I could cry... SV gearbox damage.
lilredmachine
PostPosted: 17:52 - 27 Nov 2006    Post subject: I could cry... SV gearbox damage. Reply with quote
I've had the SV for about a month, and some prick has already decided to jump up and down on the gear lever so hard that it has bent the lever down towards the floor, broken something in the gearbox (possibly the selector fork) so that the motor is jammed and won't turn over (the bike is 'stuck' in neutral so can be wheeled around) apart from every now and then when the input shaft from the lever mechanism is wiggled, and then only with a nasty metallic grating sound. What is it likely to have fubared in the gear box, and is it an engine out job to get at? Crying or Very sad
This happened at college. Some little shit is going to pay.
instigator
PostPosted: 18:02 - 27 Nov 2006    Post subject: Reply with quote
Oil out, drain coolant, right hand side engine casing off, remove clutch plates and holding thingymajiggy. If you can do that, you should be able to see if there is any damage done to the selectors and what not.
Do it, do it now. Before I forget what the insides of an sv engine look like. Laughing
SVhovis650s
PostPosted: 18:30 - 27 Nov 2006    Post subject: Reply with quote
Confused did you give the person a go on your bike? or was this done delibratly?
Oh, what sad times are these when passing ruffians can say Ni at will to old ladies. There is a pestilence upon this land, nothing is sacred. Even those who arrange and design shrubberies are under considerable economic stress in this period in history.
lilredmachine
PostPosted: 18:58 - 27 Nov 2006    Post subject: Reply with quote
No, it was parked up in college and some little chav shit has done it. I fired it up and went to leave, tapped it down into gear (hadn't looked at the lever) and there was a nasty metallic noise and it locked at which point i nearly dropped it, that was it. I've got the college to check for anything on the CCTV. God save whoever has done this, if i find out who they are.
So it might not be an engine out job? Phew. I'm afraid the bike is locked in the college compound at the moment, i'm getting it picked up tomorrow so will investigate with gusto. I'm skint as hell at the moment, so i hope nothing is too awry Confused
instigator
PostPosted: 19:05 - 27 Nov 2006    Post subject: Reply with quote
If they do have the culprit on cctv, try your best to get a copy and take revenge that way. Police will do sweet bugger all. I'm not overly sure WHAT it could be but I do know what the insides should look like. Would be interested to see what the left hand side rear seat looks like too, to see what has been bent/snapped.
lilredmachine
PostPosted: 19:11 - 27 Nov 2006    Post subject: Reply with quote
The end of the gear change lever is pointing downwards. I'm not planning on going to the police, I can't be arsed with the hassle. I have a distinct feeling that it will be one of the chavs that does bricklaying around the corner. If it is, there is a fair old chance that they may miss a few months of their course.
PostPosted: 19:18 - 27 Nov 2006    Post subject: Reply with quote
Should you need any parts, I've got both a spare engine in parts and a whole spare engine.
However, I've seen some SV engines go /very/ cheaply these days, so could be worth a look on ebay and motoforum - talking £100 for a complete working engine!
instigator
PostPosted: 19:24 - 27 Nov 2006    Post subject: Reply with quote
Bugger. Just went and spent £20 on a starter motor. If I knew i could have got one off you for £0, I wouldn't have bought it!!
lilredmachine
PostPosted: 19:48 - 27 Nov 2006    Post subject: Reply with quote
Thanks for that G, i'll bear that in mind. I'm hoping that it won't be too bad when I open it up, but it does not sound good at all. Should the worst come to the worst at least a new motor shouldn't be too bad to get hold of Razz
In order to remain on two wheels, I've dusted off the DR for a while. To be frank, it felt so good to ride it again, I may just fix the SV then flog it!
SVhovis650s
PostPosted: 22:03 - 27 Nov 2006    Post subject: Reply with quote
buggerx2 1 just spent £90 on a rectifier Wink
PostPosted: 22:05 - 27 Nov 2006    Post subject: Reply with quote
Ouch; rectifier on my road SV went and it was about £25 all in on ebay Neutral - though I did nick one from the race bike while I was waiting for it Smile.
SVhovis650s
PostPosted: 22:19 - 27 Nov 2006    Post subject: Reply with quote
there was one on there for £10.........before i needed one Rolling Eyes
i could have got one for£50 from a breakers yard, but thought that it could be knacked,so i got a new un Evil or Very Mad
Dom
PostPosted: 22:28 - 27 Nov 2006    Post subject: Reply with quote
That's some shocking luck, especially since you only just picked up the bike. Sad Unfortunately I doubt I could be any help; I haven't really got any spares about and haven't gone anywhere near the gearbox on my SV.
