| matthab |
 matthab Crazy Courier
| Jebus |
 Jebus Brolly Dolly
 Posted: 22:56 - 02 Jan 2007 Post subject: |
they rekon about every 300-500 miles for lubing your chain, you can use engine oil if you want its cheap but not that good, most people use a chain lube most car parts palce will sell it, you just spray it on the chain ideally when its clean and after a ride when its warmer. ____________________ 2nd time around CBT: 8/9/11
125 Varadero |
| mr.z |
 mr.z World Chat Champion
 Posted: 22:58 - 02 Jan 2007 Post subject: |
I'd reccomend a good spray on type lube.. thicker stuff tends to stay on longer
+You should really be oiling it every ride, or every other day, and allways do it AFTER going for a ride, the chain absorbs the lubricant far better when its warmed up.
400miles with no attention you should look at makeing sure its adjusted right as well  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| matthab |
| mr.z |
 Posted: 23:01 - 02 Jan 2007 Post subject: |
Is it enclosed?
Yeh, you can use 3in1 oil, but it wont stay on long.. halfords do their own brand which was very good (if a bit messy) ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| JakeyR |
 JakeyR World Chat Champion
| Stiffler |
 Stiffler World Chat Champion
 Posted: 23:11 - 02 Jan 2007 Post subject: |
I bought a 1 litre bottle of Halfords GL-4 Gear Oil for my YBR. It's a tiny bit thicker than 3 in 1 but still needs regular applications. I've used it for the past 1300 miles there is still 3/4 of the bottle left and the chain is oiled after every other ride or every ride in the rain.
I tried some of the spray on Teflon stuff but It doesn't seem to be good value for money.
Tim ____________________ Current Bikes - Kawasaki ZX-6R (636) | BMW G650GS |
| matthab |
 Posted: 19:51 - 03 Jan 2007 Post subject: |
I went into halfords today in worcester (wow never thought that end of town had so many chavs). And got hold of some holts universal chain oil (or something along those lines).
My next door neibour recommended i do it with the bike on the centre stand and the back wheel rotating in 1st gear. THis worked pretty well as i sprayed it on the chain as it rotates. I checked the chain tension and it was 22mm on average (manual states between 20 -30mm) i took that from 3 points on the chain to find tight spots etc.
i just have some last questions:
1. How do i know when to lubricate my chain and when its got enough on it?
2. Is there any other running care i should do?
sorry ive been using a scooter for a year or so, and im no wizz at motorbikes (why im here i suppose)  ____________________ 2005 - 2006:Peugeot jet force 50 TDSI (sold)
2006 - Present: Yamaha YBR125 06 (extras:pilot sporty tyres and screen) |
| mr.z |
| matthab |
 Posted: 20:01 - 03 Jan 2007 Post subject: |
yep  ____________________ 2005 - 2006:Peugeot jet force 50 TDSI (sold)
| cestrian |
 cestrian World Chat Champion
| element |
 element World Chat Champion
 Posted: 21:58 - 03 Jan 2007 Post subject: |
I do mine every 200 miles or so. I used to use castrol chain wax (£6 a can!) but I wont be using any wax lub again. Its pretty useless as the wax gets pushed to points on the chain and sprockets that have no wear (tips of the spocket teeth etc) leaving the areas that have a lot of wear with no lube at all!
Im using 151 (I think it is... some cheap hardware store brand) spray grease. Its white (so looks like proper chain lube ), doesnt fling off, costs all of £2 and seems to be better than the wax type lube.
Anyhow I dont even really need to look after my chain because chain and sprocket sets for my bike are dirt cheap!  ____________________ 04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME... |
| beatnck |
 beatnck Could Be A Chat Bot
 Posted: 22:24 - 03 Jan 2007 Post subject: |
as said, we all start somewhere mate! as your local we should get together for a rideout, i can help you out with the maintenance side of things too  |
| syl |
 syl World Chat Champion
| short1uk |
 short1uk World Chat Champion
 Posted: 09:39 - 04 Jan 2007 Post subject: |
I got from Halfrauds for my YBR some spray on chain lube in the motorbike section which is like a wax almost which sticks on the chain instead of flying off. It was spot on. Juyst put the bike on the main stand put a cloth behind the chain and got my missus to rotate the rear wheel while i sprayed. Jobs a good un!
