ____________________ LOOK AT DAT M8 WELL LUSH A PARROT INT IT |
| quik_d |
The last post was made 19 years, 264 days ago. Instead of replying here, would creating a new thread be more useful? |
