| DaBootnoze |
 DaBootnoze Derestricted Danger
 Posted: 20:56 - 02 Jan 2007 Post subject: Gilera Stalker Derestricting |
Just wondering if anyone could give me sum guidelines to derestrict my gilera stalker i have removed the washer behind the variator and this gave me a top speed of 35mph i have heard of a brass plate at the mouth of the carb or in the air box but am unsure of where it is and what to do and if i will need to jett it up
thx help much appreciated how else can i derestrict it as it gets to 35 and goes flat thankyou  |
| cheekythomas |
 cheekythomas Crazy Courier
 Posted: 22:21 - 02 Jan 2007 Post subject: |
There is a brass plate fitted to the carb where the airbox inlet is fitted but its not there as a restriction, its there to cause a negative pressure in the inlet manifold and shouldnt be removed unless your doing more than a normal derestriction.
You need to remove the washer from the variator like youve done, remove the resonator pipes from the exhaust and weld up the holes, then upjet it.... It should now do a clock speed of about 50-55mph
Being a stalker which is a update of the SKP it should already have the Dellorto 17.5mm carb not the older 14mm weber... If so it will have a 53 main fitted as std but needs a 60... which will also stop the whiteness on the end of the standard exhaust  |
| DaBootnoze |
 Posted: 12:37 - 03 Jan 2007 Post subject: |
thankyou you helped me out a lot i wont remove that plate i just want a simple restriction my gilera also has a performance exhaust and rollers is there still a resonator pipe? will a k+n air filter help at all my old filter is holding back so i tried it without one and it improved a lot but stuttered when i first pull away will a k+n be ok your a great help much appreciated  |
| beatnck |
 beatnck Could Be A Chat Bot
 Posted: 12:41 - 03 Jan 2007 Post subject: |
k and n filter might help, but you would have to rejet the carb, otherwise it will run lean and seize  |
| DaBootnoze |
 Posted: 12:43 - 03 Jan 2007 Post subject: |
thankyou should i upjet my main jet to a 70 with a k+n?  |
| cheekythomas |
 Posted: 14:37 - 03 Jan 2007 Post subject: |
No if its a race exhaust it wont have a resonator pipe... Did you fit the pipe?? If so... did you make sure there wasnt a restrictor tack-welded into the downpipe to make it E-marked??
I would stay clear of open filters on 2 strokes, especially at this time of year as they hate the damp... Yes it will need upjetting if you fit a open filter but it will need to be much bigger than a 70, however no-one will be able to tell you what size as it varys... last DNA i fitted one to went from std 53 to a 105
If you want to improve the airflow a little then take the rubber inlet snorkle out of the airbox, youll need to upjet to suit  |
| DaBootnoze |
 Posted: 15:15 - 03 Jan 2007 Post subject: |
thankyou is that all that restricts it then? i was thinking about a big bore kit like a 70 but am unsure what to go for any ideas your a brilliant help and you explain it so well  |
| DaBootnoze |
 Posted: 15:19 - 03 Jan 2007 Post subject: |
i did not fit the exhaust will the bore kit improve top end as acceleration is brilliant but it does die about 35mph  |
| cheekythomas |
| DaBootnoze |
 Posted: 23:13 - 04 Jan 2007 Post subject: |
yes i have i took the variator cover off got a variator tool and took the variator off and got the washer off. I also had the pipe fitted with rollers. but it reaches 35mph then dies seems weird to me aswell lol does the pipe have a slight restriction in it even though it is a sports pipe?  |
| cheekythomas |
 Posted: 21:28 - 05 Jan 2007 Post subject: |
If you took the ring off on the variator and its only doing 35mph theres something wrong for sure.
Take the exhaust off and make sure theres no restrictor on the downpipe... what make of pipe is it??
Also make sure you have upjetted it or it will be killing itself everytime you start it up  |
| Timmeh |
 Timmeh World Chat Champion
| DaBootnoze |
 Posted: 20:30 - 06 Jan 2007 Post subject: |
the pipe is a "kunda"  |
| cheekythomas |
| DaBootnoze |
 Posted: 14:33 - 08 Jan 2007 Post subject: |
acceleration is good but i have not upjetted yet do you reckon it will help it's top speed?  |
| cheekythomas |
| DaBootnoze |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 12:10 - 09 Jan 2007 Post subject: |
Yes he's saying you need to upjet or the motor will seize because it's running dangerously lean. UPJET UPJET UPJET! ____________________ My Flickr |
There is a gap of 1 year, 126 days between these two posts... |
| grant-fox |
 grant-fox L Plate Warrior
There is a gap of 351 days between these two posts... |
| bradh511 |
 bradh511 Scooby Slapper
 Posted: 01:04 - 01 May 2009 Post subject: Gilera Stalker Nkd |
hi there i am new to the forum i have a 2008 gilera stalker nkd it has done approx 7,500 miles not km wich i know is hi millage (daily run about ) thinking about derestricting mine as am fed up of the 29 ish mph how much would takeing the variator washer off get me up to in mph. Im then thinking of getting race or sports pipe and k&n air filter and rejetting it im wondering what sort of speeds this would do ? tbh im not exspecting nothing major and i need to wait to get some money i will do the free things frist any other surgestions |
There is a gap of 226 days between these two posts... |
| leescott09 |
 leescott09 L Plate Warrior
| stalker94 |
This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
 stalker94 L Plate Warrior
 Posted: 22:20 - 20 Jan 2010 Post subject: stalker |
[b]i brought a 04 stalker the otha week all i have done is take the gold ring ut of carb gianelli race pipe n 4 gram rollers n i can touch 70 down hill n around 65 on a flat so i fink theres somthin goin seriously rong on yours m8 [/b] |
There is a gap of 1 year, 206 days between these two posts... |
| mazzda-007 |
 mazzda-007 Two Stroke Sniffer
 Posted: 22:59 - 14 Aug 2011 Post subject: |
i have a 2004 stalker. i put a leo vince zx exhuast on it and have upjetted from the standard 53 to a 60 jet.
im getting around 40mph at the moment but hoping can get more when i upgrade the rollers (dont no what weight any ideas) cluth springs and variator spring (all on ebay) hoping to get quicker speed once all this is done.
btw if u dont upjet the piston goes threw the roof of the engine (no from experiance) so defo upgrade from a 53 upto 60 jet! ____________________ gilera stalker 50cc going on gsxr 1000 i hope  |
| Nope. |
 Nope. World Chat Champion
The last post was made 15 years, 67 days ago. Instead of replying here, would creating a new thread be more useful? |
