Glowing pipes
-Savage-
PostPosted: 21:27 - 17 Dec 2006    Post subject: Glowing pipes Reply with quote
Im not too sure if this is normal, but it just came to mind and i thaught i might as well ask.
When i have me fairing off and the engine running, if i rev her away, and leave it running for a while, when i open the throtle, the manifold pipes glow bright red, its kinda offputting incase they melt or something? is this normal ?
Jebus
PostPosted: 21:48 - 17 Dec 2006    Post subject: Reply with quote
well yes they will glow, and they dont have a load of air flowing over them to cool em, they wont melt, no need to worry about that.
2nd time around Smile CBT: 8/9/11
125 Varadero
BanditsHigh
Worse than a woman
PostPosted: 14:49 - 18 Dec 2006    Post subject: Reply with quote
They should get very hot, but glowing I'd have said no.
Seen this before when the mixture on a mates bike was too lean ... I'd get it checked out to be on the safe side ... if the engine is running lean then it'll damage valves/pistons.
All the best ... Barry
bladerunner
PostPosted: 17:23 - 18 Dec 2006    Post subject: Reply with quote
They should not be glowing hot...sure sign that something is amiss
0ddball
PostPosted: 17:45 - 18 Dec 2006    Post subject: Reply with quote
Nothing to worry about generally though as said, if they glow excessively it could be due to running lean or even too rich. Get it checked on a rolling road if you're concerned. If you have an infrared thermometer this can give a good idea of the mixture strength.
Jebus
PostPosted: 21:45 - 18 Dec 2006    Post subject: Reply with quote
how much and for how long do you rev it? if you do it for 2 long they will glow, but i dont think that it should at idle.
125 Varadero
joe black
PostPosted: 00:44 - 19 Dec 2006    Post subject: Reply with quote
germans used to do this with their bmw at gps they called it red piping , very entertaining when you,re pissed.
PostPosted: 00:50 - 19 Dec 2006    Post subject: Reply with quote
Thrash it and yes they will glow red, but wouldn't expect that it to do that when just revved a bit.
Running lean or ignition timing wrong are the most likely causes.
sickpup
Old Timer
PostPosted: 06:10 - 19 Dec 2006    Post subject: Reply with quote
Had this on a pigsarsehole (Pegaso) the carb balance caps were holed.
Took ages to work out.
The last post was made 19 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 59.36 Kb
