xs 650 boyer branston inginiton
 Topic moved: from General Bike Chat to The Workshop by G (30 Nov 2006 - 23:26)
craftydg
PostPosted: 23:59 - 30 Nov 2006    Post subject: xs 650 boyer branston inginiton Reply with quote
i got the boyer branston electronic inginiton on mi xs650 but every time i ride mi chop the thing cuts out Rolling Eyes i found it 2 be the coil but wen the coil is cold its perfect but after a few min of running it gets hot (if i aint moving) even wen the engine is cold and not running it gets hot if the ingition is on Question Question
(cold it works)
(hot it dont work)
what causes this ?
yambabe
PostPosted: 00:25 - 01 Dec 2006    Post subject: Reply with quote
Was the coil supplied with the ignition system or is it the original Yamaha one?
Tarmacsurfer
PostPosted: 01:25 - 01 Dec 2006    Post subject: Reply with quote
After running your post through Babelfish I think I got the gist of it.
The Boyer Bransden kits are notoriously picky with coils (at least they were a few years back, fitted a Bransden kit to my GPz and mated it up to first Dyna and then Accell coils), so it could be a resistance issue. On the other hand, that description is almost textbook for a wiring issue. Heats up, expansion in the loom, all of a sudden no connection.
What do you mean when you say you found it to be the coil? Have you actually dropped the coil off and checked it, or are you simply checking for a spark?
I'm immortal. Well, so far.
finpos
PostPosted: 08:01 - 01 Dec 2006    Post subject: Reply with quote
Sounds like the coil is mismatched to me. If the Boyer Brandston thing is marketed as performance kit, you'll almost certainly need upgraded coils as well.
finpos.
irving
PostPosted: 09:10 - 01 Dec 2006    Post subject: Reply with quote
PostPosted: 18:36 - 01 Dec 2006    Post subject: Reply with quote
They are also notoriously fussy about battery condition. If your battery is getting a bit old, maybe time for a new one.
The last post was made 19 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.53 - MySQL Queries: 16 - Page Size: 47.21 Kb
