cant get rs125 to start
dransy
PostPosted: 14:46 - 07 Jan 2007    Post subject: cant get rs125 to start Reply with quote
So ive put my bike back together , new spark plug , checked for a spark and its sparking really well but it wont start the starter motor just turn and turns and it wont start up
any ideas?
cheers
finpos
PostPosted: 14:52 - 07 Jan 2007    Post subject: Reply with quote
Is it getting fuel (plug should be wet-looking after a bit of churning the engine)?
Did you take the engine apart? If so you might have made a boob of the timing.
finpos.
Whosthedaddy
PostPosted: 14:54 - 07 Jan 2007    Post subject: Reply with quote
Fuel tap turned on?
edd
PostPosted: 01:07 - 08 Jan 2007    Post subject: Reply with quote
finpos wrote:
Did you take the engine apart? If so you might have made a boob of the timing. finpos.
RS 125's are 2 strokes, and I'm pretty sure you can't mess up the ignition timing on them.
Have you got any compression? Have you tried jump starting it off a big battery/ car? If you have fuel spark and compression with a 2 stroke, then it has no choice other than to start really.
Bluespark Automotive - Diesel Tuning for Performance and Economy
faith183uk
PostPosted: 22:46 - 24 Jan 2007    Post subject: Reply with quote
First of all i'd remove the plug, put your thumb over the plug hole and press the start button. The pressure should blow your thumb off the hole. If so then compression is not your problem.
I would then pour a small amount of petrol directly into the cylinder via the spart plug hole, replace the plug and try again. If it starts and runs a while then its a fueling problem. Most likely carb.
Also make sure the breather hole on the tank is not blocked as this will stop fuel flowing. A quick check is if you open the petrol tank cap and it hisses then you have a blocked breather (the hiss is the air rushing into the empty space)
Check the fuel tap is on and clean, remove the pipe to see it fuel is flowing nicely
Also check the kill swith is set to run (not being funny but it happens)
What sort of noise is the starter making, does it sound like its enganging and turning the engine?
The last post was made 19 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.39 - MySQL Queries: 13 - Page Size: 49.48 Kb
