| befdelta7 |
 befdelta7 Brolly Dolly
 Posted: 22:46 - 02 Dec 2006 Post subject: cagiva supercity gearing **UP-DATE** X2 |
hi peeps,
does anyone know what the number of teeth are on the standard front and rear sprocket for the supercity 125? im getting a new chain and sprockets kit(the standard ones are completely knackered ) and want faster acceleration, so need to know the number of teeth of both so i dont order the same as standard.
also does anyone have any recommendations as to what size(number of teeth) of sprockets i should get to have faster acceleration? im not to bothered about losing top-end speed as i never do more than 75/80MPH and still have another gear to go anyway.
thanks in advance for the tips and replys  ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
| Dischord |
 Dischord World Chat Champion
 Posted: 23:18 - 02 Dec 2006 Post subject: |
It should be etched into the sprockets, give it a rub down with a wire brush if it's mucky! if not try counting them
If you want acceleration go a tooth down on the front and 2 teeth up on the rear, should do just nice  ____________________ 2012 KTM EXC 250
Check out my vids - https://www.youtube.com/user/KTMSparky/videos |
| befdelta7 |
 Posted: 00:38 - 03 Dec 2006 Post subject: |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| befdelta7 |
| sickpup |
 sickpup Old Timer
| cagiva gezzer |
| sickpup |
 sickpup Old Timer
| cagiva gezzer |
 Posted: 18:55 - 15 Dec 2006 Post subject: |
They use differnet sizes depending on 6 / 7 speed or year it came out of factory. They're the same physical fitment. The planet can have a different rear on some.
https://www.biketorqueracing.co.uk/Final%20Drive/chains.asp another site for prices. ____________________ "because one stroke isnt enough and four strokes waste two" |
| befdelta7 |
 Posted: 21:59 - 18 Dec 2006 Post subject: |
so what would you recommendations on sprocket sizes (number of teeth on the front and rear) be for quicker acceleration the traffic around my area on a daily basis is ridiculous so quicker acceleration makes more sense than going for standard gearing -- and its a change from the usual every day ride too  ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine. |
| sickpup |
 sickpup Old Timer
 Posted: 05:08 - 19 Dec 2006 Post subject: |
According to the fitment they are a different physical fitment.
I would be happy to be wrong on this. |
| befdelta7 |
 Posted: 16:31 - 14 Jan 2007 Post subject: |
iv just counted my teeth on both sprockets and the rear is a standard 42tooth and the front is a 15 tooth
so fitting a 13tooth front and a 43tooth rear will be a substantial increase in accelleration...
my question is, is it wise to got for a 13tooth front sprocket judging by the 15tooth on the front which i thought was a 13tooth and would that make my bike rev out? i dont mind losing a little top-speed but surly this change will incur problems... or will it be fine?
cheers for your replys guys  ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine. |
| stevo as b4 |
| befdelta7 |
| Marci |
 Marci Brolly Dolly
| befdelta7 |
 Posted: 15:05 - 15 Jan 2007 Post subject: |
cheers for that Marci
from what i can understand about it, it means when accelerating a slight bump in the road could cause the front wheel to lift slightly. am i correct or have i not fully understood the meaning of it?
also any tips for fitting a new chain and sprockets:
any easy ways of doing it?
any particular part needed to be fitted first?
any things to watch out for when fitting or fitted and taking the bike out for the first time?
cheers for your replys boys! ____________________ Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine. |
| befdelta7 |
The last post was made 19 years, 1 day ago. Instead of replying here, would creating a new thread be more useful? |
