| TGE125NSR |
 TGE125NSR Banned
 Posted: 16:26 - 29 Jul 2003 Post subject: NSR Overheating |
A friend of mine who lives near by has just brought a NSR RK G reg.
2 things, how much would starter motor be?
After you get it started by bumping it, within say 5 minutes of riding it begins to overheat.
It has had a new water pump.
Any ideas?
I think this forum needs a 'technical' section. Would look better with all these technical posts seperated from the general chat topics.
Just a thought  |
| Ste |
 Ste Not Work Safe
 Posted: 16:30 - 29 Jul 2003 Post subject: |
Start motor about £60ish
Flush out the coolant, and refill it. Thats assuming that the owner has put any coolant in it
And it doesn't need a technical section, it needs an NSR section! |
| M1ke |
 M1ke Ped Boi
 Posted: 16:33 - 29 Jul 2003 Post subject: |
Just do what scotty does when his overheats, stop every couple of mile and take a piss on it.  |
| TGE125NSR |
 TGE125NSR Banned
 Posted: 16:35 - 29 Jul 2003 Post subject: erm |
Yeah okay cheers steven.
Thanks newbie for that , i think your main area of knowledge is the penis, so we will make you a forum called ' all about the penis ' by newbie!
On a serious note, could it be the radiator or gaskets in the top end?
| TiN |
 TiN Pocket Tin
 Posted: 16:40 - 29 Jul 2003 Post subject: |
Is it actually overheating, or are you going purely by the temp guage reading? Could be a dodgy thermostat for false readouts. Otherwise, is the coolant topped up? ____________________ TiN
dotgems.net |
| Scotty |
 Scotty Scooter Boi
| TGE125NSR |
 TGE125NSR Banned
 Posted: 17:42 - 29 Jul 2003 Post subject: ye |
Well the bike is with his dad who lives about 20 mile away so i havent seen it, i will ask him when i see him.
Basically he just said he gets on it i, rides, 5 minutes later the temperature has creeped up to like over the 3/4 mark so he pulls over and lets it cool down and rides again!
Not a bike for going to work on!
| Ropehead |
 Ropehead Could Be A Chat Bot
| Scotty |
 Scotty Scooter Boi
 Posted: 21:15 - 29 Jul 2003 Post subject: |
Is the radiator hot, or does the engine get hot with the radiator staying cold?
Does the engine use any water?
If the head or base gaskets are gone it is likely to use some water.
If the coolant cannot circulate properly then it is likely the engine will be hot while the radiator stays cold. This can happen is the water pump is not working, the thermostat is sticking or also if the antifreeze mix in the cooling system is too strong (should be about a 50/50 mix of water and antifreeze)
The last post was made 23 years, 50 days ago. Instead of replying here, would creating a new thread be more useful? |