You can get pattern ones for 40 quid. Fitted one to mine over a year ago and it's been perfect. Sorry. Razz
Photos and that
SVhovis650s
PostPosted: 22:45 - 27 Nov 2006    Post subject: Reply with quote
you live & learn Embarassed
lilredmachine
PostPosted: 19:47 - 28 Nov 2006    Post subject: Reply with quote
I've got it back home, I'll crack her open tomorrow. Found the motor manual so i'll be armed with literature. I'll take pics for the more familiar-with-sv650s members for seeing if there is anything obviously out of place.
lilredmachine
PostPosted: 20:42 - 29 Nov 2006    Post subject: Reply with quote
Ok, it's been knocked back till tomorrow. Got a day to do it then.
Just one thing, why do I have to drain the coolant? Sounds like a noob question I know, but I didn't have to on the MZ to do essentially the same thing...
PostPosted: 20:44 - 29 Nov 2006    Post subject: Reply with quote
If you're taking the right side panel off (which I presume you are), the coolant pump is located there. This includes pipes that go into the engine, so when you take it off it will break the seals that go to the pump and dump the coolant (usually half of it into the oil if you haven't drained it).
PostPosted: 20:49 - 29 Nov 2006    Post subject: Reply with quote
that's crap luck mate. hope you find the scum bag that did it.
SVhovis650s
PostPosted: 20:51 - 29 Nov 2006    Post subject: Reply with quote
have you found out who did it?
lilredmachine
PostPosted: 21:46 - 29 Nov 2006    Post subject: Reply with quote
No, not yet. The college hasn't gotten back to me on whether or not anything is visible on cctv.
Thanks G, I can see you are going to be quite a big help in this. I've had a read of the manual with my dad now and can see what you mean. From the symptoms, it would appear the gear shift mechanism has come to pieces inside the case (possible jamming everything up hence it not turning over), and that one or more of the gear shift folks may be bent. All I can see from the manual is that it looks like a big job to reach them... Am I correct?
PostPosted: 22:21 - 29 Nov 2006    Post subject: Reply with quote
Not sure if I'll be as much of a help as you're hoping.
I expect it will be quite a big job to get to them. Not as tightly packed as some sports bikes, but then they usually have a removable sump.
lilredmachine
PostPosted: 13:09 - 30 Nov 2006    Post subject: Reply with quote
Any suggestion on how to remove the clutch basket? It's 'stuck' in neutral so there is no way of stopping it from moving as the hub nut is turned...
instigator
PostPosted: 13:20 - 30 Nov 2006    Post subject: Reply with quote
Screw driver jammed inbetween the two sets of teeth so it gets difficult for it to revolve....?
I was lucky, on my sv, once I had undone the crumple washer, the nut was literally finger tight. But on my diversion, I was jumping on the torque wrench and it wouldn't come undone. Some are 5nm tight, some 150nm. Mad
There is a special tool you can use in such circumstances but I am not sure how much it is or where you'd get one. Sick'up probably knows I imagine.
PostPosted: 13:21 - 30 Nov 2006    Post subject: Reply with quote
Air/electric impact wrench is the best way.
Otherwise, haynes usually shows a way to make a 'holder' out of two strips of metal - you bend the end of each one and join them in the middle to make a scissor/plier style device; then poke the ends into bits of the clutch basket.
I tried making that once and failed, so took it to a local garage instead.
lilredmachine
PostPosted: 14:16 - 30 Nov 2006    Post subject: Reply with quote
Just chiseled the nut off in the end. Not like it's going back on the road soon anyway Wink
https://img138.imageshack.us/img138/4822/feckoffholeuw5.jpg
https://img153.imageshack.us/img153/6300/crankbitvk2.jpg
The problem has become rather... terminal. There is now a feck off hole in the crankcase. The damage is so severe it is difficult to tell what has gone on inside. My best guess is the abuse the gearshift mechanism got made it fall apart in the crank case, the actual shifter was wedged between the primary drive gear and the oil pump drive and is bent to buggery. The main damage was probably done when the shifter wedged in the main drive when it was running, the jolt it put through the mounting in the crank case broke it off, and all the little bits of crankcase then went through the motor resulting in the nasty metally/oily mess that came out when I took out the sump plug.
Short term prognosis is it's fucked, I need a new right hand crankcase (at the least, not to mention the gearshift mechanism and possibly the oil pump drive gear and primary drive gear) and it's an engine out job. One side of my head reckons it would be an easier and in the long run cheaper method to try and obtain a second motor and swap it in, keeping this one as spares. The top end is fine. Unless anyone has a right hand crank case going cheap? Wink
This is quite possibly the worst thing that could of happened Laughing
The last post was made 19 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.73 - MySQL Queries: 13 - Page Size: 133.55 Kb
