| bladerunner |
 bladerunner World Chat Champion
 Posted: 15:57 - 09 Dec 2006 Post subject: Will a GPZ500 head and Cams fit a KLE 500 engine |
Anybody know if there are any differences between the GPZ500 and the KLE500 engines? A friend of mine has fitted a GPZ head assembly onto his KLE but cant get it to run.The KLE was missing the head when he bought it
I havent had a look myself at it yet but he assures me that the valves have been lapped in and seal. The cam timing is correct according to the KLE manual as are the valve clearances. The inlet and exhaust cams are in the correct way round!! and it has a good spark and the timing is not adjustable but wont fire even with easystart sprayed into the bores.(I know bodger)
As i say i havent had a look at it myself yet but apparently when the motor is turned over there is little suction on the carb side and even seems to pump air out of the carb??? So I'm wondering did kawasaki do different configurations of this engine? i.e. are the cams wrong for this motor??
Any sugestions guys and girls?
Cheers  |
| 0ddball |
 0ddball World Chat Champion
| bladerunner |
| stinkwheel |
| stevo as b4 |
| bladerunner |
 Posted: 23:34 - 10 Dec 2006 Post subject: |
Thanks for the replys guys. The head was lost at a local engineering firm whilst it was having the exhaust studs drilled out and re tapped. A GPZ500 head and cams were fitted but as I said above it hasnt even the slightest attempt of firing..so looks like I'll drop a pencil down the plug holes and watch the valves open and close as I have a horrible feeling this cam might not be the same as the KLE one!!
I would at least have expected a pop or bang out of it as is should everything be ok!!
Thanks for taking the time to answer the post guys!!
I'll let you know how I get on!!!
Anybody got a spare KLE cam kicking about
Rob  |
| stinkwheel |
| bladerunner |
 Posted: 23:51 - 10 Dec 2006 Post subject: |
I'm on Anglesey north Wales..Let me know how much youd be after for it...The last motor was bought from glasgow!! the guy who now owns the bike rode up on his Bergman scooter to pick it up...not bad for a 65 yr old bloke hehe. I havent had a look at it like i said but feel a little guilty as i said the motor should be the same but looks like i might have been wrong
if we ended up posting it I'd only need the cam or cam and head assembly.Would you be able to split to save on costs?
Rob  |
| stinkwheel |
| stinkwheel |
| 0ddball |
| stinkwheel |
| Kickstart |
 Kickstart The Oracle
 Posted: 09:35 - 11 Dec 2006 Post subject: |
Found my Kawasaki manual for the early GPZ500.
Ignition timing: From 10° BTDC @1 200 r/min (rpm) to 37.5° BTDC
@10 000 r/min (rpm)
Valve timing:
Inlet: Open 45° BTDC. Close 65° ABDC. Duration 290°
Exhaust: Open 70° BBDC. Close 40° ATDC. Duration 290°
A bit different, but to be honest I suspect it would only make a difference if the pistons and valves ran VERY close.
If it isn't just being a pain to star following the rebuild as Stinkwheel suggests then personal guess is that one of the cams is 180 degrees out.
| bladerunner |
| Pete. |
 Pete. Super Spammer
 Posted: 12:23 - 11 Dec 2006 Post subject: |
As a rough guide, every other turn of the engine, as the No1 piston passes TDC, you should see the exhaust valve and the inlet valve both moving at the same time, this is the valve overlap as the exhaust is closing just after the end of the exhaust stroke and the inlet starts to open just before the start of the induction stroke. ____________________ a.k.a 'Geri'
| stinkwheel |
| Kickstart |
There is a gap of 4 years, 106 days between these two posts... |
| dinomeat |
 dinomeat L Plate Warrior
 Posted: 00:26 - 27 Mar 2011 Post subject: gpz 500s timing |
hi i just bought a 1993 gpz 500s the bloke said it was all jammed up ive had it all apart and found out it was just the starter motor jammed , i took all the cylinder head off to find out if there was anything else wrong but all seemed ok so i put it all back together but im having trouble get any timing marks any tips or info on how to time it all up would be a great help thank |
| MarJay |
 MarJay But it's British!
| dinomeat |
| stevo as b4 |
The last post was made 15 years, 201 days ago. Instead of replying here, would creating a new thread be more useful? |
