cagiva supercity gearing **UP-DATE** X2
befdelta7
PostPosted: 22:46 - 02 Dec 2006    Post subject: cagiva supercity gearing **UP-DATE** X2 Reply with quote
hi peeps,
does anyone know what the number of teeth are on the standard front and rear sprocket for the supercity 125? im getting a new chain and sprockets kit(the standard ones are completely knackered Rolling Eyes ) and want faster acceleration, so need to know the number of teeth of both so i dont order the same as standard.
also does anyone have any recommendations as to what size(number of teeth) of sprockets i should get to have faster acceleration? im not to bothered about losing top-end speed as i never do more than 75/80MPH and still have another gear to go Shocked anyway.
thanks in advance for the tips and replys Thumbs Up Thumbs Up
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
Dischord
PostPosted: 23:18 - 02 Dec 2006    Post subject: Reply with quote
It should be etched into the sprockets, give it a rub down with a wire brush if it's mucky! if not try counting them Very Happy
If you want acceleration go a tooth down on the front and 2 teeth up on the rear, should do just nice Thumbs Up
2012 KTM EXC 250
befdelta7
PostPosted: 00:38 - 03 Dec 2006    Post subject: Reply with quote
1..2..3..4..5..6........ arghhhh lost count Laughing il look in the manuel if its not listed ill count 'em.
cheers thanks for that!! all i really do is city riding except for the sundays i go to boxhill(which isnt very often. most sundays im recovering from a heavy saturday night out on the piss Thumbs Up Thumbs Up ) so i think accelleration makes the most sense judging by the type of riding im doing Neutral
cagiva gezzer
PostPosted: 17:40 - 03 Dec 2006    Post subject: Reply with quote
Use the attached calculator.
opps - thats a six speed version, you've got a seven speed. You can alter it with the seven speed ratios.
befdelta7
PostPosted: 14:07 - 14 Dec 2006    Post subject: Reply with quote
iv looked around and all i can find are standard size front sprocket and 1 tooth bigger on the rear instead of what i want which is 1 tooth smaller on the front and 2 teeth bigger on the rear.
anyone know where i can get a kit for the supercity 125cc with 1 tooth smaller on the front and 2 teeth bigger on the rear and a chain to match included, or will i have to buy it all separate??
cheers for your replys
james.
sickpup
Old Timer
PostPosted: 19:28 - 14 Dec 2006    Post subject: Reply with quote
43 tooth rear is the largest available. 42 is standard
13 tooth is standard front with an option on 14 tooth when derestricted.
cagiva gezzer
PostPosted: 23:20 - 14 Dec 2006    Post subject: Reply with quote
https://www.125ccsportsbikes.com/forums//index.php?showtopic=7223
sickpup
Old Timer
PostPosted: 00:10 - 15 Dec 2006    Post subject: Reply with quote
According to my fitment list the Mito uses a different front and rear sprocket.
cagiva gezzer
PostPosted: 18:55 - 15 Dec 2006    Post subject: Reply with quote
They use differnet sizes depending on 6 / 7 speed or year it came out of factory. They're the same physical fitment. The planet can have a different rear on some.
https://www.biketorqueracing.co.uk/Final%20Drive/chains.asp another site for prices.
befdelta7
PostPosted: 21:59 - 18 Dec 2006    Post subject: Reply with quote
so what would you recommendations on sprocket sizes (number of teeth on the front and rear) be for quicker acceleration Question the traffic around my area on a daily basis is ridiculous so quicker acceleration makes more sense than going for standard gearing -- and its a change from the usual every day ride too Thumbs Up
sickpup
Old Timer
PostPosted: 05:08 - 19 Dec 2006    Post subject: Reply with quote
According to the fitment they are a different physical fitment.
I would be happy to be wrong on this.
befdelta7
PostPosted: 16:31 - 14 Jan 2007    Post subject: Reply with quote
iv just counted my teeth on both sprockets and the rear is a standard 42tooth and the front is a Shocked 15 tooth Shocked
so fitting a 13tooth front and a 43tooth rear will be a substantial increase in accelleration...
my question is, is it wise to got for a 13tooth front sprocket judging by the 15tooth on the front which i thought was a 13tooth and would that make my bike rev out? i dont mind losing a little top-speed but surly this change will incur problems... or will it be fine?
cheers for your replys guys Thumbs Up
stevo as b4
PostPosted: 22:25 - 14 Jan 2007    Post subject: Reply with quote
id expect a 1 tooth drop in front sprocket size to lose you around 5mph, and sharpen the acceleration a bit. Id be very suprised if you need to drop more than 2 teeth on the front sprocket however.
Have you got the option of getting a rear sprocket with fewer teeth? If so, this gives you more scope to make small changes to the gearing, that maybe in between 1 tooth more/less on the front sprocket. Also if you use a smaller rear sprocket you will reduce the un sprung weight slightly too.
befdelta7
PostPosted: 23:01 - 14 Jan 2007    Post subject: Reply with quote
what does that mean? please explain iv never herd of un sprung weight Embarassed
cheers for your reply Thumbs Up
Marci
PostPosted: 12:24 - 15 Jan 2007    Post subject: Reply with quote
https://en.wikipedia.org/wiki/Unsprung_weight
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
befdelta7
PostPosted: 15:05 - 15 Jan 2007    Post subject: Reply with quote
cheers for that Marci
from what i can understand about it, it means when accelerating a slight bump in the road could cause the front wheel to lift slightly. am i correct or have i not fully understood the meaning of it? Confused
also any tips for fitting a new chain and sprockets:
Arrow any easy ways of doing it?
Arrow any particular part needed to be fitted first?
Arrow any things to watch out for when fitting or fitted and taking the bike out for the first time?
cheers for your replys boys!
befdelta7
PostPosted: 19:53 - 15 Jan 2007    Post subject: Reply with quote
anyone there???
The last post was made 18 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 98.21 Kb
