Changing a sidelight
Crash it for fun
PostPosted: 22:39 - 04 Aug 2003    Post subject: Changing a sidelight Reply with quote
One of the bulbs has gone in the headlights and I want to replace it. It is only a sidelight so not urgent but annoying because it only lasted 4 months. I can't take it back to the shop because of a separate issue regarding the police. How much of my bike do I need to take apart to get into the front light cluster?
if it helps the bulb looks like this Idea
McJamweasel
BCF Junkie
PostPosted: 22:40 - 04 Aug 2003    Post subject: Reply with quote
What bike?
Crash it for fun
PostPosted: 22:41 - 04 Aug 2003    Post subject: Reply with quote
sorry, NSR-125R 2003
kev
I Hump Things
PostPosted: 09:50 - 05 Aug 2003    Post subject: Re: Changing a sidelight Reply with quote
did you steal the bike or something?
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
one1895
I liked BCF so much I made my own copy
PostPosted: 16:06 - 05 Aug 2003    Post subject: Reply with quote
Take both front lower fairings off each side, then slip off the front upper fairings with the screen attached. You should see your headlight unit - this should pop off but make sure you undo the wire clip before doing so. Take off the rubber socks on the back of the unit and then you can twist the plastic bit out which the bulb is attached to. If it's the other bulbs you need to replace then just pull and they'll come out.
Cam.
Hull & Yorkshire Bikers - Sheffield & Yorkshire Bikers - Manchester Bikers - Nottingham Bikers
Kris
PostPosted: 16:11 - 05 Aug 2003    Post subject: Reply with quote
you can get to the headlights by turning the steering on full lock and reaching inside the front subframe. The lights will have 2 rubber moulds over them. Pull them off and twist the light holders 60-90 degrees anti-clockwise and they will come off. Easy peasy and no need for fairing removal.
www.prisonplanet.com
Crash it for fun
PostPosted: 17:10 - 05 Aug 2003    Post subject: Reply with quote
Cheers mates!
I didn't nick it and don't think that I could take another NSR boy's pride and joy. I lost my licence 2 months back because I was 2mg of alcohol over the limit! GUTTED!!!!
I also need to get a new shut off valve fitted too and can't ride it back to the shop until march next year. DOUBLE GUTTED!!!!
The last post was made 22 years, 232 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 52.76 Kb
