Oxford Hot Hands instructions
Cruiser
PostPosted: 19:50 - 21 Dec 2006    Post subject: Oxford Hot Hands instructions Reply with quote
Hey everyone,
Ive just bought some Oxford Hot hands heated grips, went to go and fit them to the bike.. and the guy who sold me them forgot to put the instructions back in the packet after showin me the grips lol.
Does anyone know where i can get an online version of the instructions? Ive looked on www.oxprod.com but they aint got the instructions for the hot hands, any help much appreciated!!!!
Cheers,
James Smile
cheekythomas
PostPosted: 19:52 - 21 Dec 2006    Post subject: Reply with quote
All you need is to wire up the power supply direct to the battery.. Rest are on plug in fittings so you cant go wrong. Laughing
kawakid
PostPosted: 22:44 - 21 Dec 2006    Post subject: Reply with quote
True.
But if you wanted to do a prof job, you would want to rig up a relay and it would stop your battery going flat if left on.
I've a twin and a 4.
Cruiser
PostPosted: 23:14 - 21 Dec 2006    Post subject: Reply with quote
thanks, i`ll wire them up an see how it goes!!!
is that the same as wiring it to the ignition?
i was gonna wire it to the battery cos i know absolutley nothing about electrics, and just make sure i turn them off wen engine aint runnin lol.
PostPosted: 23:17 - 21 Dec 2006    Post subject: Reply with quote
You could wire them to a circuit that is powered when the ignition is on but that is a fair extra load on a circuit that might not take it.
Personally I would use a relay (basically an electrically operated switch. You feed power to the relay directly from the battery and earth the grips directly to the battery. However you trigger the relay with a feed from a circuit that is only powered when the ignition is on (such as the feed for the brake light switch). This way the extra load on an existing circuit is tiny.
Trouble is you will forget, or some kid will play.
Cruiser
PostPosted: 23:21 - 21 Dec 2006    Post subject: Reply with quote
i`ll look into the relays ta mate, i seriosly have no idea about doing that but sounds a better idea lol. the guy i bort them off said could wire it to the horn, but thought maybe the horn wudnt be as loud if i needed it an they were switched on, cheers for the help mate much apreciated Very Happy Very Happy Very Happy
PostPosted: 23:26 - 21 Dec 2006    Post subject: Reply with quote
Depends on the horn. Some just have a single wire and earth through the body of the horn, and these will only get power when the horn button is pressed. Some (most) have 2 wires, but may not have power all the time, only being fed when the button is pressed, while some will have power all the time and have the switch on the earth side.
Personally I tend to use the power feed for the rear brake light switch.
PostPosted: 00:28 - 22 Dec 2006    Post subject: Reply with quote
I wired mine directly to the battery, but a mechanic said to wire it into the rear brake light. Hopefully I can convince my dad to do it.
crazymotorbik...
PostPosted: 00:37 - 22 Dec 2006    Post subject: Reply with quote
I always wire all my stuff through the horn. Im not sure what bike you have but all my kawasakis have had a black wire that runs to the horn. This wire provides 12v when the igntion is on but once the ignition is off then the wire is 0v. Using this wire has no noticeable effect on the loudness of the horn.
Heres a diagram i used today to wire my oxford heated grips in, i slightly modified it, but u'll get the idea:
www.pcforge.co.uk/bike/improved_wiring.jpg
I used the optimate connector so that when i need to charge my battery all i have to do is unclip my heated grips and clip in my optimate charger.
Cheers,
Shaun.
Cruiser
PostPosted: 22:38 - 17 Jan 2007    Post subject: Reply with quote
ta for the help, its wired upto the battery now but gonna have to change it round when i get the time, works fine tho! thanks for the help Very Happy
The last post was made 19 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 67.24 Kb
