Can it be this thirsty?
Korn
Admin
PostPosted: 20:54 - 04 Aug 2003    Post subject: Can it be this thirsty? Reply with quote
After fitting the jet kit to the storm last week and advancing the ignition this weekend, I've noticed a strange problem.
When you're twatting it at full throttle for about a minute, it will start to run out of fuel. Let off for a few seconds and it's back to normal. It's as if it's drinking the float bowls dry faster than they can fill up again. It runs normally otherwise, this only ever happens when keeping it absolutely pinned on the motorway (160+). Is it really drinking the fuel this quick? So far it's done 90 miles on a full tank and no evil orange light of doom, so if anything it's as if the mileage has improved.
Me is confused Shocked. Anyone have a clue?
(Apart from that I'm loving it, there's a real top end rush to it now and the arse-o-meter pronounces it phucking quick)
3516 Miles, 11 Countries
TiN
Pocket Tin
PostPosted: 20:57 - 04 Aug 2003    Post subject: Re: Can it be this thirsty? Reply with quote
Kornel wrote:
So far it's done 90 miles on a full tank...so if anything it's as if the mileage has improved.
TiN
dotgems.net
Zimma
Wheelie Junkie
PostPosted: 20:59 - 04 Aug 2003    Post subject: Reply with quote
Korn, remove that mans 'lellow karma and give it to me... He just doesn't know the way of the 'Storm. Silly Farterblade rider. Wink Razz Very Happy
-Zimma
Robby
Dirty Old Man
blocked fuel filter or kinked fuel line?
kev
I Hump Things
PostPosted: 22:40 - 04 Aug 2003    Post subject: Reply with quote
does the bike have a fuel pump?
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
Korn
Admin
PostPosted: 23:01 - 04 Aug 2003    Post subject: Reply with quote
Nope, plain old gravity.
Hmmm, maybe I should chuck the gokart fuel pump on there and see what happens Question
kev
I Hump Things
PostPosted: 23:02 - 04 Aug 2003    Post subject: Reply with quote
what is that pump from?
Korn
Admin
PostPosted: 23:03 - 04 Aug 2003    Post subject: Reply with quote
I don't have a clue where it came from.
kev
I Hump Things
PostPosted: 23:04 - 04 Aug 2003    Post subject: Reply with quote
do you know the flow it puts out?
TiN
Pocket Tin
PostPosted: 23:18 - 04 Aug 2003    Post subject: Reply with quote
So does the bike feel as though it's running out of fuel whilst the throttle is pinned? Or as soon as you release it?
Maybe a run and tweak on a Dyno would be a good idea?
TiN
dotgems.net
Korn
Admin
PostPosted: 23:27 - 04 Aug 2003    Post subject: Reply with quote
While pinned. But only if you've had it pinned for about a minute, anything shorter and it's fine.
Nope. Though I'm not really considering putting it on the storm, it's home will be on the gokart. Looking through a few mailing list archives people have had similar problems, which apparently go away if you bolt on a cbr600 fuel pump. I wonder if I can find a cbr600 anywhere around here, parked on the street 'n that Wink
kev
I Hump Things
PostPosted: 00:44 - 05 Aug 2003    Post subject: Reply with quote
well if the blade gets scrapped you can buy the fuel pump from that for a tenner.
TiN
Pocket Tin
PostPosted: 01:18 - 05 Aug 2003    Post subject: Reply with quote
Oh yeah, and I assume that you've made the appropriate airbox/filter mods?
TiN
dotgems.net
kev
I Hump Things
PostPosted: 01:20 - 05 Aug 2003    Post subject: Reply with quote
he has.
I think the bike is trying to tell you something... feed me!!! Razz Razz
Is mid ride refueling a possibily yet? Razz
Korn
Admin
PostPosted: 00:49 - 07 Aug 2003    Post subject: Reply with quote
Hmmm, it's stopped doing it now Rolling Eyes
I very nearly punched it tonight 'cos it kept blowing fuses, but then I found out it was actually my fault and apologised profusely.
It rewarded me with just shy of 175mph, I love this bike Laughing
PostPosted: 00:51 - 07 Aug 2003    Post subject: Reply with quote
175mph. Not bad Smile
Have to be seeing how it goes on the strip Very Happy
and fuses blowing... dont get me started Sad
Korn
Admin
PostPosted: 01:00 - 07 Aug 2003    Post subject: Reply with quote
Where did you get that funky circuit breaker type fuse (not sure if it was you I saw with it)?
I traced my problem to a trapped wire earthing on the frame where I had been in a hurry to fit the clocks back on and buggered the insulation, but it took about 20 fuses and finding and unplugging every other thing attached to that circuit Shocked
PostPosted: 01:05 - 07 Aug 2003    Post subject: Reply with quote
RS.
I can bring one along to BdB if you want.
Though the ones I've got at the mo are a bit bigger than the one ste had.
Korn
Admin
PostPosted: 01:06 - 07 Aug 2003    Post subject: Reply with quote
It should be fine (touches desk), I've stocked up on spares. Your kwak fuses are bigger anyway, aren't they?
PostPosted: 01:26 - 07 Aug 2003    Post subject: Reply with quote
Bought a few of those from Demon Tweeks before now
Quite useful
PostPosted: 08:22 - 07 Aug 2003    Post subject: Reply with quote
Oh yea, forgot you use mini-blade fuses, bloody weirdo thingamies.
You can't get ciruit breakers in that size. It is however possible to wire up something with a normal sized blade fuse holder that plugs into the fuse socket.
The last post was made 23 years, 63 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 113.68 Kb
