Gilera Stalker Derestricting
 Topic moved: from Forum Feedback & Help to The Workshop by EuropeanNC30Rider (2 Jan 2007 - 20:51)
DaBootnoze
PostPosted: 20:56 - 02 Jan 2007    Post subject: Gilera Stalker Derestricting Reply with quote
Just wondering if anyone could give me sum guidelines to derestrict my gilera stalker i have removed the washer behind the variator and this gave me a top speed of 35mph i have heard of a brass plate at the mouth of the carb or in the air box but am unsure of where it is and what to do and if i will need to jett it up
thx Mr. Green help much appreciated Laughing how else can i derestrict it as it gets to 35 and goes flat thankyou Very Happy
cheekythomas
PostPosted: 22:21 - 02 Jan 2007    Post subject: Reply with quote
There is a brass plate fitted to the carb where the airbox inlet is fitted but its not there as a restriction, its there to cause a negative pressure in the inlet manifold and shouldnt be removed unless your doing more than a normal derestriction.
You need to remove the washer from the variator like youve done, remove the resonator pipes from the exhaust and weld up the holes, then upjet it.... It should now do a clock speed of about 50-55mph
Being a stalker which is a update of the SKP it should already have the Dellorto 17.5mm carb not the older 14mm weber... If so it will have a 53 main fitted as std but needs a 60... which will also stop the whiteness on the end of the standard exhaust Wink
DaBootnoze
PostPosted: 12:37 - 03 Jan 2007    Post subject: Reply with quote
thankyou you helped me out a lot i wont remove that plate i just want a simple restriction my gilera also has a performance exhaust and rollers is there still a resonator pipe? will a k+n air filter help at all Mr. Green my old filter is holding back so i tried it without one and it improved a lot but stuttered when i first pull away will a k+n be ok your a great help much appreciated Thumbs Up
beatnck
PostPosted: 12:41 - 03 Jan 2007    Post subject: Reply with quote
k and n filter might help, but you would have to rejet the carb, otherwise it will run lean and seize Thumbs Up
DaBootnoze
PostPosted: 12:43 - 03 Jan 2007    Post subject: Reply with quote
thankyou should i upjet my main jet to a 70 with a k+n? Thumbs Up Mr. Green
cheekythomas
PostPosted: 14:37 - 03 Jan 2007    Post subject: Reply with quote
No if its a race exhaust it wont have a resonator pipe... Did you fit the pipe?? If so... did you make sure there wasnt a restrictor tack-welded into the downpipe to make it E-marked??
I would stay clear of open filters on 2 strokes, especially at this time of year as they hate the damp... Yes it will need upjetting if you fit a open filter but it will need to be much bigger than a 70, however no-one will be able to tell you what size as it varys... last DNA i fitted one to went from std 53 to a 105 Shocked
If you want to improve the airflow a little then take the rubber inlet snorkle out of the airbox, youll need to upjet to suit Wink
DaBootnoze
PostPosted: 15:15 - 03 Jan 2007    Post subject: Reply with quote
thankyou is that all that restricts it then? i was thinking about a big bore kit like a 70 but am unsure what to go for any ideas your a brilliant help and you explain it so well Thumbs Up Mr. Green
DaBootnoze
PostPosted: 15:19 - 03 Jan 2007    Post subject: Reply with quote
i did not fit the exhaust will the bore kit improve top end as acceleration is brilliant but it does die about 35mph Sad Mr. Green
cheekythomas
PostPosted: 21:52 - 04 Jan 2007    Post subject: Reply with quote
You sure you removed the variator restrictor if its only doing 35mph?? It should be another 10mph on top of that??
DaBootnoze
PostPosted: 23:13 - 04 Jan 2007    Post subject: Reply with quote
yes i have i took the variator cover off got a variator tool and took the variator off and got the washer off. I also had the pipe fitted with rollers. but it reaches 35mph then dies seems weird to me aswell lol Confused does the pipe have a slight restriction in it even though it is a sports pipe? Smile
cheekythomas
PostPosted: 21:28 - 05 Jan 2007    Post subject: Reply with quote
If you took the ring off on the variator and its only doing 35mph theres something wrong for sure.
