Yamaha DT overheating problem
ashleybarber5...
PostPosted: 17:41 - 02 Aug 2003    Post subject: Yamaha DT overheating problem Reply with quote
Hi,
My problem is that when I am riding my Yamaha DT 125R, It over heats. When I take a look in the radiator, there is nothing in there because it as overflowed out of the radiator expansion pack on the back of the bike. Please can you tell me why this is happening and how to fix it.
P.S My friend told me it was my water pump propellers. Is this true???
Thanks
PostPosted: 18:37 - 02 Aug 2003    Post subject: Reply with quote
Well if there nothing in there, put some water and some coolant in Rolling Eyes
ashleybarber5...
PostPosted: 19:55 - 02 Aug 2003    Post subject: Reply with quote
I ment i fill it up with water, then go out!
PostPosted: 19:57 - 02 Aug 2003    Post subject: Reply with quote
Well if its going out the overflow then its full i would think?
Is it going straight out the overflow when you pour water into the radiator? Or after you have taken it for a ride
ashleybarber5...
PostPosted: 20:01 - 02 Aug 2003    Post subject: Reply with quote
when i take it out for a ride
ashleybarber5...
PostPosted: 20:04 - 02 Aug 2003    Post subject: Reply with quote
but when i put water in it, it isn't over full
PostPosted: 15:40 - 03 Aug 2003    Post subject: Reply with quote
Check for air bubbles in the system. These will stop the water circulating and cause it to overheat. Check the radiator cap is on properly. Also check that the head gasket isn't blown as the engine will then suck in loads of water
ashleybarber5...
PostPosted: 16:54 - 03 Aug 2003    Post subject: Reply with quote
thanks KICKSTART
Very Happy
Ropehead
PostPosted: 11:30 - 04 Aug 2003    Post subject: Reply with quote
if all that fails, check the impella its on the righ hand side on the gear box bit. u remove a strange shaped part of the gearbox (about the size of a large pair (fruit that is).
this is just from memory so it might be on the left hand side Razz
ashleybarber5...
PostPosted: 18:27 - 04 Aug 2003    Post subject: Reply with quote
and what should i look for??
The last post was made 23 years, 80 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 59.95 Kb