Its was in a yellow / purple can,
https://www.halfords.com/wcsstore/HalfordsConsumerDirect/images/catalog/200-228098.jpg
bit like that but halfords own one and a wax easy to find if you have a gander on the motorbike section |
| matthab |
 Posted: 13:45 - 04 Jan 2007 Post subject: |
thats the exact stuff i bought!  ____________________ 2005 - 2006:Peugeot jet force 50 TDSI (sold)
| short1uk |
| Keir |
 Keir World Chat Champion
 Posted: 15:43 - 04 Jan 2007 Post subject: |
ive currently got some "new formula" castrol chain wax. its rubbish. ____________________ Current : '08 Yamaha FZ1s
Previous: '99 Honda CBR 600FX, 03 ZX636 B1H, 99 Fazer 600 (red), 02 GSX-R 600 K2, 00 SV650s (red), 2008 ZX10R, 97 Bandit 1200N, 04 ZX6RR K1H, 04 GSX-R 1000, 98 Fazer 600 (gold), 05 Madness 110 Pit bike, 04 CR125R, 00 SV650s (black), 06 KTM 625 SMC, 99 SRAD 600 track bike, 03 SV650, 98 Bandit 1200N, Bandit 600SY, 03 GSX-R 600 K3, 01 GSX-R 600, 01 Fazer 600 (black), VFR 400 NC30 x3, 78 Honda Dream, 00 Speedfight 50 |
| strag |
 strag World Chat Champion
| matthab |
| djneu-trix |
 djneu-trix Spanner Monkey
 Posted: 03:31 - 06 Jan 2007 Post subject: |
a lad that works in our local garage oiled his chain (like as above) and had his thumb ripped off round the sprocket!!!
sounds mad but u only have to slip slightly and bang! your thumb has gone! never to be seen again!!!!
 ____________________ pg |
| Grav |
 Grav World Chat Champion
 Posted: 04:41 - 06 Jan 2007 Post subject: |
| matthab wrote: |
sorry ive been using a scooter for a year or so, and im no wizz at motorbikes (why im here i suppose)  |
Good to see another young person on the road Matt, here's some advice from a chap who's been riding for 20 odd years.
Before you ride you should check that your lights, brake lights, horn and indicators are all working properly, it only takes a minute, I do mine when the bike is warming up.
Once a week give your bike a good check over, you can do this when you are cleaning it and it gets two jobs done at once.
Check your tyres for any cracks, splits, foreign objects and tread depth. There is a wear indicator in the tread as a guide. Also check the tyres are pumped up to the correct pressure for the bike. Your manual/owners handbook should give you the figures and most supermarket garages have a FREE air line.
Check your chain for tension and lubricate it as the good folks here have described already.
Check your engine oil level. Put the bike on the center stand on a flat, level surface, there is usually a sight glass in the engine casing that tells you how much is in and top it up to the full level if needed. You should also change the oil regularly. I do mine every 3000 miles but some folks do it earlier.
Check your brakes are working properly. Takes but a moment to pick it up off the side stand, apply the front brake fully on and push. The bike should not move. For the back brake, put the bike on its center stand, push the brake pedal down fully with one hand and try to move the back weheel with the other. Again, it should not be possible to move it.
All the above can be done in less than an hour if you take your time, and you will always keep on top of your bike maintenance.
Ride safe. |
| Finglonga |
 Finglonga World Chat Champion
 Posted: 12:18 - 06 Jan 2007 Post subject: |
Feck this fangled chain loob! In the good old days I used to take the chain off and put it in a heated tin of chain grease to make sure it got in every nook and cranny. There was none of this spray stuff available.  ____________________ Andy Sez....
F.Y.Y.F.F. |
| Grav |
 Posted: 21:03 - 06 Jan 2007 Post subject: |
Is that stuff still available? I haven't seen it in years but I most definitely remember the rollocking off my mum for stinking the kitchen out.  |
| strag |
The last post was made 19 years, 134 days ago. Instead of replying here, would creating a new thread be more useful? |