Take the exhaust off and make sure theres no restrictor on the downpipe... what make of pipe is it??
Also make sure you have upjetted it or it will be killing itself everytime you start it up Wink
Timmeh
PostPosted: 21:30 - 05 Jan 2007    Post subject: Reply with quote
Perhaps you should just buy a 125 sports scooter.
Safer in the long-run.
DaBootnoze
PostPosted: 20:30 - 06 Jan 2007    Post subject: Reply with quote
the pipe is a "kunda" Razz
cheekythomas
PostPosted: 22:15 - 06 Jan 2007    Post subject: Reply with quote
Kundos are decent pipes...
I would say its still restricted, and as youve not mentioned upjetting STILL i would also say running dangerously lean.
Is acceleration good?? Or slow as well??
DaBootnoze
PostPosted: 14:33 - 08 Jan 2007    Post subject: Reply with quote
acceleration is good but i have not upjetted yet do you reckon it will help it's top speed? Confused
cheekythomas
PostPosted: 11:32 - 09 Jan 2007    Post subject: Reply with quote
Dont worry aboutm speed... if youve not upjetted it, it will be lean and killing itself!
DaBootnoze
PostPosted: 12:00 - 09 Jan 2007    Post subject: Reply with quote
what are you saying I need to upjet it as it is killing itself or i shoudn't?
PostPosted: 12:10 - 09 Jan 2007    Post subject: Reply with quote
Yes he's saying you need to upjet or the motor will seize because it's running dangerously lean. UPJET UPJET UPJET!
There is a gap of 1 year, 126 days between these two posts...
grant-fox
PostPosted: 12:45 - 14 May 2008    Post subject: Reply with quote
hi there, i have a 2005 gilera stalker it has a pm tuning stage 6 boost bottle and a leo vince tt pipe, it also has the variator spacer removed, that is all that has been done to it, is there anything i can do to make it go faster and is there anything that NEEDS doing to maintaine its wellfare ?
please help
my email is [email protected]
many thanks
grant
There is a gap of 351 days between these two posts...
bradh511
PostPosted: 01:04 - 01 May 2009    Post subject: Gilera Stalker Nkd Reply with quote
hi there i am new to the forum i have a 2008 gilera stalker nkd it has done approx 7,500 miles not km wich i know is hi millage (daily run about ) thinking about derestricting mine as am fed up of the 29 ish mph how much would takeing the variator washer off get me up to in mph. Im then thinking of getting race or sports pipe and k&n air filter and rejetting it im wondering what sort of speeds this would do ? tbh im not exspecting nothing major and i need to wait to get some money i will do the free things frist Smile any other surgestions
There is a gap of 226 days between these two posts...
leescott09
PostPosted: 22:40 - 13 Dec 2009    Post subject: Reply with quote
!!!!!!!!!GILERA STALKER!!!!!!!
i,ve just brought a 55plate GILERA STALKER 50cc
its been derestricted it went 60 mph 3-4 years ago but has been locked up in a garage since then
what should i do to get it back up to that, also what should i get for performance wise other than leo vince tt and rollers
cheers
stalker94 This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
There is a gap of 1 year, 206 days between these two posts...
mazzda-007
PostPosted: 22:59 - 14 Aug 2011    Post subject: Reply with quote
i have a 2004 stalker. i put a leo vince zx exhuast on it and have upjetted from the standard 53 to a 60 jet.
im getting around 40mph at the moment but hoping can get more when i upgrade the rollers (dont no what weight any ideas) cluth springs and variator spring (all on ebay) hoping to get quicker speed once all this is done.
btw if u dont upjet the piston goes threw the roof of the engine (no from experiance) so defo upgrade from a 53 upto 60 jet!
gilera stalker 50cc going on gsxr 1000 i hope Razz
Nope.
PostPosted: 23:23 - 14 Aug 2011    Post subject: Reply with quote
The last post in this thread was from january 2010. I think if his engine was going to blow up it would have done so by now.
Also, just for reference, there is no way in hell you could get 65 on the flat from ANY derestricted CVT 50 without some serious performance mods. God I hate Ped Boi's Evil or Very Mad
The last post was made 15 years, 64 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.21 - MySQL Queries: 16 - Page Size: 123.81 Kb
